Yep... another 355 belt question... Sorry | Page 2 | FerrariChat
Discussion in '348/355' started by DirkDiggler, Mar 22, 2022.
  1. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    WATSON likes this.
  2. Shorn355
    Shorn355 F1 Veteran
    6,891
    Colorado
    Scott
  3. phrogs
    phrogs F1 Veteran
    7,376
    Kzoo Michigan
    Whoa!
  4. Shorn355
    Shorn355 F1 Veteran
    6,891
    Colorado
    Scott
    Gialllo uno and INTMD8 like this.
  5. fatbillybob
    Aug 10, 2002
    29,456
    socal
    I thought I read somewhere on Fchat your belt broke or am I mistaken?
  6. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,473
    Los Angeles
    For me it's not this, it's that I do my own work and have very little free time...and majors are time-consuming. So it's not about money, but time. And fwiw, the reason I service it myself is that I find my work is better than a shop's (not yours Brian)
    Carmellini likes this.
  7. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
  8. Suffyk
    Suffyk Formula Junior
    May 25, 2012
    319
    Thanks @yelcab ! Just going through an engine out right now, and mostly changed everything on your list (and then some). You did list a couple of things that I’ll have my mechanic check out while the engine is out. I’d also add the transmission mounts - mine were done - 40k mile car.
    The @Ricambi America 30k mile kit is amazing, highly recommend.
    My car had a dealership documented engine out 1.5 years (1000km) ago completed by the previous owner… they didn’t bother to change the cam seals (one had a rip). To that point, the new seals from Ricambi are orange, the ones in the car were black. Does anyone know when/if there was a color change?
    The bearings were not stamped hill engineering, and the tensioners were still the original - they still had a 96 date code (97 car). One oil line was leaking considerably - changed all three. Moral of the story… unless you did the previous major and know what was done and what wasn’t done, you never know what to expect until you pull the motor - regardless of how long ago the previous major was done.
    ShineKen, tatry68 and Carmellini like this.
  9. fatbillybob
    Aug 10, 2002
    29,456
    socal
    What was the failure in your case? I have heard some weird ones as well as some where people have gone beyond Ferrari's "service life."
  10. fatbillybob
    Aug 10, 2002
    29,456
    socal
    Sometimes you see some pretty strange stuff that was , "Done."
    Suffyk likes this.
  11. johnk...
    Jun 11, 2004
    11,299
    CT
    John Kreskovsky
    The long an short of it is that I drove over a short section of road that was being repaved. All dug up and just a stone base. Best we could tell was that a stone kicked up and caused the belt to ride up on the drive pulley fence, initially shearing the teeth off the outer 1/2" of the belt before it got cut through. No mechanical issues or were found. Make of it what you will.
  12. fatbillybob
    Aug 10, 2002
    29,456
    socal
    There was a similar 348 one where a guy actually found the toll token in the undertray that exactly matched the punched out area of the timing belt! It was posted here
    Zamboniman308 likes this.
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,704
    San Carlos, CA
    Mitchell Le
    By the way, the 355 is the wrong car if you are "looking to save a buck or two."
    ShineKen and Carmellini like this.
  14. PaulK
    PaulK F1 Rookie
    4,815
    Michigan
    Paul
    Quote of the year right there. I had to dip into my children's college fun to run a 355.
    Good thing I don't have children! :D
  15. 308 GTB
    308 GTB F1 World Champ
    11,758
    New Jersey
    Barry Wolinsky
    phrogs, WATSON and Qavion like this.
  16. PaulK
    PaulK F1 Rookie
    4,815
    Michigan
    Paul
    #41 PaulK, Mar 23, 2022
    I am seriously thinking of getting the challenge belt "guard(s)" to seal off the belts.
    Do I need anything else besides the two upper and one lower guard to fit them to my '95? Longer screws perhaps?
    This has been a big fear of mine since I got the car. When I pull the engine these are going on!
  17. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Longer bolts might be necessary, Paul, but they're easily sourced.
    The toll token picture I posted were of a 308. Its transversely mounted engine is more prone to foreign body ingestion than our 348s and F355s.
    Barry
    PaulK likes this.
  18. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,036
    NE FL
    Ken
    I do not think you need longer bolts. There are two super thick washers on the top bolts. I'm sure these come off and the guards go in their place
    PaulK likes this.
  19. PaulK
    PaulK F1 Rookie
    4,815
    Michigan
    Paul
    Thanks Barry, I know the 308 is transverse and that my fear is a little irrational. Still, it only takes one pebble to ruin everything!
    Perfect, thank you!
  20. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Paul,
    The reason those belt guards were developed for the F355 Challenge was due to all the rubber on the track shed by the slicks all the cars are driving on. The "tire boogers" are thrown up by cars ahead and by my own car and get into the brake calipers, on the inside surfaces of the wheels (sometimes throwing them out of balance), and even into the cabin. Big chunks of slicks can do real damage. A couple of years ago at Sebring I had a chunk of rubber smash through the screen in the forward aspect of my left rear wheel well. It took out two blades of the cooling fan and damaged the radiator.
    The underbody panels on the F355 protect the cam belts from small debris on roads. The track is a completely different affair.
    If the guards are available, put them on at your next major service. They'll provide an extra layer of protection over that provided by the stock belt covers.
    Barry
  21. ShineKen
    ShineKen Two Time F1 World Champ
    20,202
    Southern California
    Nostradamus
    The one argument against the guards is if something does get in there as the guards do have openings, you'll have to get creative to get them out :).
  22. 308 GTB
    11,758
    New Jersey
    Barry Wolinsky
    Yes, the guards are ventilated but tire boogers would have to take a creative trajectory to get in.
    My car is currently undergoing its major service. I'll ask my techs if they found anything inside.
  23. PaulK
    PaulK F1 Rookie
    4,815
    Michigan
    Paul
    I knew it was for the marbles but I had no idea they could do that kind of damage. Wow! I think I may just put these on.
    Yeah I dont think much should get in there. They "seal" the top of the cam covers (I always worry about those spark plug covers coming loose) but the lower one in the V has holes in it. Hopefully nothing comes in!
  24. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,036
    NE FL
    Ken
    WATSON likes this.
  25. kenneyd
    kenneyd Formula 3
    Sep 30, 2014
    2,036
    NE FL
    Ken
    Here is the only example I've seen posted here related to a 355 belt failure. I dont remember exact miles, but I think it was in the teens. Obviously a beat 355, likely salt belt. Im guessing frozen tensioner pulleys or the rust cause the belt to slip on the gear?? GROOSSS lol
    IvanRico likes this.
