365 GT oil issue | FerrariChat
365 GT oil issue
Discussion in 'Vintage (thru 365 GTC4)' started by jww427, Jul 3, 2017.
  1. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Hello all!
    Im a Boxer owner and now a 365 queen owner. (sucker)
    My beloved 365 has 53K miles on it and Ive read the articles on oil burning issues.
    However, my car goes through 1 quart for every 2 hours or so of "spirited" driving.
    Is this acceptable?
    When is a top end rebuild necessary?
    Many thanks,
  2. 12659
    12659 Formula Junior
    Oct 6, 2005
    346
    Seattle WA. USA
    mark
    not acceptable. Has the car sat for some time? Do a leak down and compression test.
  3. TTR
    TTR F1 Veteran
    5,201
    Riverside, CA
    Timo
    To your knowledge, has the engine ever been completely/thoroughly rebuilt ? If not, with that mileage and apparent problem, you might want to consider doing it all and doing it right, instead of just "top end"
  4. 166&456
    166&456 Formula 3
    Jul 13, 2010
    1,723
    Amsterdam
    Could be a number of things, bad valve stem seals especially on inlet valves, can cause a lot of oil burn that is not always visible from tailpipe smoke. If the oil burn is correlated to a lot of high RPM then it could well be the rings. Are there ash deposits on the spark plugs? And is the engine otherwise leak-free? Leak-down test? These and a good number of other things to check before tearing her down.
  5. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Hi John,I would think that burning that much oil would create a significant amount of smoke.If so OK but look hard for leaks that show up when the revs are up and make sure your level is correct and your additions are not overfilling. Mike
  6. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,046
    San Francisco Area
    John Vardanian
    If you do not have a great deal of smoke, it's possible that you blow it out the crankshaft seals. Clean the engine and run it again and look for leaks.
    john
  7. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Does anyone know how many pints are represented between the MAX and MIN indicators on the dipstick?
  8. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    In a 65 mile drive the engine burned half the way down from MAX.
  9. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Sorry, US quarts, not pints!
    The manual says there is 10.56 quarts in the sump and oil cooler.
  10. 12659
    Oct 6, 2005
    346
    Seattle WA. USA
    mark
    Wow, that is excessive! something is wrong. Have you looked at the spark plugs?
  11. Streetsurfer
    Streetsurfer Formula Junior
    Dec 16, 2015
    934
    near Chicago
    Ron
  12. TTR
    TTR F1 Veteran
    5,201
    Riverside, CA
    Timo
    I'd be concerned if that much oil was consumed during 650 mile drive.
    As there's potentially numerous reasons, it's tim to quit attempting interweb analysis and start actual work to figure out what is the cause.
    And unless you have 100% confidence going through the diagnostic process yourself, find a mechanic/shop that has experience and is familiar with this type of cars/engines.
  13. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    I think you know by now that you are using too much oil. The next question would be what to do next? If it's not leaking the oil profusely then its burning it (assuming it's not it's going into the radiator) so it means rings or valves need attention.
    I would start by doing a compression and leak down test to indicate weather it's a top end or bottom end problem. Maybe you just need head work.
    My car (late 330 GTC) was using similar amounts of oil and the car was smoking like crazy, especially at idle (high vacuum). There was even oil dripping from the exhaust manifolds after shut down. When I did the tear down I expected to see very worn valve guides but it turned out to be the valve guide seals. The engine was way overdue for an overhaul anyway at 78k miles, so everything needed attention.
  14. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Thanks for the advice!
    The car has been sitting for awhile as most do.
    Not much smoke at idle, so Im guessing the top end was done at some point.
    Im going to drive it another 300 miles (adding oil) to see if consumption goes down.
    No external leaks that I can see, but on the highway if you go up to 6000 rpm and let off the throttle, there is some real smoke for sure.
    Do rings ever come back or reseal after some hard driving?
    JWW
  15. jww427
    jww427 Karting
    Oct 31, 2016
    148
    White Post Virginia
    john w. warner IV
    Would Marvels help the sticky rings?
    Any advice?
    thanks!
    JWW
  16. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    1,847
    Marvel Oil in the fuel will not hurt anything, and may help free any stuck rings. Best thing is to put some miles on it before making an expensive decision.
