Any practical way to get a testarossa on 4 jacks? | FerrariChat
Discussion in 'Boxers/TR/M' started by bpu699, Sep 12, 2017.
  1. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    16,262
    wisconsin/chicago
    bo
    want to change my tires. My lift is otherwise occupied for a 911 engine rebuild... Tire places will not do tires on a Ferrari. Tires too old to drive at highway speeds 2 hours to a dealer... Need to get loose rims to a tire shop.
    I have 4 jacks stands and two low clearance hydraulic jacks...
    For the life of me, don't see how to lift it...
    If you lift one side, you can't lift the other...
    If you lift the back, front hits the ground...
    I guess I could do one side at a time, which seems silly...
    Anyone done this? Am I missing something?
  2. ozziindaus
    ozziindaus F1 Veteran
    9,799
    Detroit
    Sam
    I hear ya.
    Here's an idea but remember to jack the fronts together along with the backs together (rear glass cracking risk). Two person job.
    Also, don't make the same mistake another member here made (rpissm) where he jacked up just to the side of the locators and bent the bodywork
  3. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    Lol yeah that really sucked. My car was already on 4 jack stands and I needed to raise it more to fit underneath there. I jacked up ghe front first using a jack on the left and jack on the right. Since the jack stand was already under the hardpoint I went just to the right on either side. I'd go up 10 turns on one side, then 10 on the other side until I noticed the buckling. Then I had to scurry back and forth lowering the jacks! 10 tyrns on each side and now I have a set of $10,000 dimples. Yes. $10,000.
  4. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,128
    Mel
  5. ago car nut
    ago car nut F1 Veteran
    5,267
    Madison Ohio
    David A.
    Above works well.
    Melvok likes this.
  6. ozziindaus
    9,799
    Detroit
    Sam
    All 4, not just the back.
  7. Melvok
    Jul 25, 2008
    14,128
    Mel
    Yes, shown above is back and front Sam :)
  8. bpu699
    Dec 9, 2003
    16,262
    wisconsin/chicago
    bo
    Ok, I like the idea with the wood blocks... But then how do you do the front? I can BARELY get a hydraulic jack under the front, with the back end flat on the ground. You lift the back 6 inches, front hits the ground. Where are you folks putting a jack in front??? Its all soft/fiberglass undercarriage/bumper.
  9. ago car nut
    5,267
    Madison Ohio
    David A.
    You have to jack the front up from the jacking points under the rockers. But do it in steps evenly. side to side.
  10. jgmblair
    jgmblair Formula Junior
    720
    Winnipeg, MB Canada
    Jeff Blair
    Bo, I just did this last week. I have a scissor lift and had the wheels off my car, I let the lift down as low as it would go and unfortunately the lift couldn't lift the car back up. I took the little scissor jack out of my daughters matrix and my wife's lexus and placed them where mel has his custom fabbed lift on the rear engine cradle. I was careful to just lift the rear of the car a few turns on each jack back and forth as to not flex the rear end and break the rear glass. Once the car was up high enough I blocked it like me l's photo then took the 2 scissor jacks and moved them to the jacking points just behind the front wheels. I told my wife i'd rub her neck if she came out to the garage and helped me for 5 minutes and she agreed ;) we just went slow and lifted the car together and ageing blocked it as Mel did. Once I had the weight off my scissor lift I was able to lift the car as usual but dumb mistake on my part. Good Luck!
  11. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
  12. wda24729
    wda24729 Formula 3
    Sep 22, 2014
    1,000
    Devon, UK
    Graham
    Glad I read this thread, didn't realise there was a risk of the window smashing if lifting the rear on one side :)
    Just to confirm, as I use a 2 post lift (4 arms), is it ok to mount under the front jacking points and on the engine cradle to the rear as far back as the lifting arms will go?
  13. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,934
    romano schwabel
    that is ok with 4 arms
  14. Melvok
    Jul 25, 2008
    14,128
    Mel
    Two hydr jacks, at the same time (or almost) ... but it works super with blocks/loggs :D
  15. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Jack stands suck.
    Consider something like this scissor.
    a mid-rise two post lift might be even better (depends on your circumstance).
    Cheers,
    Vincenzo
  16. Melvok
    Jul 25, 2008
    14,128
    Mel
    Very good solution, bur also a problem to get the TR ON it imo ?
  17. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    yes - too high for the tr without some blockage to raise the car or inset into the concrete.
    If you are sure of your concrete, a two post midrise has some advantages but also some drawbacks.
    it just depends....
    cheers,
    vincenzo
