328 Alternator Removal Procedure | FerrariChat
Discussion in 'Technical Q&A' started by btemplin, Jul 17, 2004.
  1. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    Does anyone have a detailed procedure for removing the alternator from a 328? I saw some procedures in the parts & service section for checking the alternator belt tension, and replacing that belt. But I'm thinking there's more that needs to be done to get the alternator out of the car. If anyone could direct me to this procedure, or has it written up and could send it to me, I would very much appreciate it.
    Thanks,
    Brian
  2. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,303
    Ventura, California
    Robert Garven
    Brian,
    I cant speak for a 328 but on the 308, you:
    *take lots of digital images!!!!!!!
    *unhook battery neg cable
    *drain coolant
    *remove coolant pipe in front of alt
    *loosen slack and remove belt
    *remove alt adj. hardware
    *remove nut holding alt (on mine you have to remove dipstick first)
    * put a piece of cardboard on exhaust and set the alt. on it
    *detach electrical cables from starter
    *carefully remove (on the gt4 there is a heat shield that is easier to remove if it is taken off first)
  3. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Sorry to see your post so late, but here's a pretty complete alternator removal procedure i wrote up in the old Fchat archives:
    http://www.ferrarichat.com/discus/messages/112/316950.html
    I always pull the alt mounting bracket instead of removing the pivot bolt from the alt. Lots quicker & easier, & you can't get the alt out with it in.
    BTW, I welded a short piece of ~1/4" steel rod to the alt bolt heads when I had it out. Now the alt bolts can be loostened by just turning the nuts from the front. Takes longer to drain the coolant down & get the pipe out of the way than it does to remove the alt!
    You do have to twist the alt around until you get just the right orientation before it'll come out thru the opening.
    BTW, please DO NOT start a new thread just because you're not getting answers to an existing one.
    Just post a quick 'please help' to your original thread.
  4. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    re: Message [qoute=btemplin]"I have removed the lower mounting bracket from the block. Removed the vent cover from the rear of the alt. Disconnected the wiring from the alt. But I can't find a position that will let me get between the gas tank and the crank pulley. "
    [/quote]
    The alt removal write-up linked to by the preceding post was based upon my experiences with a 308 QV. However, the 308 & 328 engines are extremely close, & I'm pretty sure both use the same BOSCH alternator, so I know of no reason for removal to be different.
    I remember having to rotate the alternator into a funny orientation before I could get it out.
    Hmm, is there a heat shield under the alternator that runs along the top of the exhaust manifold extension along the frame?
    If so, I think it may have to be loosened so it drops down against the manifold, or maybe even removed.
    Will try to keep a close eye on this thread in case you have further questions.
  5. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    Yes, it is a Bosch alt.
    I removed the heat shield from under the alt. early on in this process. There is another small heat shield over the top of the exhaust, directly under the crank pulley. However, one of the two nuts holding it in place is not accessible without removing the exhaust.
    I'll see if I can take some pics later and post them.
    308 & 328 engines are pretty close. I'm beginning to wonder if maybe the gas tank is larger, or shaped differently on the 328, thus causing my problem.
  6. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Hmm,
    Try standing the alternator up on end, then angle it sideways over the crank pulley & against the gas tank & see if it will come out.
    Yes, we could be dealing with a 308-328 gas tank difference, but it's never come up before.
  7. Ferrari_tech
    Ferrari_tech Formula 3
    Jul 28, 2003
    1,527
    Malcolm W
    btemplin / Verell
    Gas tanks are the same for both 308 / 328 so the alternator should come through - might have to jack up the engine a little though.
  8. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    I may have it. Is the problem that your alt is too long to come out because of the large Al cast cover on the back? The cover I'm thinking of covers the back of the alt & has a flexible tube attached so it picks up air from below the car.
    If so then you'll need to remove the cover. Turn the alternator around & you can get at the bolts that are holding it on.
    I retrofitted a cover to my 308 last time I had it out, but I can't remember if I had to install it after I got my alternator into place.
  9. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    #9 btemplin, Jul 22, 2004
    I have removed the back cover from the alt. Still won't come out. It's too wide. No way it will get between gas tank & crank pulley. And can't go up at all with it since the A/C belt and compressor are there. See pics...
