attaching headlight (perspex) covers - Queen/Dino | FerrariChat
Discussion in '206/246' started by Bryanp, Oct 19, 2005.
  1. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,822
    Santa Fe, NM
    I'm going to take the Queen out of commission after thanksgiving for a bunch of issues that need addressing, partially so I'm at least presentable for the FCA National in my backyard next year.
    One item I'm going to do is the installation of the headlight covers that were an option on euro spec cars. Does anyone have detail photos showing period-correct attachments for these? I've seen two types; the simple L-shaped clip where one leg is screwed to the body and the other to the lens. The other I've seen for the front-most connection is a screw going through the lens and then though a ferrule-spacer and into the body - the ferrule is sometimes painted to match the body; other times it has been polished.
    and another technical issue - the Queen/Dino type headlight covers are not sealed to the body - so they need to be removed once in a while to clean whatever minute road junk has gotten inside the void. With that in mind, I do not think a self-tapping metal screw would be the advisable fastener. I think you would want a nut welded or epoxied (I don't want a complete nose repaint) to the back-side of the body metal to receive a bolt, not a screw.
    Does anyone have any detail shots of the headlight covers on any of the DeRethy 330 Speciales? Given their rarity, they probably still have their original fastener-types and are very close in time to my very early Queen.
    thanks in advance.
  2. Bob Zambelli
    Bob Zambelli F1 Rookie
    3,655
    Manning, SC
    Robert G. Zambelli
    #2 Bob Zambelli, Oct 19, 2005
    Bryan - I faced the same problem when doing my friend's DINO.
    I fabricated small brackets from 1/16" stainless steel and attached them to the inside of the headlight cutouts. Then I drilled and tapped the brackets for #8 machine screws.
    All hardware is stainless steel and I used nylon washers under the screw heads at the plastic.
    The job looks perfect, if I may say so!
    Bob Zambelli
  3. BigTex
    79,379
    Houston, Texas
    Bubba
    Napolis used a similar detail on the P4 resto.........no pics left here but maybe in resto section at "dash talk"......
    Bob Z.'s tapping of the clip would seem the way to go........
    George Vosburgh likes this.
  4. xs10shl
    xs10shl Formula 3
    Dec 17, 2003
    2,037
    San Francisco
    #4 xs10shl, Oct 19, 2005
  5. drew365
    drew365 Formula Junior
    Jun 22, 2004
    252
    The Valley, L.A.
    Andy Ritter
    My car is not a Eurospec but did have headlight covers on when I bought it. They were attatched with L brackets. A car wash managed to crack one while doing a detail, so I took them off. I bought a pair that apparently are for a 275 and are too big for my car. I've thought about cutting them down but have never gotten around to it. California regulations prohibit covers that are not sealed so I doubt I'll ever put them back on. Bryan, where did you find them to fit your car? There is a picture of my car with the covers on page 17 of the book "Forty Years of Ferrari V-12 Engines by W.E. Gasich if you have the book.
  6. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,822
    Santa Fe, NM
    jeez, that's quite the attachment detail on the California!
    Drew, I got mine on ebay and they are a tad big. I will have to spend a bunch of time sanding them down to the right profile.
    Bob, do you have any close-up pics, or can you get them?
  7. Tabletcounter
    Tabletcounter Karting
    Apr 30, 2005
    161
    Cheshire UK
  8. Bob Zambelli
    3,655
    Manning, SC
    Robert G. Zambelli
    I plan to convert my 330 GTC to covered headlights, possibly this winter.
    I like the photos of John's Dino - very clean.
    It's also similar to the setup on my Deutto except that it had external clamps.
    In fact, I may try and modify the GTC to accept Duetto covers - that would be perfect.
    Bob Z.
  9. Tabletcounter
    Apr 30, 2005
    161
    Cheshire UK
    You took your dino through a car wash!!!
    landpirate likes this.
  10. andrewg
    andrewg F1 Rookie
    4,667
    Chester, England
    AndrewG
    They look like the original UK spec fitings (weren't the headlight covers a delete option in the UK rather than a cost option?)
  11. dgrperformance
    dgrperformance Formula Junior
    Feb 28, 2005
    311
    Oceanside, CA
  12. Bryanp
    Bryanp F1 Rookie
    Aug 13, 2002
    3,822
    Santa Fe, NM
  13. dinogts
    dinogts Formula 3
    I'm still looking for Dino headlight covers. Any sources for them?
    Mark
  14. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  15. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  16. dinogts
    dinogts Formula 3
    Thanks!!! Anyone here ever bought and installed these? If so, how did they fit?
    Mark
  17. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    I thought maybe I would put headlight covers on the 72 Euro Dino I'm working on now. I bought a set from Brandoli and they are way oversize, not just a little. Has anyone used the covers from Brandoli? I was also going to make a chrome ring for them.
  18. 2GT
    2GT Formula 3
    Aug 25, 2008
    1,842
    Western NY
    Fred
    Jon, when Bob Zambelli did the Brandoli covers on my former Dino (post #2 above), he cut them down gradually with a dremel tool. It was very tedious work, and consumed several hours. The results, however, were well worth the effort. Fred
  19. daviekj
    daviekj Formula Junior
    486
    I bought a pair of Superformance Perspex covers (not Brandoli) around 2005. Each was approx 10mm oversize all the way around. Made a cardboard template as a guide. Mounted an abrasive wheel (probably something like 80 grit) in a pillar drill, and gradually worked my way down with lots of test checks.
  20. omgjon
    omgjon F1 Rookie
    3,569
    Spicewood, Texas
    Jon Gunderson
    Brandoli way bigger than 10mm all around.
  21. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    Jon, I love the Brandoli covers. I believe they are the same shape and curvature as on the original Scaglietti covers. A thin chrome trim would be beautiful. Once you have the lenses fitted you can experiment with thin chrome design tape to get the desired thickness.
  22. swift53
    swift53 F1 Veteran
    8,285
    E.S.
    Alberto
    I had the same issue with a Duetto. Installed a rivet nut under the bolt and it worked like a charm.
    If interested, I can post photos.
    How where the UK Dino covers, originally installed in the UK?
    Regards, Alberto
  23. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,798
    Southern California
    UK/Maranello Concessionaires lenses were made from flat plexi so don’t visually continue the fender form the way of the original Scaglietti/Brandoli (3D shaped). Here’s a set I believe were installed by MC.
  24. racerboy9
    racerboy9 F1 Rookie
    2,645
    While they look cool it looks like they would eventually rub on the paint and collect dust and condensation on the inside. Is this not a problem for those that have them installed?
