You've got me scared.. plug wire replacement | FerrariChat
Discussion in '308/328' started by Saabguy, Sep 15, 2012.
  1. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    HI all,
    so after reading countless threads on replacing plug wires it occurred to me that as long as I was going to replace the plugs the wires should go in as well. But every thread speaks to things going all pear-shaped afterword.
    Now, this isn't my first rodeo, I've replaced the wires on race cars for decades, I've replaced the wires on the E-Type with Magnecor wires. But none of them had silicone covers.
    So, other than send them to Dave, what recommendations or pitfalls to avoid come to mind?
    Thanks,
    Lester
    .. and no, I FULLY recognize that Dave is the ultimate answer but I've got to give this a shot to keep my "man card"
  2. PT 328
    PT 328 F1 Rookie
    4,004
    I purchased just the wire from Dave and rebuilt my wires myself, no issues.
  3. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,107
    E ' ' '/ F
    Snike Fingersmith
    I simply put new wire inside the existing cover, new ends, new plug extenders, done. I think I used 7mm and lubed the hell out of them, but it's been a while. I used some sort of wire-on-a-spool from the local auto parts place, no issues in several years.
  4. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,337
    Encino, Ca
    Carl T
    Ditto on buying the wire from Dave. I would add to lightly sand, 600 grit, the distributor cap screw and fitting before screwing down the new wire. Replace extenders as well.
  5. Tostapchuk
    Tostapchuk Formula Junior
    Aug 19, 2004
    278
    Connecticut
    TJO
    Don't be scared. They're only plug wires.
  6. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,786
    Marin
    Geno
    #6 Sledge4.2, Sep 15, 2012
    1) buy set taylor spirocore wires
    2) buy new extenders
    3) remove grey ends of spirocore with exacto
    4) refit wires on boot ends using dialetric grease
    5) measure and cut wire set using old wires as template
    6) clean, wire brush dist terminals, check carbon cap for wear and spring return
    7) strip small bit of end of wire and double back the inner element on itself so the set screw has two chances to pierce the element
    8) jam the end in the dist cap, using dialectric grease, and remove a little of the plastic sheathing to get in the hole, dont overtighten set screw
    9) test resistance from cap terminal ends to extender, wiggling each end to ensure solid connection
    10) install wires and go man go
  7. Saabguy
    Saabguy Formula 3
    Mar 28, 2012
    1,785
    Shreveport, LA
    Sledge,
    that was one of the numerous threads I read. I'm partial to Magnecor wires although there may be no functional difference between brands. I went with the pre-cut kit for no reason other than I didn't want to mis-measure, order, then be in trouble when I needed to get it done. Spending a few additional bucks won't make a difference over the next 20 years or so.
    My only real concern is removing the silicone covers and re-using them. Yes, I know that Magnecor offers new material if I need it but I hope to keep the original "patina".
    HAHAHAHAHAHHAAAA... sorry, I couldn't keep a straight face.. with the patina remark.. I actually think that mine are in good enough shape to re-use.
    Lester
  8. Matto
    Matto Formula 3
    Dec 26, 2011
    2,085
    Mooresville, NC USA
    Matthew
    +1 apply common sense and care....you'll be ok.
  9. thecarreaper
    thecarreaper F1 World Champ
    18,057
    Savannah
    Ive done like 6 sets with the 8 308s ive had. It aint hard guys. Do it on the couch while watching a movie. :) Hot soapy water helps to slide off the boots and red silicone covers, gets them clean too.
  10. BigTex
    79,379
    Houston, Texas
    Bubba
    You can buy the OEM sets, they come separate for each side, at about $415 each.
    Jus' sayin'........ReOriginals stocks them.
    j/k
  11. lostbowl
    lostbowl Formula 3
    Apr 30, 2009
    1,246
    Michigan
    Tom
    "man card" right on ! Lost
