Questions on timing chains vs. timing belts, TIA. | FerrariChat
Discussion in 'Technical Q&A' started by Tifoso1, Sep 26, 2005.
  1. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    After reading most of the threads on the issues of timing chains and belts, I came to the conclusion of the following, please correct me if I am wrong on any of them, TIA:
    1) Chains are milage dependent, unlike belts, which have a time reference as well. Thus in a non-everyday car, a belt engine will probably reach the time criteria sooner than the milage criteria, hence higher maintenance. However, belts are cheaper than chains when they both calls for replacement.
    1a) Most cars will require seals around the engines to be replaced around 80K miles or so, which on average, takes about 6-7 years. Hence in theory, timing belts will be replaced at the same time, in these cases, belt engines does not really require extra care.
    2) Chains are stronger than belts(??), but if a timing-belt engine has been keeped properly, the failure rate is about the same.
    2a) In case of cars that sits for an extended amount of time, chains will be more likely to break due to lack of lubrication before belts will lose its shape and in term, causes failures.
    3) Engines with belts are quiter, and has a lower power loss than chained engines, thus more effection from this stand point.
    4) Timing Chain engines are more compact (shorter) but does require a source for lubrication. Thus, more moving parts and more stuff that can potentially go wrong if the system fails.
    Please add more pros and cons of each if you know of any. Also, why did car manufactures go from chains to belts in the first place (I am assuming that chains were used before belts.) and more specifically, in case of Ferraris. Again, TIA.
  2. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    If it moves, anything is mileage dependent.
    But you have a couple things round the wrong way, sorta. Taken in order:
    1.) Belts are mileage dependent too. They just wont run forever. Seeing many MB cars have gone past 300K miles on original chain's, I would guess the chains win. However, not all chains are created equal. Notice many Ferrari have three row chains. Very robust.
    2.) I believe the failure rate on belts far exceeds any chain driven cars, on cars that exceed thier mileage limits, old American V8 technology notwithstanding.
    3.) On cars that sit a lot, it seems the belts take a set and accelerates the deterioration of the belt. Cars that sit dont instantly start rusting, so again, the chain will win.
    4.) Chain driven engines may be a tad bit shorter, but except for the actual links and pins that make up the chain itself, I dont think there are really any more parts per se.
    So why a belt? Its my belief and understanding, that it was first used in racing. Ferrai jumped onto it, as well as a lot of racing engine designs, purely for a performance reason, not a durability reason. The belt is way lighter compared to a chain. For the same reason you would get a lighter flywheel, or lighter rods, pistons, or valves, the belt carries and requires less inertia.
    Think of trying to accelerate the timing system from idle. Every gram of weight extra is weight the engine has to move to accelerate. This is why we had plastic timing cogs with small diameters, and belts. It will not make more HP, but it will accelerate faster.
  3. Rifledriver
    37,367
    1 Yes
    1a No
    2 Maybe
    2a No. Where did that come from?
    3 Yes but close to a draw
    4 Length dependant on design. Yes
    Answers predicated on subject being modern motors, a comparison of new belt drive and new chain drive, not the chain drive that dates back to the 30's as installed on the 166, 275,365 etc.
  4. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    Same reason as you would want to manually "pump" some oil in within the engine after the car has been sitting for an extended amount of time (I don't mean weeks, but months to years). Oil will drain, even in a dry sump system, and leave metal against metal at startup. Thus at startup, it is when an engine takes on most abuse with greatest friction and least amount of lubrication. Does the same rule not apply to chains? Will oil not drain away and leave the top part of the chain dry of oil, thus at startup, would it not creat a point of stress thus result in greater chance of breaking? TIA.
  5. Rifledriver
    37,367
    I suppose as an intellectual exercise, yes.
    I have seen motors started that had been sitting for decades, poss 20 years and the chain did not break. In other words it is a complete non issue.
    Every thing else in the motor will be junk before the chain is a problem.
  6. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    My 1972 Lotus has a timing chain. It's the original one and will last the life of the car. It is never considered a normal service item. The only thing we DO service is the chain tensioner. It does reach the end of its travel eventually and is replaced/repaired. This too may never happen in one's lifetime however.
    The key is on an engine rebuild to have the tension correct to begin with. My chain is lubricated with engine oil so once set, not a lot can go wrong. In all the years of Europa ownership and being in a Europa group, I have never heard of a chain breaking either first, second or third hand. I hope I'm not jinxing myself!
    Ken
  7. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    All things being equal, chain (and gear) driven engines are also infinitely less prone to oil leakage. A chain driven DOHC has 1/4 the seals of a belt driven one. In addition, the gaskets in general are a lot less complicated on a sealed drive system. There are just less places to leak, plain and simple.
    A blanket statement, but chains deal with lack of tension a lot better than belts as well. The teeth are significantly taller (as a ratio of chain width) than in a belt, which generally uses short, wide teeth.
  8. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    According to the replies I am getting here, is it safe to conclude then that the only advantage of a belt-driven system over chain-driven system is purely performance, which is a direct result of less power loss with belt-driven engines? TIA
  9. Steve B
    Steve B Formula Junior
    Dec 23, 2003
    521
    Naperville
    Steven L. Biagini
    They are also quieter and allow for a simpler (and less expensive) casting of the block.
  10. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    I don't know how massive of a chain Lotus uses, but chains do wear, and stretch. Usually, the stretch is taken car of through the tensioner, and generally, when the tensioner has reached its limit, the chain should be replaced. If a chain breaks, it can as much or far more damage than a belt would ever do, because it can wind up on the lower sprocket and break the block.
