YELO 550 - a Tribute to Steve (GS) Johnson | Page 12 | FerrariChat
Discussion in '456/550/575' started by gsjohnson, Oct 31, 2014.
  1. fatbillybob
    Aug 10, 2002
    28,608
    socal
    Hood looks great! Very subtle and does not ruin the look of the hood . Good job.
  2. Thrasher
    Thrasher Formula Junior
    May 26, 2012
    281
    London UK
    waow! cant wait to see the hood on, spectacular.
    What wheels have you got? maybe the standard modular wont be aggressive enough for the hot rod look.
  3. fatbillybob
    Aug 10, 2002
    28,608
    socal
    A long time ago HRE made a "ferrari bolt pattern adapter to centerlock hub" for HRE centerlocks. If a centerlock could be sourced that would make a statement.
  4. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    Thanks for the positive comments John, Carl and Thrash...
    John-Yes I would have preferred larger louvers, but it was impossible unless I cut the hood bracing on the bottom side. I didn't want to do that and I settled for what you see. They do appear larger in person versus the photos. I haven't performed any trough work on the bottom side either. Water entering? Only when parked. I will not attempt to drive the Yelo Hot Rod in the rain...although surely I will get caught out at some point :) Best laid plans...I'll take some pics of the bottom side over the weekend.
    Thrash- 19" NF2s for the Yelo Hot Rod...shown earlier in the thread.
  5. ///Mink
    ///Mink Formula Junior
    Sep 5, 2006
    818
    Fair Oaks, CA
    Tom Mink
    Wasn't sure I'd like the louvers, but I kind of do...
  6. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #281 gsjohnson, Aug 9, 2015
    A little late, but as promised, here are the pics of the back side of the hood. Note the vent size and quanity were based on the support bracing locations as I didn't want to cut into the braces.
    I then got a little side tracked and started playing around with some aluminum thermo paper to protect the paint from the heat. I first cut out some patterns in the shape of the area on the hood I wanted to cover. Once I completed the pattern I then folded the pattern in two so I could trim the pattern to be uniform on both sides. I then placed the pattern onto the aluminum thermo paper and then cut the thermo paper to the pattern I made. I tried a couple of thermo pieces and placed them on the hood.
  7. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #282 gsjohnson, Aug 9, 2015
    Since I've got this screeching loud T/O bearing, I've decided to change the clutch assembly. I removed the rear brakes, axles, changed the fuel filters while I was there, and drained the trans oil...including the filter as I migrate towards the trans removal. Don't over look the trans filter as part of the draining process...here's why...Note the metal chips in the upper left corner of the filter I removed. I doubt this has ever been changed on the Yelo Hot Rod.
  8. Cribbj
    Cribbj Formula 3
    GS, thanks for the underside pics of the hood; it's pretty apparent why you didn't go any larger with the louvers now - I wouldn't have either :)
    Curious which brand of reflective barrier you chose & why? There's a plethora of that stuff out there and not much long term testing feedback on which works the best, etc.
    Tranny filter looks pretty nasty. Hope your synchros are OK.
  9. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #284 gsjohnson, Aug 10, 2015
    Thermo Tec was born out of the aircraft industry and it was only aluminized heat barrier thermo shield that could actually produce testing results. I was not impressed with Dynamat. I also used Thermo Tec for heat protection of my battery as well.
    Thermo-Tec : Full product line
  10. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #285 gsjohnson, Aug 27, 2015
    Ok I just received my vent housings back from Robbie at Sticky-no-more. Robbie does great work. Note the new arrows. Removing the vents from the dash is simple...It's a slip fit and just requires soft pry tool to walk them out of the dash. It's a little trickier to separate the chrome ring form the vent, but still easy with a little patience. Just depress the little plastic tabs and work your way around in a circular manner while putting a little pressure pulling them apart by hand. Each vent has six tabs. Cleaning these chrome rings must be done very gently with rubbing alcohol, careful not to damage the chrome or the painted surface. Do not rub hard. Once I received the vent housings back from Robbie I snapped the ring and the housing back together. There's a guide slot in the housing so the ring will only go on one way. Gently snap the two pieces back together. Don't force anything or you will break one of the tabs. Just be patient.
