Countach Technical Thread & Questions
Discussion in 'LamborghiniChat.com' started by jollygood, Mar 18, 2013.
  1. I have started the new week 1 FerrariChat Update poll, please vote... http://www.ferrarichat.com/forum/threads/ferrarichat-com-update-week-1-poll.560487/
  1. Ellagirl
    Ellagirl Formula 3
    Aug 20, 2014
    1,293
    Florida
    Nils johnsen
    Yes, thanks. Thats it. I did install it once in the car ,easy plugg in and bracket fits good but the car did not shut off when you turned off the key,i later recieved diode from my dealer wich is supose to avoid the alternator to backfeed to the ignition box after the key is turned off,i did not find a plug anywhere to fit the connections the diode kit came with.car sounded good but kinda hard to pull the coil wire every time you shut the car down, do you know if the system is any better than the original? And also where do you conn the diod the easyest to make the car turn off on the key?or is there perhaps another reason the car does not shut off. Very thankful for all help,would like to install the new box if it is in fact any better,my existing ignition works fine so far,but stil would like to try the new one.
  2. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    2,722
    Sequim
    Michael Wilson
    #202 Jalpa_Mike, Oct 8, 2014
    Nils,
    Lamborghini addressed this "run on" problem in Technical bulletin #004 back on June 24th 1988.
    Here is a copy of the 2 pages:
  3. Ellagirl
    Ellagirl Formula 3
    Aug 20, 2014
    1,293
    Florida
    Nils johnsen
    Thanks !i did recieve the same two pages from Lamborghine with my diod kit, have not being able to find the connectors in the wire harness anywhere, there is only the big red pos cble coming inn from the alternator to a common terminal,from there it feeds in to a relay box in the left side rear compartmnt in the taillight section. The box contains fan and ignition nd start relay, perhaps Lamborgini expects you to find suitable place for the diod where there is acces to the right wire,but there is no plug anywhere to be found that connects to the plug /diod kit. Did the Canadien guy run in to the same problem?
  4. Chadbourn Bolles
    Chadbourn Bolles Formula Junior
    457
    Leesville, SC USA
    Chadbourn Bolles
    Next time you get ready to run car, try this. Disconnect the switch wire at the Alt. Start car, then shut it off. If it shuts off, then place the Diode in that wire.
    Chadbourn Bolles
    803 532 6257
    email: Lamborghinionly@yahoo.com
  5. Peter K.
    Peter K. F1 Rookie
    3,871
    Connecticut
    Peter K.
    #205 Peter K., Oct 9, 2014
    I don't remember posting this picture of my car. Where did you see it?
  6. amc
    amc Karting
    Apr 9, 2009
    191
    old school
    Countach thread... or some restoration thread in this forum.
  7. Tired of seeing this ad? Upgrade now
  8. johnghini
    johnghini Karting
    66
    #207 johnghini, Oct 21, 2014
    Can anyone confirm whether the areas I highlighted have the black sealant in their seams? In short, I cannot tell whether the horizontal "rocker panel" seam that runs into both the front and rear flares should have the sealant. Seems some cars have it the complete distance, while others have it on the flares only...or none at all. I am finishing up the car and need to know! Car I am referring to is a US QV (1986).
    Thx!
  9. godabitibi
    godabitibi F1 Veteran
    5,861
    La Sarre, Quebec, Ca
    Claude Laforest
    #208 godabitibi, Oct 21, 2014
    From a car I believe was on original paint. 87 US.
  10. tbakowsky
    tbakowsky F1 World Champ
    Professional Ferrari Technician Consultant
    Sep 18, 2002
    12,167
    The Cold North
    Howie Felterbum
    I know that car..
  11. jgoodman
    jgoodman F1 Rookie
    2,738
    Central PA
    Jay Goodman
    Anyone have the part number for the windshield washer fluid reservior? Any part cross links for other cars? Just noticed that mine won't hold fluid. Thanks in advance.
  12. gurslo
    gurslo Formula 3
    Feb 25, 2008
    1,490
    Connecticut
    Peter
    Would a "3D printer" work it's magic for a project of this sort?
  13. EarlyCat
    EarlyCat Moderator
    Moderator
    Mar 9, 2005
    4,162
    Kentucky
    Joey
    Get the part number actually on it & Google it. It is probably a Fiat or Alfa part.
