Yet another 348 clutch rattling noise thread | FerrariChat
Discussion in '348/355' started by Finpat, Sep 21, 2023.
Tags:
  1. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    There are plenty of clutch noise and odd behaviour related threads but it seems that I have a bit different set symptoms:
    1) When idling and gear on neutral, warm or cold, a very faint rattle can be heard. I pretty sure it is coming from direction of pumpkin. Pretty sure, but not absolutely, 100% sure. 30+ yrs old power train will always make some noises.
    2) When clutch pedal is pressed to the bottom, a very clear rattling sound can be heard in cabin. The rattle comes at the bottom 1/4 of the pedal travel.
    3) When clutch pedal is on the top 3/4 part of the travel the rattling sound can't be heard. Only the same very faint noise as on idle.
    4) The clutch engagement is taking place in very short travel, quite close on the top of the pedal travel.
    Clutch disc and pressure plate are pretty fresh, TO bearing is a bit older. The car is 1991 TS.
    Any guidance and/or guesses what would be the root cause(s)?
  2. andrejwolk1975
    andrejwolk1975 Karting
    Feb 28, 2020
    107
    Italy
    Andrea M
    Flywheel? Is there any cluncking/rattling noise when you turn off the car? Have you got any problem in starting the car when it is well "warmed"?
  3. fatbillybob
    Aug 10, 2002
    28,626
    socal
    WAG pressure plate finger
  4. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Happens at a stans still while not movig?
    Pull The clutch and have a look it's possible you broke a pressure plate finger for exampme.no way to tell without looking. Ernie has a good thread on clutch repair. 3 bearings in there too, could be voith is dry and if so ita gonne get expensive unleass you fabricate new blocks.
    Cant really tell over the internet but good sense says pull clutch to start and have a look. Easy to do.
  5. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    I forgot to mention in opening post that the car (or the toy, actually) starts butter smooth when warm.
  6. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    I will pull the clutch when driving season ends in a week or two. Beautiful and warm fall day still today.
  7. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    Now the dual disc clutch is on the floor.
    At least all the fingers all are there and by looks of it triple seals are not leaking. I will open the clutch pack tomorrow to see if flywheel bolts are the culprits. Do I need some special tool for opening the flywheel retaining bolt?
  8. fatbillybob
    Aug 10, 2002
    28,626
    socal
    If the clutch pack is good then I would pull the clutch shaft to make sure the transfer gear is properly staked to torque. When the lock ring come loose the gears bang on each other and will eat each other and be very costly. A faint noise as you describe could be you got it early and perhaps just get away with proper tightening. This was not done right at the factory. This was 1st found on the 348 challenge cars because they were run harder. Of course I'm a track guy and drive my Ferraris so I found this the hardway too. There are threads on here about the issue and me rebuilding my gearbox and then helping Ernie to rebuild his gearbox and the "Stooges" were born.
    ernie likes this.
  9. m.stojanovic
    m.stojanovic F1 Rookie
    3,172
    Malaysia - KL
    Miroljub Stojanovic
    #9 m.stojanovic, Dec 23, 2023
    Yes, if the special low head flywheel bolts (those that require an M8 Ribe Bit) were replaced by standard allen bolts, the bolt heads might be contacting the housing as the clearance there is very small. To inspect these, you don't need to disassemble the clutch. Just take the whole clutch/flywheel assembly out of the housing (loosen the allen grub screw and undo the large hat-bolt) then look for any scratches on the housing.
    Before taking the assembly out, you can try rotating the clutch assembly positioned as shown on your picture on the floor and listen for any faint scratching sounds. You can also try by having the clutch assembly upside down and rotating the housing while pressing down on it.
  10. m.stojanovic
    3,172
    Malaysia - KL
    Miroljub Stojanovic
    ernie likes this.
  11. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    I hope it is something simple like flywheel bolts scraping the casing. I have browsed few of the transfer gear staking threads and they look a bit intimidating.
  12. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    The unloaded clutch assembly rotates freely without any screech when pumpkin is facing the floor. Very good tip about loading the clutch assembly pumpkin facing up. I will put some soft wood under the setup and then press it down.
    That is project for tomorrow, today is the time for Xmas food coma.
    Merry Christmas from Frozen Tundra for everybody!
    steved033 likes this.
  13. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    9,594
    Atlanta, GA
    Steve D.
    like this? LOL. when I got my car, the flywheel bolts had backed themselves out....all of them...like they'd never been torqued. A light touch on the pedal and clack-clack-clack-clack!!!
    fixed, serviced, and 6 years later just fine...
    sjd
  14. fatbillybob
    Aug 10, 2002
    28,626
    socal
    That's a new one for me. I have never seen that.
  15. steved033
    Apr 12, 2017
    9,594
    Atlanta, GA
    Steve D.
    My money was on dead throwout bearing, or maybe a broken finger....sure sounded like a really dead bearing. Opened it up, it already had the hill bearing and body inside, and all the fingers were intact. There was grease everywhere so I decided to do the flywheel service. I got it apart was was like oh.....i see...
    sjd
    ernie likes this.
  16. fatbillybob
    Aug 10, 2002
    28,626
    socal
    Amazing! One of the issues is these cars are decades old with many owners and many mechanics finger prints. There is a lot of bad out there added to the natural failure of these cars.
  17. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    Whoops, mechanic forgot to torque those bolts up.
  18. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    Clutch pack opened and re-packed, no oddities found. Nice and clean looking as it should after just a couple of thounsands kilometres. Now going back in and I focus pedal travel adjustment.
    fdekeu likes this.
  19. fdekeu
    fdekeu Formula Junior
    629
    Belzium
    Frank
    Is the rattle still present?
    Could have checked with the flywheel off
    Use earplugs ;-)
  20. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    Too early to tell. I suspect that throwout bearing travel is too long when clutch pedal is fully pressed. We will see, or actually hear in couple of days once I get everything back together.
  21. fdekeu
    629
    Belzium
    Frank
    Travel too long = different master cilinder?
    May be a good idea to change the slave seals while your in there
  22. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    Good point about master cylinder. Must check.
    Slave seals were brand new. Clutch was open last time in 2022, about 4000km ago.
  23. fatbillybob
    Aug 10, 2002
    28,626
    socal
    funny how everyone takes off the rear bumper. That is not needed.
    PAP 348 likes this.
  24. Finpat
    Finpat Karting
    Sep 17, 2021
    236
    Finland
    Kari Lehtinen
    I am a Ferrari newbie so more space to work in an unfamiliar territory helps. Also a shiny stainless steel exhaust from Protoxide is going in.
    fdekeu likes this.
