News
Yo Ho Yo Ho a Shaughnessy Barn Find for me!
Discussion in 'Vintage (thru 365 GTC4)' started by T308, Jul 2, 2005.
  1. T308
    T308 Formula 3
    1,000
    Southern Cal
    #126 T308, Apr 28, 2015
    Next step is to continue to return to bare metal and extract the springs which after 50 years really want to stay where they are.
    The loom is out and off to be re-created.
    Need to break down the interior of the doors.
    Strip and reassemble the bright work.
    Then up on the dolly and off for metal surgery and a fresh coat of Ivory.
    More to come.
  2. simsko
    simsko F1 Rookie
    Feb 5, 2012
    3,619
    What colour is it going to end up in? The original avorio would be a great choice:D
  3. T308
    T308 Formula 3
    1,000
    Southern Cal
    Back to the original finishes. Ivory over red interior.
  4. Sig. Roma
    Sig. Roma Formula Junior
    Mar 11, 2007
    713
    Bella Italia
    Dom T.
    The colouor it should be !!
  5. velocetwo
    velocetwo F1 World Champ
    Dec 11, 2006
    12,461
    Left Coast
    Color Nazi's
  6. T308
    T308 Formula 3
    1,000
    Southern Cal
    #131 T308, May 12, 2015
  7. T308
    T308 Formula 3
    1,000
    Southern Cal
    #132 T308, Jun 10, 2015
    Just one last process before mounting on the dolly. Rear suspension removal. Everything's been going very smooth save getting the bolts out of the bushings. 50 years have not been kind. Oil. Heat. Fire. Curses. Prayers. Every tool in the bag and I can't get the bolts out of the bushing sleeves. Ugh....
  8. Lowell
    Lowell Formula Junior
    Silver Subscribed Owner
    Apr 17, 2005
    886
    Santa Fe, NM
    Lowell Brown
    Did you try an air driven impact wrench?
  9. T308
    T308 Formula 3
    1,000
    Southern Cal
    I did and the nut came off nicely. However the bolt and bushing rotate together and the bolt will not budge. Repeated bashing is doing nothing but bending the carrier.
  10. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    2,714
    San Francisco Area
    John Vardanian
    T308, I might suggest a little trick I picked up while doing this, mind you under much better (read that as not rusty) conditions. If you raise the axle all the way up the upper bolts tend to come out easier, and conversely, if you lower the axle the lower bolts come out easier. Anyway, the moral of the story is you might move the axle up and down with a jack and feel to see if the strain on the bolts changes. Good luck.
    john
  11. Lowell
    Apr 17, 2005
    886
    Santa Fe, NM
    Lowell Brown
    If you want to see what I did you can go to
    Kerry's 330 GT Restoration site
    and search for
    Winter Project - Rear Suspension.
    As I recall, I removed the plate attached to the spring before I removed the radius arm.
    I have a very detailed diary and photos that I could email you if you want more information
    about what I did other than what you will find on Kerry's web site that I quoted.
  12. T308
    T308 Formula 3
    1,000
    Southern Cal
    #137 T308, Jun 12, 2015
    Thanks Lowell and John. I tried combinations of all your tricks, but the two lower bolts still did not budge and as much as I hated to do it, I cut them off. The sleeve inside the silent block had fused to the bolt so all the earth, wind and fire wasn't going to move it. Now I've got to find some replacement LOBOs.
  13. Rifledriver
    Rifledriver Two Time F1 World Champ
    26,325
    Austin TX
    Pretty common.
    Neil Young was right, rust never sleeps and the bolt and sleeve become one.
    If you want genuine Lobo bolts there was a fastener supply near Pat Ottis's shop that sold them in nearly every size under the sun. Contact him and I am sure he can direct you.
  14. John Vardanian
    Jul 1, 2004
    2,714
    San Francisco Area
    John Vardanian
    Bowlin Equipment, at the end of Tenth in Berkeley, a block up from Ottis.
    john
  15. T308
    T308 Formula 3
    1,000
    Southern Cal
    Thanks for the lead. Sadly they no longer carry the LOBO line. Apparently they've switched to SPE. Perhaps a trip to Cornaredo is in order.
  16. T308
    T308 Formula 3
    1,000
    Southern Cal
    #141 T308, Jun 22, 2015
    Leaf springs are finally off. One process that always scares the hell out of me. Something that should never be done alone, but when you must....
    The nice collection of dirt is likely equal parts Italian, Belgian, Tennessean, Floridian and Californian. It's like an theological dig.
  17. velocetwo
    Dec 11, 2006
    12,461
    Left Coast
  18. John Vardanian
    Jul 1, 2004
    2,714
    San Francisco Area
    John Vardanian
    Good work! If you do not know the routine for refitting the leaf springs make sure to ask before starting the job. You'll save yourself some pain and time.
    john
  19. T308
    T308 Formula 3
    1,000
    Southern Cal
    But sadly, not in the size required. Only smaller sizes.
  20. T308
    T308 Formula 3
    1,000
    Southern Cal
    #145 T308, Nov 29, 2015
  21. Dbacr
    Dbacr Karting
    148
    Ft lauderdale, FL
    Dan
    Nice to see you held on to the car. Great read.
  22. T308
    T308 Formula 3
    1,000
    Southern Cal
    I've been saving my pennies for ten years!
  23. George Vosburgh
    George Vosburgh F1 Rookie
    May 26, 2011
    2,759
    Pittsburgh, PA
    What happened to this project??
  24. T308
    T308 Formula 3
    1,000
    Southern Cal
    #149 T308, Feb 13, 2016
    It's coming along nicely. The engine rebuild is underway and the car's ready to go to paint and metal as soon as the slot opens up. Eleven years and counting!
  25. George Vosburgh
    May 26, 2011
    2,759
    Pittsburgh, PA
    Keep going, good luck!
