Countach restoration tid-bits on a S2 | Page 2 | FerrariChat
Discussion in 'LamborghiniChat.com' started by randomlambo, Jan 16, 2016.
  1. Downdraft1
    Downdraft1 Formula Junior
    Nov 13, 2008
    786
    Just wondering if younpainted the calipers or had then plated
  2. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    Bear in mind ATE had a number of different period-correct finishes circa 1980, this being one of them.
  3. randomlambo
    randomlambo Formula Junior
    Feb 3, 2013
    377
    RI & MA border
    DT
    These were powdercoated but the intent was to achieve closer to the plating color. It may be a little too 'rich' looking (plating is usually more subtle) but in reality it's very close.
    We chose this because of assumed increased durability.
  4. ilconservatore
    ilconservatore F1 Veteran
    May 18, 2009
    8,369
    Cincinnati Ohio
    #29 ilconservatore, Mar 22, 2016
    I don't know if this was changed on later cars, but earlier engines had exhaust studs that threaded into the block, and headers were attached with tall brass nuts.
  5. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    Indeed, plating will tarnish, powder-coating wont.
  6. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    Thank you - we're using these nuts for the header-to-muffler connections but did not use them on the block. I will check to see original disassembly pictures and check.
  7. Downdraft1
    Nov 13, 2008
    786
    Your thread convinced me to do the same. I am changing all the seals in the master cylender and the brake hoses. Will detail the suspensions and repaint the calipers. Found this Lights 4 Speed - Accessori e ricambi MINI e BMW
    Thanks for the motivation!
  8. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    So I'm at the point of looking for tires for my car. I have P7s on there which are old (not the original ones, heh) and which make the car look really good as has been discussed on other forums here.
    Since the PZeros are the only matched replacement set that one can buy...
    For the rear the option is clear = 345/35-15
    For the front - My car has 205/50-15 but I see other cars have used 225/50-15? I think later cars use the 225 is that correct? Is there a difference on the stance with the P7 vs PZero 205s? I want to stay with the original intended side-wall thickness of the 205/50 but the P7 was more ...bulbous... whereas the PZero appears more rectangular/square shaped in terms of the cross-section.
    What say you Countach experts?
  9. I would go with the 205.
  10. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    #35 randomlambo, Jul 1, 2016
    Fiamm airbox covers re-done with the silkscreen printing on them, rather than stickers...
    Can anybody confirm whether these were matte, satin, or glossy?
  11. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    These were satin for the LP400S.
  12. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    #37 randomlambo, Jul 11, 2016
    Moving along...front all done and all electrical parts verified working.
    All the oil and water-systems were tested for pressure (within reason) - most important were the two oil lines going to the front cooler; they are a **** to take off and put back in.
  13. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    #38 randomlambo, Jul 11, 2016
  14. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    #39 joe sackey, Jul 11, 2016
  15. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    #40 joe sackey, Jul 11, 2016
  16. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    Joe -- impeccable as always...
    Is it a chrome finish?
  17. joe sackey
    Sponsor
    May 23, 2006
    57,331
    Southern California
    Joe Sackey
    I believe that's a chrome plating, the original done by the supplier was very brittle, I'm confident what we did will last the next generation and still look nice.
  18. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    #43 randomlambo, Jul 12, 2016
    Here's a up the butt shot...
    Quick question for the experts - were there any notes on the alignment of the check marks on the springs?
  19. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    I think those paint marks are only for identify correct springs for car model and separate front and rear, as they are sometimes easy to mix. (do correct if I am wrong)
  20. EMILIO
    EMILIO F1 Veteran
    Feb 23, 2006
    6,852
    Italia
    nice!
    can we see a pic of the complete car? VIN?
  21. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    The shop that redid the springs got the correct color paint marks on all of them but when we put them back on the car there was no particular attention given to the orientation of the paint marks...that's what I'm looking to find.
  22. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    #47 randomlambo, Aug 24, 2016
    Looking for an opinion here -- for a car restored to original would you consider wrapping the exhaust with the heat blanket wrap such as the one in this picture? It would not be original but would help with the heat in the bay?
  23. randomlambo
    Feb 3, 2013
    377
    RI & MA border
    DT
    #48 randomlambo, Aug 24, 2016
  24. Hard to say. I had my headers ceramic coated, which helped some. Wrapping might have been better. The heat reflecting material does a great job. Usability wise it's a good idea. Purist wise, I don't know. Both are going to be hard to see. Myself, I couldn't discount a car that was actually better to use in this regard. Pebble beach or judging, maybe not such a good idea. Ask yourself if you see selling the car in the near future, if not and your going to enjoy it - then consider it seriously.
  25. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    4,012
    Switzerland
    Raymond S.
    This helps really to lower the cabin temperature, GLA12997 and DLA12662 have it, huge difference!