    I have stood it on both ends, tilted it, tried sideways, and backwards. There's just not enough room. No one mentioned unbolting the A/C and moving it out of the way. Maybe that's just a given and I didn't get it. Wow is this frustrating!!!
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    This is strange, It looks just like the same area in 308s.
    The alt comes out thru the gap either nose or tail end first & (I think) angled slightly upwards.
    The A/C belts, etc. are close but not a problem.
    Hmm, I don't remember that large bolt & metal boss on the compressor's lower left corner. Is hitting it part of your problem? Is it part of the mounting bracket? If so, could you take a couple of pix that includes your compressor & it's mounting bracket?
    The 308 compressor is most commonly an Italian built version of the YORK #206 piston compressor used in the 328s. There are a few (supposedly minor) differences in the cases tho. Possibly the 328 compressor is taller & extends downward further & closes things up.
    Can you see the mfg's name & # on the compressor?
    If the compressor has to come out, I can walk you thru it.
  11. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    This is strange, It looks like the same area in 308s.
    The alt comes out thru the gap either nose or tail end first. The pivot point has to be tilted just right to fit in a gap. Possibly the triangular one between the crank damper & the exhaust/heat shield.
    The A/C belts, etc. are close but not a problem in the 308.
    Hmm, I don't remember that large bolt & metal boss on the compressor's lower left corner. Is hitting it part of your problem? Is it part of the compressor mounting bracket? If so, could you take a couple of pix that includes your compressor & the mounting bracket?
    The 308 compressor is most commonly an Italian built version of the YORK (now CCI) #206R piston compressor used in the 328s. There are a few (supposedly minor) differences in the cases tho. Possibly the 328 compressor is taller & extends downward further & closes things up.
    Or else they've redone the compressor mounting bracket.
  12. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    #12 btemplin, Jul 22, 2004
    Here are some better pics of the A/C and it's mount. I could not see a name on the A/C, at least not from the angles I viewed it from. The A/C belt is not helping anything, but even if it were loosened or removed, it wouldn't make enough difference.
    I did an eyeball measurement of the gap between the tank and pulley, by holding the back cover of the alt. up to it. The diameter of the alt. is ~2 inches greater than the width of the gap. And the depth of the alt. (front to back) is even larger than its' diameter. So there is no way it can fit thru there.
    It looks more and more like the compressor has to move (a lot) to make way. I really didn't think I'd have to go this far...
  13. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Here's how to remove a YORK style (piston) A/C compressor:
    (CAVEAT: I haven't done this in a couple of years, so I may
    have forgotten something.)
    Special tools:
    A Thin, flat 17mm(i think) ratcheting wrench really speeds things up.
    (GearWrench reversable wrench) , or a thin CRAFTSMAN Stainless, Lifetime,
    or Professional Thin Profile 3/8" ratchet w/a short socket).
    0) Disconnect the 2 wires for the compressor's electrical clutch. They are up near the dipstick tube.
    1) Remove the A/C belt tensioner, leaving the belt in place.
    2) Loosten, but don't remove the lower compressor mounting bracket.
    3) Drop the compressor out of the upper mounting bracket as follows:
    The compressor is held to the upper bracket by 3 studs which have pairs of tapered rubber grommets on them.
    The upper bracket has double tapered holes that are sandwiched by the rubber grommets.
    The grommets will have washers on them, so watch out that they don't get lost once things start to move.
    The studs provide a course adjustment of the tension on the A/C compressor belt.
    Look at the top of the upper bracket & notice how far the studs protrude past the end of the nuts.
    (A couple of pictures would be a good idea) so you can leave a similar protrusion when re-installing.
    - Using a thin ratcheting wrench (or a combination wrench wrench & a lot of
    patience) remove the 3 nuts from the studs.
    Unfortunately, there isn't a lot of clearance between the top of the upper bracket & the body,
    hence the need for a low profile ratcheting wrench.
    - Remove the flat washers that s/b under the nuts.
    - Remove the 3 upper rubber grommets from the upper bracket. (You may have to wiggle the compressor a bit
    to break the grommets free from the studs).
