Knocking sound on the scud | FerrariChat
Discussion in '360/430' started by rs4, Jul 6, 2011.
  1. rs4
    rs4 Karting
    Feb 6, 2010
    65
    Hong Kong
    hi,just got a 09 scud for 2 months,wow what a car!
    i heard some knocking sound came from the front suspension,dealer said it's normal and the sound do disappear for a while after dealer did some lubrication work but then came back again...
    is it really a characteristic of the scud and any way to solve it?
    thanks
  2. SfefVan
    SfefVan Guest
    Nov 28, 2008
    1,370
    Switzerland
    Stef
    My F430 had the same problem and I had to insist really a lot to get it resolved. The knocking noise came from the front swaybar which was moving between both wheels. After several attempts, they eventually fixed it by changing all link parts between the sway bars to the suspension.
  3. FerrariDublin
    FerrariDublin F1 Rookie
    Jun 14, 2009
    3,454
    Dublin, Ireland
    Greg
    Hi RS4 and welcome to F-Chat. Nice car you've landed yourself there! Well done.
    It could be as suggested above or indeed it could be wear in the lower or upper ball joints (or both) on the wishbones on either or both sides. Could also be wear of the flanbloc bushings where the wishbones connect to chassis.
    I'd be inclined to bring it on back to dealer for diagnosis and repair if you have any warranty.
    Best of luck.
  4. rs4
    rs4 Karting
    Feb 6, 2010
    65
    Hong Kong
    guess i have to try harder to have the dealer getting the job done.
    thanks again for the warm welcome!
  5. Shack
    Shack F1 Rookie
    May 2, 2005
    2,615
    Earth
    I have had this issue on my F430. Would go into dealership and come back fine. Would drive it in the rain and noise would be back next day. They said they had to re-lube the joints with a "better" lubricant that would not wash out. Have not driven in the rain since so will see whether they are correct.
    Congrats on the car - awesome choice
  6. F430GT
    F430GT Formula 3
    Sep 29, 2005
    1,300
    Marco Island, FL
    There shouldn't be any sound from a Scuderia suspension, especially a Scuderia, a car that comes with stronger suspension parts than a F430.
    Mine has no sounds. I have installed the Challenge bushings (delrin) which are noisy, but the right lubrication made them quite. The stock Scuderia bushings don't cause any sounds,, by design they are quieter than the Challenge bushings.
    - Check your sway bar lubrication at the bushings attaching to the chassis, as well as the joints with the lower wishbone, and the link between the sway bar and the drop link.
    - Check the lube on the delrin sleeves (4 of them used in the front axle) supporting the springs.
    - Re-torque the upper and lower wishbone attachments to the chassis.
    - Check for play on the upper and lower monoballs attaching to the wheel carrier.
  7. rs4
    rs4 Karting
    Feb 6, 2010
    65
    Hong Kong
    have booked the car in next week,let's what they found out this time..
    btw,the noise did come back after i drive the car in the rain,that's really strange!
  8. rcallahan
    rcallahan F1 Rookie
    Jul 15, 2002
    3,307
    Santa Barbara
    Bob Callahan
    You drive your car in the rain? How bizarre! :)
