89 328GTS foam insulation air hose? | FerrariChat
Discussion in '308/328' started by Jackmb1, Sep 12, 2007.
  1. Jackmb1
    Jackmb1 F1 Rookie
    Dec 27, 2005
    3,329
    Does anyone know where I could get a Ferrari foam insulation air hose for a 89 328GTS?
  2. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,294
    Colorado
    Dave
    They are hard to come by. I would suggest calling dealers around the country hoping someone has one in old stock.
    Dave
  3. Mule
    Mule F1 Rookie Owner Rossa Subscribed
    Jun 25, 2003
    3,758
    Alaska
    Mule
  4. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    I am pretty sure they are no longer available.
    That being the case mine met with a roll of black duck tape a year or so back. You either do something like that or investigate the aftermarket alternatives.
    I.
  5. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Perth West Australia
    Tony
  6. Jdubbya
    Jdubbya The $10 Trillion Man Silver Subscribed
    Dec 28, 2003
    43,200
    PNW
  7. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    No, the foam covered air ducts are peculiar to the 89 cars ( I think earlier cars have different ducts) and they run from the side vents to the air cleaner and the oil cooler. Damn silly things, the foam covering just falls apart.
    The one you have there is the one that feeds up to the throttle body.
    I.
  8. Jdubbya
    Dec 28, 2003
    43,200
    PNW
    Gotcha, it's not mine I just happened to see it. Good luck on the search!!
  9. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Tony
    I dont think they are made anymore and fall to bits any way mine had no foam left in it at all, Plus the one I installed is only about $30-$40 US.......check my link couple of posts back Tone
  10. 4redude
    4redude Formula Junior
    Jan 13, 2005
    732
    Fungus Corner
    Brian Keegan
    Those hoses haven't been available in years. Get the fiber/woven looking intake hose off a wrecked 348 or 355. It is designed to withstand the heat and is the same diameter. It is "wrinkled" in places to make the bends without kinking so take some measurements to make sure you have the length OK.
  11. Jackmb1
    Jackmb1 F1 Rookie
    Dec 27, 2005
    3,329
    Thanks everyone for your input. I'll have to look for an aftermarket solution.
  12. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    This is what I did (McMaster-Carr). My opinion is that it looks much better than orange hose.
  13. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
  14. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    I should add that I have not run the engine yet with this hose so I don't know how heat-resistant it is. I think it will be okay but..... Also, I am leaving out the passenger's side fuel tank and the A/C compressor so I don't know if there would be any clearance issues with the tank in place or with the compressor. Doesn't look like it but............
  15. Jackmb1
    Jackmb1 F1 Rookie
    Dec 27, 2005
    3,329
    Let us know how that works for you. Thanks
  16. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    Will do. It will probably be a few more weeks until I'm able to run the engine. I'm finishing a Major + and Electromotive install on it. Hasn't been run for a year now :-( If you don't hear back from me then send a reminder. I'll might be too excited, once I can drive it again, to remember :)
  17. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Tony
    Now I know how to fix at door vent end.....I strugled by hand and fit trunking without being able to clamp it, it has stayed on so far but now it is clear what has to come off for correct fixing etc Thanks for the photo. Tone
  18. TK 328
    TK 328 Karting
    Dec 24, 2006
    167
    Tony
  19. mike
    mike Formula Junior
    Nov 2, 2003
    721
    Colorado
    I too know it's not available.. about a year ago I called a Ferrari Dealer, looking for the rubber accordian (intake) connection for my '86 328. They had one but of course we bagan talking about the foam hose on the later 328's..
    So my question is; can you put an earlier model intake?. and completely get away from the aftermarket stuff & heat resistant issues?
  20. Mule
    Jun 25, 2003
    3,758
    Alaska
    Mule
    If you had enough money and skill, I am sure that you could make the older style work. I do not know for sure, but I do not think it is a direct bolt on replacement.
    As far as heat resistance, my snazzy orange hose is rated from -80 to 500 degrees. It will outlast the car.
