yank out that F1 for a stick shift...? 1998 355 | FerrariChat
Discussion in '348/355' started by leslie-ca, May 20, 2007.
  1. leslie-ca
    leslie-ca Karting
    Feb 11, 2006
    97
    No. Calif
    Leslie
    This would be in a salvage car so we are not concerned about originality. Assume the car is bought cheaply, under $45k for a 1998 spider. Everything but the paddles works. The trans will shift, it can be actuated if voltage is applied directly. The prior owner has tried many new parts and has given up. Since we preferr the manual shift, what about a change over ? So.... assuming used parts are available, what would it take? I guess I may find a taker for the F1 stuff that is usable. Does anyone feel this would this be a viable solution?.
  2. plugzit
    plugzit F1 Veteran
    7,775
    Redondo Beach, CA
    Bruce Bogart
    Since I like to be more involved the operation of the car, I think you'd be making the car better-more of a drivers' car-which is exactly what it is. Congratulations on being freed of the tyranny of "dollar value".
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Manual shift 6-speed gets my vote :)!
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,425
    CT
    Jay
    old school 6 spd with a foot working the clutch? I do that every day in my daily driver. But paddle shifting a 6-spd with an electro-hyrdaulic clutch like F1? Now that's special :)
    But to the original question...I have no idea how that'd work. It seems like a huge change, not just the mechanics but the ECU too...
  5. wingfeather
    wingfeather F1 Rookie
    Feb 1, 2007
    3,653
    rock bottom
    If you want stick, buy a 348.
    355 = F1
  6. Meeyatch1
    Meeyatch1 Formula 3
    Dec 28, 2003
    1,343
    Low flying jet.
    Mitch
    Okay, that makes no sense.
  7. PAR8HD
    PAR8HD Karting
    Mar 31, 2007
    75
    Shoreview, MN
    Harold J. Hitchcock
    Just a guess, but I think that would be a disaster to try. You would need to change over the center console. Then run the linkage through the firewall back to the transmission. Not sure what the engine change would be, but I would bet a clutch and ECU swap would be in order. Perhaps someone would know if the mounting on the engine is different. Also curious is this would affect the gas tank as well. Also need to check on the mounting of the transmission, are the mounts the same for an F1 and a stick? More work than I would do for this. Keep it original.
  8. Rifledriver
    37,072
    ????? Wow.
  9. wingfeather
    Feb 1, 2007
    3,653
    rock bottom
    If you've seen that happen in person, then simply get an electronics guy to wire up paddle switches to send power directly to those leads you speak of. Problem solved for about $500.
    Otherwise, for about $10,000 you could hire Vildini Motorsports to swap in an RB26DETT :)
  10. leslie-ca
    leslie-ca Karting
    Feb 11, 2006
    97
    No. Calif
    Leslie
    PAR8HD,
    Thanks for the tip, on my way now to buy a clutch and remove that pesky torque converter, If you need a spare I will sell it to you real cheap...
  11. leslie-ca
    leslie-ca Karting
    Feb 11, 2006
    97
    No. Calif
    Leslie
    Thank you wingfeather. Now how about we skip the simple electronics guy, and for $500 you just ride along back there and when I yell out "SHIFT" you just touch the wires together real quick like...
    P.S. .... Do not worry, I will keep the RPM's down...I promise...
  12. wingfeather
    Feb 1, 2007
    3,653
    rock bottom
    Okay :)
    As long as I get to wear a camo baseball cap & a shotgun!
  13. leslie-ca
    leslie-ca Karting
    Feb 11, 2006
    97
    No. Calif
    Leslie
    Good comeback. Me thinks that hardwired would not allow for proper order and timing that is software controlled. Any other suggestions?
  14. leslie-ca
    leslie-ca Karting
    Feb 11, 2006
    97
    No. Calif
    Leslie
    #14 leslie-ca, May 26, 2007
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    LOL :D :D :p