  14. Tired of seeing this ad? Upgrade now
  15. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
  16. jgoodman
    jgoodman F1 Rookie
    2,738
    Central PA
    Jay Goodman
  17. SupercarGuru
    SupercarGuru F1 Rookie
    Sponsor
    Dec 14, 2003
    3,060
    Fl
    John Temerian
    I cannot find the owners manual on my 1987 car... And cannot find where to check the oil?? I know this sounds absurd... Am I blind??
  18. Redlambo
    Redlambo Formula Junior
    867
    Pendergrass GA
    Vic Woloschinow
    #216 Redlambo, Oct 23, 2014
    This should help.
  19. 2NA
    2NA F1 World Champ
    Professional Ferrari Technician Consultant Owner
    Dec 29, 2006
    17,438
    Twin Cities
    Tim Keseluk
    Even when you know where to look, sometimes it's a mystery.
  20. Chadbourn Bolles
    457
    Leesville, SC USA
    Chadbourn Bolles
    #218 Chadbourn Bolles, Oct 27, 2014
  21. Peter K.
    Peter K. F1 Rookie
    3,871
    Connecticut
    Peter K.
  22. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    2,802
    Switzerland
    Raymond S.
    #1121228, of my friend, Vortex charger
  23. EarlyCat
    EarlyCat Moderator
    Moderator
    Mar 9, 2005
    4,162
    Kentucky
    Joey
    Amazing work!
  24. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    #222 Jalpa_Mike, Nov 15, 2014
    Rebuilding the water pump on my 5000QV.
    Here are all the old components laid out. Just ordered new seal, bearing, hoses, snap clips, etc. from GT Car Parts.
    Also having the water pump cover re-welded. At some point in the cars history, someone must have broken the cover and welded it (note all the red silicone gasket sealer on it). So, I took it to a proper machine shop (the same folks who have done Jon Shirley's Pebble Beach winning Ferrari 375MM). They'll weld a new flange on it and machine it properly.
  25. islandguy
    islandguy Formula 3
    1,209
    Northern CA & NV
    Looks good Mike. Was it giving you trouble or just on your list of things to do?
  26. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    Yes, it started leaking.
  27. EarlyCat
    EarlyCat Moderator
    Moderator
    Mar 9, 2005
    4,162
    Kentucky
    Joey
    I will be rebuilding mine soon. I've already rebuilt mine twice over 8 plus years. One catch is the seal must be pushed on, evenly, or it will leak immediately. The perfect "tool" to press the seal, is the plastic top of a bug bomb like you would get at Home Depot. Did you get the packing slip with the parts? A Ferrari seal.
  28. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    Joey:
    I'm still waiting for the parts to arrive from Bill @ GT Car Parts.
    The water pump cover won't be ready for 2 weeks, so I'm not in a hurry for the parts... Yet
  29. jollygood
    jollygood Formula 3
    1,066
    jollygood
    Would you have a parts list for rebuilding water pump, for future reference?
  30. Countachqv
    Countachqv Formula 3
    2,140
    USA/France
    a stupid question: what are the torque specs of the countach oil plug and differential plug?
    i forgot and cant find it in my docs
  31. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    #229 Jalpa_Mike, Nov 22, 2014
    I'll put together a list of all the parts that I am replacing. They are starting to trickle in.
    First is the new water pump drive shaft. Here is a shot of the old and new side-by-side. Not hard to see why mine was leaking! The seal had failed exposing the spring inside the rubber seal and allowing it to rub for who knows how long against the shaft. It was also heavily pitted, rusted, etc.
  32. Chadbourn Bolles
    457
    Leesville, SC USA
    Chadbourn Bolles
    The looks of the shaft have nothing to do with the seal leaking. There are 2 places the pump will leak, 1 the seal fails, and 2 the bore where the seal fits, is not as smooth as glass, allowing leakage past the OD of the seal.
    You just paid several hundred dollars to have a pretty water pump shaft.
    Chadbourn Bolles
    803 532 6257
  33. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    Chad:
    The seal was ripped wide open. The spring inside the seal had been dragging on the shaft and caused a groove to form. Water was on it for quite some time as the area where the seal rides is rusted and pitted. It was a cheap $200 to spend for piece of mind.
    Mile
  34. EarlyCat
    EarlyCat Moderator
    Moderator
    Mar 9, 2005
    4,162
    Kentucky
    Joey
    I'm curious Chad, or anyone, if you put anything on the seal (for coating, protecting, or lubricating) when you put it together?
  35. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    Joey:
    I've heard a couple of folks recommend the same lubricant that is used for o-rings and pump seals on submerged pond pumps.
    I think Chad has recommended the same. Maybe he'll jump and let us know if that is true.
