488 - Yet another battery question / problem | FerrariChat
488 Yet another battery question / problem
Discussion in '458 Italia/488/F8' started by DiamondDog, Jun 23, 2024.
  1. DiamondDog
    DiamondDog Formula 3
    Aug 29, 2021
    1,463
    Orange County, CA
    I have replaced the battery 2 times already in 2 .5 years. I have it on a tender all the time. These issues tend to happen when I get my car back from Ferrari dealer service. I tell them to put it on the tender, but I suspect they do not and they will have the car for 3-4 days or so
    I have the OEM Ferrari tender made by CTEK and I have the more advanced one made by CTEK (5.0). The battery wont accept a charge from the 5.0. It makes a pulsing sound, then stops making that pulsing sound. IN the past in would continue to make the pulsing sound.
    I swapped the 5.0 with another 5.0 unit and it fails as well and that charger works on the other car just fine, so its not the charger.
    The weird thing is that the OEM Ferrari Charger works just fine.
    Battery is an interstate battery that was installed 6 months ago and was the 2nd one. Do you think the battery is failing despite the OEM battery tender is able to charge it ok?
  2. ferrefeh
    ferrefeh Karting
    181
    Illinois
    Feh H
    Strange. Mine has an interstate installed in 2022 and working just fine with the OEM tender. Wondering if you have some current drain somewhere.
  3. DiamondDog
    Aug 29, 2021
    1,463
    Orange County, CA
    Just to clarify, it works fine on the OEM tender made by CTEK, it does not work on the "better" (5.0) tender made by CTEK and ia hve swapped the tender and it works on another car and the other cars fails on mine (The 5.0) so its not the charger
  4. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Fort Lauderdale, Florida
    Todd
    weird. my F8 is original battery still, over 3 years old and 7300 miles.
  5. Snapshift
    Snapshift Formula Junior
    924
    Centralia IL
    Lyle D. Pahnke
    What happens if you connect the CTEK 5.0 directly to the battery terminals on the battery with the cable clamps? What I am learning, is that if there is a high enough parasitic load on the battery while sitting, that some chargers won't actually initiate the charging cycle for some unknown (to me at least ) reason why.Using one of the bluetooth battery monitors can sure give you enough information about whether the battery is charging with the charger, and the voltage rate of drop over a few days indicating that there may be a high parasitic load on the battery. The only way to measure parasitic load is to put a current reading VOM in series with the negative terminal.
  6. SVCalifornia
    SVCalifornia F1 Rookie
    2,571
    Silicon Valley
    Keith
    Think you have an AGM battery. So you need to make sure you have an AGM capable charger and it is in AGM charge mode.
    I wouldn’t trust the OEM charger having seen them do charging very poorly and it has no diagnostic capability. My OEM Roma charger (not a CTEK) is completely useless causing considerable grief. New high end CTEK much better.
    That the new CTEK fails is indicative.
    SV
  7. ChaosAD!
    ChaosAD! Karting
    Jul 29, 2021
    167
    John Shinas
    I’m going on 2 years and 4,300 miles with the original battery. I’ve never gone longer than 2 weeks straight on the tender before driving it so it doesn’t sit plugged in very long.
  8. 020147
    020147 F1 Rookie
    4,607
    Midwest
    I upgraded my 488’s charger to a model 7002 from CTEK and it’s been flawless for 4 years now. My battery is an AGM battery and I use the AGM function on the charger.
  9. MANDALAY
    MANDALAY F1 World Champ
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    IMO Our factory Ferrari batteries are OK when they go in the car. Our cars have a volt age drain. The longer the battery is not on a tender the greater the chance of a battery fail , i.e a cell or 2 dying. Once that happens its only time when it fails.
    Your car / battery was blessed IMO that it wasnt without a tender for any length of time and no cells have been damaged..
    CChung likes this.
  10. SD455TA
    SD455TA Formula Junior
    I'm thinking you could go 6 years for starters. Then play it by ear.
  11. MANDALAY
    May 23, 2013
    14,645
    AUSTRALIA
    ANGELO
    True however not having a starter close by is a BIG gamble.
  12. 05F430F1
    05F430F1 F1 Rookie
    3,600
    Todd
    Oh, no worries.. I took Mandalays advice a year ago and got the NOCO starter. Forgot about it til now but it’s in the bonnet just in case.
    MANDALAY likes this.