    At this point, the compressor is being held in place by the lower bracket & the studs & lower grommets.
    4) Remove the lower mounting bracket while supporting the compressor so It can't drop suddenly.
    At this point, the compressor should drop down out of the upper bracket, but most likely the lower grommets
    are stuck to the studs & the holes in the bottom of the upper bracket. You should be able to break them free
    by shoving the compressor back & fourth.
    5) Slip the compressor out of place. You can support it by draping the hoses over the top of the fuel tank,
    or by hanging it with wire from something sturdy.
    Installation is the reverse of this procedure.
  14. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    Thanks for all the guidance so far. Unfortunately, I gave up the fight last night. After removing the lower A/C bracket, and the A/C belt, there still was not enough room to get the alt. out. Once I got to that point, it was not clear that removing the A/C compressor from the upper backet would have made enough room either. So I've reached the limit of what I'm willing to dismantle. I'll be calling a towing service this week to have the car taken to the mechanic I usually use. It's really disappointing to not have been able to finish the job. But it's not obvious what the next step needs to be. So it's time for someone with more tools and more skills to take over.
    Thanks again for the support!
    Brian
  15. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    You're welcome.
    Sorry we couldn't figure out why the engine is so close to the gas tank on your car. (Or if the alternator case is oversize...)
  16. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    OK...I may try 1 more thing before calling the tow truck.
    I think (90% sure) that if I remove the crank pulley, then the alt. will come out.
    Do you know if the pulley will come right off simply by removing the (very large) bolt? Or do you need to dislodge it in some special way from the damper even after removing the bolt?? Is the pulley keyed such that there is only one way to put it back on after taking it off???
  17. BigTex
    79,380
    Houston, Texas
    Bubba
    Did you note UK Tech's suggestion to drop the engine mounting bolts and raise the motor slightly?
    That would be easier than pulling the crank pulley IMO.
  18. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    Actually, I hadn't gone searching for the engine mounts yet. Are they easily accessible? How much lift could I expect to get by doing that? 'Cause I would need probably 2-3 inches to make any difference.
  19. BigTex
    79,380
    Houston, Texas
    Bubba
    I raised mine an inch or two once to get the front header off.
    I don't think I'd go for that much though! Any one else?
    I can get my 308 unit out just as you are trying to do....this is very strange....
  20. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    The crank damper is just held on by the large bolt on the end. You'll need an air wrench to break it loose tho.
    It's aligned with a single large woodruff key, so alignment isn't a concern. You may need a large brass or copper punch or hammer to align the key for reinstallation tho.
    The end of the crank the damper sits on is cylindrical. My damper came off pretty smoothly once I had the bolt out.
    I think I've read that the 328 front engine mounts are different from the 308 mounts, so I can't help you with them.
  21. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    Is there any chance the crank pulley bolt is reverse thread? Before I get into this thing any further, I want to make sure that CCW is loosen not tighten.
  22. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    I'm slowly making progress. Used an impact wrench to remove the crank pulley bolt. But now I can't get the pulley off. It won't budge. Suggestions?
  23. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Get a large pulley/gear puller. Most rental places will have them.
    Also AutoZone will rent or loan tools. If it doesn't break it loose pretty easily, protect the bolt hole/threads on the end of the crank by either put the bolt back in, or put a large nut on the end to press against.
    Put a block of wood against the front of the sump & pry with a wonder bar.
    Just be careful to not bend the sump/timing cover. (I'm reluctant to suggest this as you have to have a really good feel for how much force is likely to be safe.)
    Man, this project is fighting you all the way!
  24. btemplin
    btemplin Rookie
    Dec 17, 2003
    39
    Houston, TX
    Brian Templin
    WAHOO! It's out!!
    Pulley/gear puller got the job done. With that off, and the lower A/C mounting bracket removed, there was JUST enough room to get the alt. out. BUt it was still darn close. The alt. mounting bracket studs sticking out of the block are the nemesis. I had to turn the alt. just right to get between the studs and the gas tank.
    Hopefully I'll get the alt. to a rebuild shop today, and be reassembling by the weekend.
    Thanks for the help so far. I'm sure I'll need more assistance once I start putting it all back together though.
    Brian
