2001 ferrari 360 f1 spider gearbox overfill | FerrariChat
Discussion in 'Australia' started by knocker, Aug 6, 2017.
  1. knocker
    knocker F1 World Champ
    11,861
    Sydney Aus
    Adrian
    hi all I had service last month gearbox oil engine oil coolant been driving car last 2 weeks got car out thismorning and small pool of clear gear oil on floor at back of car I know it could be rear gbox seal but alternatively is their a gearbox overflow on a 360
    incase of overfilling .grasping at straws any ideas cheers
  2. IanB
    IanB F1 World Champ
    Jun 15, 2006
    15,666
    I don't know 360's, but most transaxles have a breather which can drip when overfilled. Gear oil is not clear however...but it does have a strong smell.
    Is your car an F1? Very common for mechanics to top up reservoir and overfill, because the (clear) F1 flluid expands a lot with heat. If so, this is not a problem, overflow will stop when it gets to the right level.
  3. PAP 348
    PAP 348 Nine Time F1 World Champ
    Dec 10, 2005
    99,437
    Mount Isa, Australia
    Pap
    Have you considered taking the car back to the workshop that performed the work Knocker?
    Or did you perform the work yourself?
  4. GLW
    GLW Rookie
    Feb 19, 2015
    5
    Hi Knocker,
    Are you sure its not the rear engine oil sump plug leaking ( there is 2 plugs on your 360)
    the rear plug does up into an aluminium plate, there is only around 10mm of engagement - its real easy to over tighten and strip the thread. You Can view this plug thru a hole in the under tray.
  5. FazzerPorscheman
    FazzerPorscheman F1 World Champ
    Jul 28, 2010
    15,031
    Piz Gloria
    EnzoFerdinand
    If you did it yourself and you're handy with spanner scandal what not, can you come and do my belts too please. :D
  6. IanB
    IanB F1 World Champ
    Jun 15, 2006
    15,666
    ewwww
  7. Horse
    Horse Three Time F1 World Champ
    Dec 1, 2005
    34,911
    Brisvegas
    Jon
    He's cheap AND easy. ;)
  8. knocker
    11,861
    Sydney Aus
    Adrian
    Yep thanks Ian it's coming out of the actuator so hopefully rebuild seal or two ,hopefully
  9. knocker
    11,861
    Sydney Aus
    Adrian
    Will keep posted,on bit of learning curve first Ferrari 🙄
  10. knocker
    11,861
    Sydney Aus
    Adrian
    I'm shure you can service your own belts Fazzer 🐡
  11. knocker
    11,861
    Sydney Aus
    Adrian
    Thanks for the feed back Ian I appreciate it
  12. Horse
    Dec 1, 2005
    34,911
    Brisvegas
    Jon
    Hey knocker, fill in your profile; will help with recommendations.
  13. Aircon
    Aircon Ten Time F1 World Champ
    100,524
    Melbourne, Australia
    Peter
    I like knockers. Anyone else?
  14. IanB
    IanB F1 World Champ
    Jun 15, 2006
    15,666
    the F1 system is actually quite simple and reliable. The bits that fail are F1 pump, the actuator unit (rarely) and the potentiometers on the transaxle (that tell the ECU what gear the car is in). All parts common across Alfa, Lambo, etc.
    Don't be fooled into paying thousands for replacement parts, get second opinions and do online research.
    Also, change the F1 fluid every year, which can be done by using a small pump to vacuum out the reservoir. You don't need an SD2 computer reset.
  15. FazzerPorscheman
    Jul 28, 2010
    15,031
    Piz Gloria
    EnzoFerdinand
    Shame they don't like you. ;)
  16. knocker
    11,861
    Sydney Aus
    Adrian
    Cheers Ian all cleared up gear oil seeping out of a solenoid 🙄 I have a lot too learn and should listen more carefully to my mechanic but thanks all for input and ribbing I deserve it great fun cheers Knocker
  17. knocker
    11,861
    Sydney Aus
    Adrian
    Cheers Ian all of this info is gold many thanks
  18. knocker
    11,861
    Sydney Aus
    Adrian
    Thanks for input GLW all info greatly appreciated cheers Knocker
  19. Maranello550
    Maranello550 F1 World Champ
    Aug 25, 2011
    12,324
    HongKong
    Gary
    Fixed......😜
  20. Aircon
    100,524
    Peter
    ewwwwwwwwwwwwwwwwww
    Sicko!