  11. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Kenneth
    My car is only a 1.6L engine that's really detuned from its top potential as a race engine, so it's not stressed very much at all in street configuration. You are correct that when the tensioner is at the end of the travel the chain is replaced; I'm not aware of anyone ever having done this (from wear as opposed to rust or deterioration) on a Lotus Twin Cam engine. Even the assembly manual says this is unlikely to ever happen.
    Ken
  12. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,637
    The Brickyard
    The Bad Guy
    Well all I have to say is that my truck has over 184,000 miles on it and the chain is still running strong. Yet I had to put a new timing belt in my 348 at 56k miles. I doubt you will ever see a timing belt that can go 200,000 miles, or more, before it needs to get changed.
    Chains win.
  13. Tifoso1
    Tifoso1 F1 Rookie
    Nov 18, 2003
    2,606
    Pacific NW
    Anthony C.
    While that may be true, but there are plenty of cars out there with a recommended belt replacement at 100,000 miles or so, and with most engines, some type of oil leak, major or minor, will probably develop by then and need an engine out service to replace the seals anyway.
  14. Erich
    Erich Formula 3
    Sep 9, 2003
    1,190
    Poway CA
    Erich Coiner
    belts are cheaper to manufacture than chain.
    This is the reason there are so many Toyotas and other econoboxes that run belts.
    Erich
  15. scorpion
    scorpion Formula Junior
    Jan 19, 2004
    469
    Kentucky
    Excluding Ferrari's which we all know leak - I have never had an engine out service because of leaky seals - what would you drive that would make you think 100,000 miles is time to pull the engine? My hauler Pathfinder has 130,000 miles, I have owned two z cars with 100,000+ miles an Infiniti with 85,000 miles (I know it's not 100,00 but close enough) and NEVER pulled an engine to replace seals.
  16. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Now hold on here guys. Yes, belts are cheaper, but that is NOT why Ferrari used them. They used them for a performance reason, everyone else used them because it was cheaper engineering and cheaper parts. Do you see small diameter belt sprockets on Jap cars, or any other car made in the world? No.
    Regarding engine out service. If you owned a Lola, or a Can Am car, or perhaps a Ford GT-40, one that had a race motor, or perhaps a 288 GTO, or a F-40, you would be pulling that motor out after every weekend and freshening it up. I don't know about today, but not many years back, track driven hotted up street motors were generally torn down after 20 hours, or after any long endurance race. Why? to protect your investment. You dont want to wait till it blows apart, you want to salvage all the internals and the block. Racing engines many times do not operate at the speeds your Ferrari does in every day use! Take your Honda out and crank it to 8K rpm all day, week after week and see how long it stays together. These Ferrari are not Hondas, and were never meant to be. They are race cars that are "detuned" to be street driven, PERIOD. Our belt change requirements are in keeping with a hard driven track car. I guess if some of you dont like maintaining a race car, you should maybe buy something else.
  17. spider348
    spider348 Formula 3
    Nov 3, 2003
    1,275
    MA
    Krowbar, I like your passion for all things Ferrari but….
    The Honda S2000 does wind to 8k and beyond all day.
    Please pardon my somewhat skeptical attitude toward Ferrari but look at the situation from a pure business perspective.
    1. Belts are cheaper to produce. Reduce production cost/ increase profit on the front end.
    2. Belts in Ferraris require unusually high maintenance costs. Increase profit on the back end. An evergreen revenue stream!
    Not a bad business model!
  18. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    As I understand it belts are more efficient than chains, but chains are more reliable.
    Interestingly the new motor in the F430 has reverted to chains.
  19. Rifledriver
    37,367
    All new motor designs since F50 are chain drive.
  20. Fred2
    Fred2 F1 World Champ
    18,359
    nj
    Japanese motorcycles use chain drive, and rev to where no street based car can even think of going to.
    The chains last as long as the motor does.
  21. 208 GT4
    208 GT4 Formula 3
    Dec 27, 2003
    1,769
    Brighton (UK)
    Dan
    Would it be right to say that a tensioner problem is more likely to cause a toothed belt to jump than a chain & sprocket setup?
  22. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    #22 Dave, Sep 27, 2005
  23. Rifledriver
    37,367
    No. Ford twin cam and Dino V6's just to name 2 were famous for tensioner slippage that caused blowups. Also Maserati/Citroen V6's
  24. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Seriously, lets not compare apples to watermelons here. You ever seen the cam drive chain in a motorcyle engine? Most are smaller links, shorter in length, than on a bicycle. I doubt that tiny little chain weighs anymore than a belt for a 308. And further, motorcyle engines, because they are designed for high rpm torque, have very light crankshafts that would never hold up to pushing a car around, as well as thier light weight cams. Oh, and those little chains inside motorcycles break too.
    I would assume, that with all the yelling Ferrari owners are doing over belt replacement and maintainance, and seeing as Ferrari is working harder to satisfy customers, everyone probably got what they asked for, a glorified Honda, instead of something more cutting edge. Because in the giant scheme of things, when Ferrari was one of the first F1 teams to go to belts on a F1 car, I doubt it was to save money. I also doubt they were trying to save money on 308's, 348's, 288's, F-40's, or 355's, by using a belt, they used belts because it made better power. I would also make the assumption, that Ferrari went with chains on the F-50 because it was worth the power loss compared to damaging 5 valve per cylinder V-12 heads in the event a belt broke. Everything in life is a compromise somewhere, no matter if its boats, cars or airplanes. Would the belt on a Ferrari last 100K? Maybe. Is it worth it? I guess that depends on what its worth to own a Ferrari
  25. Huskerbill
    Huskerbill F1 Rookie
    Sep 6, 2004
    4,126
    Oconomowoc, WI
    Bill
    I WISH my car ran on a chain. My fear of the catastrophic event would be reduced by 50%.
    And my enjoyment would go up 200%.
    I would trade 20 HP for a chain. THAT is how much the belts on these cars scare me.
