XM No Signal | FerrariChat
XM No Signal
Discussion in 'Ferrari Discussion (not model specific)' started by icelander47, Sep 28, 2018.
  1. icelander47
    icelander47 Karting
    Sep 12, 2012
    142
    Just picked up a 2008 612 with the bose system. It says no signal for XM even though I just paid for the subscription and had the signal sent. Since the Ferrari is totally new to me, has anyone else run across this and how did you resolve?
    I did searches but didn't see the same problem
  2. RonH
    RonH Formula 3
    May 29, 2016
    1,061
    Newport Coast, California
    Ron H
    Your antenna cable could be broken. If you open your trunk you will see a black cable on the right hinge. That is your cable. Sometimes it gets pinched when you open and close your trunk. If it does then you will get “no signal” on XM. I had that problem.
    I see you bought your car at Euro Car. They use Rocco’s to bird dog electronics problems and they are quite good. They know the 612 system. You can have Euro Car arrange an appointment and they will do it gratis since you just bought the car (I recently bought a Mercedes from them with an electronics issue and they had Rocco’s fix it). Or you can phone Joe at Rocco’s direct. 949 722 0707.
  3. anunakki
    anunakki Seven Time F1 World Champ
    79,359
    Las Vegas Nevada
    Jerry
    When my 2010 California first arrived i couldnt get XM to connect. Turns out it was because the units are ID'd as Chrysler and that red flagged my account as I told them it was a Ferrari. Took several calls to correct the problem
