Yas Marina changing track layout to aid overtaking at F1 season finale | FerrariChat
Discussion in 'F1' started by 444sp, Jun 23, 2021.
  1. Bas
    Bas Four Time F1 World Champ
    Mar 24, 2008
    42,772
    ESP
    Bas
    Not quite seeing the logic here...they get rid of 2 overtaking zones, create 1 high speed corner (= very tough to follow).
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,732
    The new track will likely have fewer passes for position that the older one.
    A lot of money down the drain for nothing.
    Bas likes this.
  3. william
    william Two Time F1 World Champ
    27,691
    That will eliminate 2 chicanes, and I am all for it.
    Chicanes are only put on circuits to artificially reduce speed.
    The FIA is always afraid of lap time.
  4. DF1
    DF1 Three Time F1 World Champ
    New banked corner part of Abu Dhabi F1 track changes
    By: Jonathan Noble
    Jun 24, 2021, 6:01 AM
    A high-speed banked corner and revamped hairpin section have been revealed as part of multiple changes Abu Dhabi is making to its Formula 1 track.
    After a lacklustre season final in 2020, Yas Marina chiefs have worked hard to revamp its circuit layout which it felt did not allow current F1 cars to race properly.
    With work due to start in the summer on the overhaul, the changes to the venue are focused on three key areas of the track.
    * At the hairpin section, the chicane before it will be removed – with the width of the track in this area will also being opened up to allow multiple racing lines and potentially more passing opportunities.
    * At the end of the second back straight, the tight and twisty complex of bends are being removed completely and replaced with a high speed and wide banked corner.
    * Finally, at the hotel section, the corners that run around here are being opened up so it becomes faster and more flowing.
    Saif Al Noaimi, acting CEO of the Abu Dhabi F1 promoters, said that the aim of the changes was simply to help improve overtaking opportunities – something which had been lacking in the past.
    "We've listened to the spectators and fans, and we've listened to the teams and the drivers," he explained. "We've built these modifications, taking into consideration the feedback that we have received.
    "Ultimately, our objective is to create more overtaking opportunities, closer wheel to wheel racing and a faster, free flowing circuit."
    Al Noaimi hoped that the banked corner will especially stand out as something special, as he labelled it potentially 'iconic'.
    https://www.autosport.com/f1/news/new-banked-corner-part-of-abu-dhabi-f1-track-changes/6602969/
  5. Nembo1777
    Nembo1777 F1 World Champ
    Nov 4, 2006
    11,598
    opposite lock
    Marc Sonnery
    A banked but tight corner after a long straight...great so any one going off will land in Yemen or take a plunge in the Gulf waters!
    The banked corner in Zandwoort is shortly after very slow corners, quite different.
    The cancellation of the chicane before the hairpin will help hugely but the other changes not so sure. Hopefully the banking will allow outside passes like the constant radius curves of Mugello.
    Bas likes this.
  6. Bas
    Mar 24, 2008
    42,772
    ESP
    Bas
    Ah didnt' know the corner was banked...that changes my opinion somewhat. I'll hold off commenting until seeing it but can't be *that* bad all of a sudden.
  7. Nembo1777
    Nov 4, 2006
    11,598
    opposite lock
    Marc Sonnery
    All the articles about this state it will be banked... I remain sceptical regarding safety.
    Bas likes this.
