Yellow fuel hose | FerrariChat
Yellow fuel hose
Discussion in 'Vintage (thru 365 GTC4)' started by Bob Zambelli, Mar 3, 2016.
  1. Bob Zambelli
    Bob Zambelli F1 Rookie
    Nov 3, 2003
    3,498
    Manning, SC
    Robert G. Zambelli
    Who sells the yellow fuel hose used in vintage Ferraris?
    Bob Z.
  2. 375+
    375+ F1 World Champ
    12,069
    You might try Re-Originals in Texas.
  3. Edward 96GTS
    Edward 96GTS F1 Veteran
    9,311
    neil at newcoproducts.com
  4. jimmyr
    jimmyr Formula Junior
    Oct 10, 2004
    288
    Scottsdale, AZ
    Jim
    GT Parts in Phoenix.
  5. steve meltzer
    steve meltzer Formula 3
    Sep 18, 2004
    1,046
    with Enzo 8995
    #5 steve meltzer, Mar 6, 2016
    I'm with Jimmy Myr...GT car parts in Phoenix. Always great service and fast shipping. Seem fairly priced. I think Bill is the owner, but I've usually dealt with Dave D. and have had excellent service from him. steve
  6. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    Hi Bob, Jeff at Partsource also carries the hose. There is not much price difference between all the sources mentioned but there may be availability differences. I also like the guys in Arizona.
    If you are replacing original hose you will need to deal with the ferrules because the new hose has a slightly larger OD. See all the answers to your questions at our favorite dirty fingernail site.
    I also learned a simple valuable lesson about making up new hoses. When cutting the new hose to length I was paranoid about ending up too short at assembly so I added about 1/2" to 1" inch to be safe, figuring I could just bend it a little when I installed it. My plan didn't work out so well because the hose is very stiff and was difficult to twist and bend, especially between the gas tank and filter at the rear. Strive to make your new hoses exactly the same length as the old ones or do a dry fit with a similar less expensive rubber hose. At about 10 bucks an INCH, mistakes could be costly.
    Tom in SoCal.
  7. steve meltzer
    Sep 18, 2004
    1,046
    with Enzo 8995
    I just carefully measured my old hose, and they made a new one the exact same length. My old ferrules just screwed right on and the only battle, as Tom said, was getting installed at the tank. It's a bit tough, even with the correct length. s
  8. Bob Zambelli
    Nov 3, 2003
    3,498
    Manning, SC
    Robert G. Zambelli
    Hi, Gents - Good information.
    I only have to replace the three hoses in the engine compartment.
    Partsource is the way to go.
    Ferrules are no problem. If unavailable, I can make them.
    Again, thanks.
    Bob Z.
  9. todaxyz
    todaxyz Karting
    Jul 16, 2009
    133
    Nor Cal
    Tom
    Mine need replacement too and was going to have my local shop tackle the job. But from these posts, it seems like anyone with some amount of DIY skills should be able to do this. Is it really that straight forward or are their risks with leaks and such if your not regularly dealing with such things?
    Tom
  10. gtospoons
    gtospoons Karting
    Jun 16, 2011
    105
    Suffolk, UK
    Chris Withers
    Bob
    GTO Engineering in UK (and now LA) will give you exactly the correct hoses and all other associated items.
    Chris
  11. Lowell
    Lowell Formula 3
    Apr 17, 2005
    1,165
    Santa Fe, NM
    Lowell Brown
    I have adjusted valves, installed new bushing everywhere on the
    rear suspension, etc.
    The new hoses have a larger ID than the OD of the old ferrules.
    I bought new hoses of the correct length with the ferrules installed.
    Even so, they required some tweaking (twisting and turning) before
    they finally stopped leaking.
  12. Jumprun
    Jumprun Karting
    Feb 7, 2012
    227
    Southern California
    T. Martinez
    I assembled mine with anerobic Loctite 518, no leaks. I used my original thicker steel Ferrules by running an expander into them but it's easier to find and use replacements.
    Coincidently, just this week I discovered my brown spiral oil hose is leaking. I should have replaced that one while doing the fuel lines but at least I know the drill. Getting it out looks difficult, especially where it enters the firewall.
    Tom in SoCal.