  11. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #286 gsjohnson, Aug 27, 2015
  12. wbklink
    wbklink F1 Rookie
    Sep 2, 2009
    3,414
    Los Angeles
    Bill Karp
    #287 wbklink, Aug 27, 2015
    My tech in vegas put this around my battery, it seems to be much heavier than yours.
    Don't know the technical information about it.
    Cheers,
    Bill
  13. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #288 gsjohnson, Sep 7, 2015
  14. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    I have a brand new pair in my garage but I've been afraid to use them because I heard the oil can mess with the MAF sensors. Please let us know how it works. I would love to use them if they don't interfere. They were hard to get.
  15. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #290 gsjohnson, Sep 7, 2015
    Time to install the 575 radiator shroud for additional cooling support. The great thing about this upgrade is it is a direct bolt on with no modifications. Very simple...I cleaned the dirt and debris from the radiator fins and painted the top tank of the radiator. Note the comparison shot of the two shrouds. Quite a size difference. I also noticed that the spa fans are actually balance as evidenced by the strategically placed clips on the blades...
    The finished installation is shown in the last pic.
  16. Cribbj
    Cribbj Formula 3
    Hope that works well for you GS. Was that the only change you made? didn't change the fans or the radiator itself? If that was the sole change, it'll be REALLY interesting if you notice any differences.
  17. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    The only reason you would get MAF sensor malfunctions is from over saturating the filter gauze with the oil solution. People have a tendency to think that more is better, when in this case it is not. K&N has excellent instructions, and I follow theirs. Use the spray bottle type application on the filters. Spray in even strokes approximately 3 or 4 inches away in the direction the pleats travel moving your way down until you have covered each pleat...repeat the process on the other side...one time on each side is all that is needed...no more. Do not spray in a circular motion or randomly. Then set the filters face down on a shop towel, (as you would when installing them) in the sun for 20 minutes. This lets the oil solution travel thru the gauze and any access will drain thru onto the shop towel you placed them on. Wipe any access residue off. Hope this gives you the gonads to install your BMC filters :)
  18. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    This is helpful. Thank you. I'll let you know if filter installation gonads arrive intact. Also, what is the status of them in the box? Are they completely dry and need to be oiled?
  19. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    Yes the BMC filters come pre-oiled and in a sealed plastic wrapper. Even easier if yours are new. No fuss, no muss :) Your gonads are growing... :)
  20. sherpa23
    sherpa23 F1 Veteran
    9,993
    Rocky Mountains
    Bastuna
    Yes, they're new in the box. That makes it easier.
  21. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #296 gsjohnson, Sep 8, 2015
    Hi John-I did make some other small changes to the cooling system on the Yelo Hot Rod. I converted the coolant tank to a conventional radiator cap utilizing a Stant 18-22 lb cap...I also changed the Thermostat to a lower rating and drilled two 1/16" opposing holes in the thermostat flange. We use to do this on our race cars to help encourage the air bleeding process, as well as the fill process. Additionally I will be using RO water with the recommended Shell coolant. Silicone hoses as well. Radiator, Water pump and pulley remain stock.
  22. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #297 gsjohnson, Sep 10, 2015
    After sealing off the gaps between the shroud and radiator, I attempted to install the radiator. It wouldn't quite slip into place. I found the upper mounts interfered with the new 575 shroud due to the increased size. So much for the direct bolt on with no mods :) That also tells me that the 575 has different upper radiator mounts than the 550. I ended up having to cut down and modify the upper radiator mounts on each side. Still an easy mod...The pics show the before and after modification.
  23. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
    #298 gsjohnson, Sep 23, 2015
    Ok I finally mounted the hood and the front bumper onto the Yelo Hot Rod. Couple of notations...Both the hood hinge mounting pads as well as the bumper frame mounts have shims for the proper alignment. I marked them all left and right. It was difficult getting some good shots of the hood as the nose of the Yelo Hot Rod are too close to the back wall. Additionally I performed the final install of the Fog Lamps.
  24. gsjohnson
    gsjohnson Formula 3
    Feb 25, 2008
    2,291
    Woodland Hills, CA
    GS Johnson
  25. 308 GTB
    308 GTB F1 World Champ
    11,651
    New Jersey
    Barry Wolinsky
    #300 308 GTB, Sep 23, 2015
