Yellow BB 512 carb, 3310 original miles | FerrariChat
Discussion in 'Boxers/TR/M' started by Arakis36, Jul 29, 2007.
  1. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    Hi All,
    Noticed a mistake in my previous post, here 's the correct info;
    - 1981 BB 512 carb
    - 3310 original miles (mistake 33100)
    - everything looks new, seats, dash, undercar, engine,...
    - Asking price $124'000.00
    - Location Europe
    Question: What do you guys think about the price for such a low mile BB ???
    Thanks a lot
    Cheers
    Charles
  2. Arvin Grajau
    Arvin Grajau Seven Time F1 World Champ
    Jun 7, 2006
    78,325
    Wurundjeri man.
    Arvin Grajau
    when was it last used?
  3. Arakis36
    Arakis36 Karting
    Jul 27, 2007
    163
    It' s really been used every year, but the old gentleman drove it a couple of miles each time and left it in his garage... The mechanic that worked on it, always took great care of it every year, so that the carbs would not be clogged and that all the other parts would work. It last runned about a month ago, clutch was repalced at 2500 miles, just replaced fuel pumps and a couple of relays... Talked to the mechanic and he said it drove amazing... This really is a rare jewel in my opinion...
    Cheers
    Charles
  4. J Ingram
    J Ingram Formula Junior
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    Wow. Sounds like a good car which looks to be in good condition. If it is as stated, you have made a good choice and will love driving it. Keep us posted and send pics!
  5. amenasce
    34,460
    Joe Mansion
    Cheap IMO. Even if it might need some work, the opportunity to buy a car like a Carb BB with low mileage doesnt come up that often.
  6. jmn
    jmn Formula Junior
    Jan 31, 2005
    361
    Colorado
    jmn
    Clutch replaced at 2500 miles? I'm guessing the car has more miles.
  7. amenasce
    34,460
    Joe Mansion
    Wasnt the BB a terrible clutch eater ?
  8. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    They are high geared gals.
    Unless the engine, read carbs, are well tuned the car can be hard to get going up hill from a stop. Driver experience and familiarity with the car helps, but stops on semi steep hills are better avoided.
    The car you’re looking at sounds nice and well cared for. However I think a full PPI would still be in order. Besides the needed engine out service, I’d also suggest changing out the rubber cooling water hoses as well as the fuel hoses.
    Good luck with your tentative purchase, and let’s see some pictures!
  9. donv
    donv Two Time F1 World Champ
    26,131
    Portland, Oregon
    Don
    Not that bad, unless it's been abused. I just replaced my clutch at 33000kms, and I thought that was rather quick.
    Isn't sitting excessively bad for the clutch also?
  10. J Ingram
    Aug 12, 2006
    449
    Moreno Valley, CA
    Jesse Ingram
    I agree about the hill starts. My carb BB is well tuned and I have no trouble pulling off from stoplights. I just give just a little throttle while easing out the clutch until the car starts to move. There is then a short, subtle dead spot where the clutch and transmission are hooked up. Then you can slowly apply the throttle without any clutch burning or slipping. I use that technique on my motorcycles and it has worked well with every stick shift car I've owned. Never burned out a clutch. I try to avoid the hill starts though usually by timing the light or just avoiding it all together.
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    That's about the right price in the market...
    That's the last of the carbed versions, as you may be aware..........
  12. BigTex
    79,386
    Houston, Texas
    Bubba
    Sitting isn't necessarily bad for the clutch but they can rust to the flywheel, and stick.......could be the reason for an early renewal......
  13. JTR
    JTR Formula 3
    Apr 26, 2005
    1,502
    in a house
    I think Jeff's (JP Sarti) car had a stuck clutch because it sat for quite some time. I think he said a couple of the shocks were stuck as well.
    Boxers like to be Driven!
  14. J.P.Sarti
    J.P.Sarti Guest
    May 23, 2005
    2,426
    Yes that was correct, clutch was stuck to flywheel, had to remove clutch to fix, carbs has old fuel deposits and needed complete cleaning and one bad shock in the rear knocking over speed bumps
