Zivan Charger | FerrariChat
Zivan Charger
Discussion in '456/550/575' started by Impounder, Dec 1, 2022.
  1. Impounder
    Impounder Karting
    Aug 6, 2010
    172
    Laguna Niguel, CA
    Need guidance please. Zivan charger started blinking Green and Yellow with the Red constant. Not sure which came first but my battery ended up completely dying, 5 years old anyway. Replaced battery. Ordered a fuse for the Zivan charger thinking that was the problem but it still blinks Green an Yellow. Just to be clear this is without it being hooked up to the car.
    Any suggestions?
    Thank you
  2. tazandjan
    39,176
    zivanusa.com
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,667
    South East
    Jimmie
    Buy a CTEK or similar - many options described in previous threads
  4. Impounder
    Impounder Karting
    Aug 6, 2010
    172
    Laguna Niguel, CA
    Thank you will reach out
  5. LVP488
    LVP488 F1 Veteran
    Jan 21, 2017
    5,901
    France
    On the Maranello you still have the cut-off switch - I think it's better to use it than relying on a battery maintainer.
  6. tazandjan
    39,176
    Bad advice according to the pros. Resetting everything when not necessary is not the best plan. Plus, the switches do wear out.
    Qavion likes this.
  7. JohnnyRay
    JohnnyRay F1 Rookie
    3,621
    Central FL/NW WI
    No sir. Batteries still need a maintenance/float charge to stay healthy. They otherwise have a self discharge - in addition to any drawdown within the vehicle. AGMs perform better in this regard than conventional lead-acid - but they all need to be topped off periodically.
    Qavion likes this.