    Like Chad has stated, the big area of concern is the pump body where the seal is at. If not perfect, water will just creep right past it.
  36. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    17,438
    Twin Cities
    Tim Keseluk
    The new shaft looks good and there's nothing wrong with using new parts but I agree with Chad. The seal normally never touches the shaft. It seals between the housing and the back surface of the impeller. As long as the shaft is straight and the impeller spins true, it shouldn't leak, until the crummy seal fails again. Frequently the housing gets corroded where the seal fits. I've filled the pits with JB Weld with some success. The most important part of Lamborghini water pump maintenance is making sure the weep hole stays open so you know when it's time to do it all again.
  37. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    #235 Jalpa_Mike, Nov 23, 2014
    Since I can't post multiple images from my iPad, here are 2 images of my failed seal.
    It was very dry and brittle. Note in the one photo, how the seal actually looks twisted where it is suppose to seal against the pump.
    The other photo shows how the seal was broken into 2 pieces. The spring you see on the inside of the seal was dragging on the pump shaft and put a groove in it.
  38. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    #236 Jalpa_Mike, Nov 23, 2014
    2nd photo
  39. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    2,802
    Switzerland
    Raymond S.
  40. EarlyCat
    EarlyCat Moderator
    Moderator
    Mar 9, 2005
    4,162
    Kentucky
    Joey
    #238 EarlyCat, Nov 28, 2014
    This came with mine.
  41. Countachqv
    2,140
    USA/France
    I had my oil analyzed and got the results. For motor, differential and transaxle. It seems that all passed with flying colors as I was a bit worried at passed 30k kms and never any serious rebuild on anything.
    Doing this it seems I busted the myth of changing the oil too frequently even if you dont put a lots of miles.
    but more important is the transaxle oil and differential oil.They were in there for quite some time and dont exude any component wear at all. that was a very happy report. That said blackstone does not have a lot of comps for the countach and they base their opinion and summary on other similar cars.
    Has anyone done this and if so we could exchange info here or in private if that is better suited for someone.
    I'd like to trade reports and numbers so we can do real countach comps.
  42. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    #240 Jalpa_Mike, Dec 4, 2014
    First piece completed on the water pump.
    Previous owner had tried to fix the cracked water pump cover with silicone, etc.
    This is what it looks like when a professional does it!
    Beautiful craftsmanship!
  43. raymondQV
    raymondQV F1 Rookie
    Aug 22, 2007
    2,802
    Switzerland
    Raymond S.
  44. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
  45. islandguy
    islandguy Formula 3
    1,209
    Northern CA & NV
    I had a onetime occurrence yesterday that I can’t get to repeat:
    A loud high pitch buzz/hum coming from the left side front near the AC fan and horn. Sounded like the door open buzzer but 10 times louder.
    Any Thoughts?
  46. jollygood
    jollygood Formula 3
    1,066
    jollygood
    Were you driving the car? Speedometer cable!
  47. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    Also, check either of the 2 little fans on the condensor. When the bearings go, they sound awful!!! I had to replace one of mine!
    However, fear not. It's the same thing and it's used on a FIAT X1/9. They are pretty cheap, however kind of a bugger to get out!
  48. islandguy
    islandguy Formula 3
    1,209
    Northern CA & NV
    Car was parked, idling. Turned the ignition off then back on and surprisingly the noise was gone.
    I'll check those out. Thanks for correcting me. When I said AC fan I should have said condenser fan(s). Doesn't sound like a fun job.
  49. Jalpa_Mike
    2,722
    Sequim
    Michael Wilson
    #247 Jalpa_Mike, Dec 8, 2014
  50. Ellagirl
    Ellagirl Formula 3
    Aug 20, 2014
    1,293
    Florida
    Nils johnsen
    Any experience out there regarding removing the smog/air pump an a 88 fi qv,other than a lot less clutter in the engine compartement? Any negatives i need to know? Or should it be left the way it is. Any info is greatly appreciated.thanks
  51. vaholtorf
    vaholtorf Formula 3
    1,068
    Colorado
    Victor Holtorf
    I recommend removing it. It doesn't even operate except at idle, to clean up the exhaust for the then-mandated emissions limits at idle. It is easy to remove, and it is also easy to reinstall at a later date if desired. It's removal does clean the engine bay up, and sames a little weight too!
  52. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,528
    maryland
    I would remove it also. Cleans up the engine bay nicely. Just keep the entire set up for the next person. You will just have to buy 12 caps to cap the disconnected tubes from the exaust manifolds. If you need to know what size they are, let me know. I can dig thru my notes.
