328 16inch wheels fit on Mondial with 390s? | FerrariChat
Discussion in 'Mondial' started by LouB747, Jun 23, 2009.
  1. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Huntington Beach, CA
    Lou Boyer
    Found a set of 16 inch 328 wheels that look exactly the same as my current 390's on my 86 Mondial. Do you guys know if these will fit straight onto my car without any modifications? I'm running out of tread on my 390's and figure it's time to upgrade to 16's. How much would you pay for 328 "16's"? Thanks so much, Lou
  2. 350HPMondial
    350HPMondial F1 Veteran Silver Subscribed
    Feb 1, 2002
    5,325
    Edwardo
    Nope,,, you need ABS wheels from a 1988 1/2 model year 328.
  3. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    How do I know if the wheels I'm looking at are "ABS wheels from 88 1/2 or later? I have an 86 Mondial Cab that has the 390's. Pic attached of my wheels. Like the look of these, just want a bit more common size...........thanks......Lou
  4. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    I got a set off of a mondial T for my 82 Mondi qv, straight fit and choice of tyres, transformed the car!
  5. BigTex
    BigTex Seven Time F1 World Champ Owner Rossa Subscribed
    Dec 6, 2002
    79,380
    Houston, Texas
    Bubba
    Convex shape markes ABS wheels.........I hesitated to answer, but I thought the Mondial offset was different from the GTB/S....
  6. BigTex
    Dec 6, 2002
    79,380
    Houston, Texas
    Bubba
    It IS worthwhile to leave the 390mm "experiment" in the past...LOL!
  7. 350HPMondial
    Feb 1, 2002
    5,325
    Edwardo
    Lou,
    I like the looks of your wheels too.
    And, the Ferrari 16" Convex wheels, will look exactly like the ones you have now.
    I got my 16" wheels off of a Mondial T,,, see.
    Ciao,
    Edwardo
  8. birddog
    birddog Formula Junior
    Jun 24, 2006
    415
    Illinois
    Ed
    The first thread below explains a little of the Mondial wheel issue. Your best bet is to find '87-'88 Mondial 16" wheels. After that, you could check if Mondial T wheels would fit - but my dealer and T Rutlands both indicated that they would not. (I think I asked Ricambi too - but not sure.) I hear there are guys on here that have made it work though.
    As for the 328 wheels, see the second thread below. If you're going to go with 328 wheels, go for the convex - or what some call "ABS" wheels (although some pre-ABS cars had them too.) Again, check the fittment with someone in the know - as you may need spacers or different bolts to use 328 wheels. 348 wheels definitely require different bolts, but there are other threads on that.
    If you can find '87 or '88 Mondial 16" wheels they use the same bolts and fit right up. Best of luck, and please post what you find out as this is a common topic of discussion.
    http://www.ferrarichat.com/forum/showthread.php?t=240305&highlight=mondial+wheel
    http://www.ferrarichat.com/forum/showthread.php?t=212386&highlight=convex
  9. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    Here's a pic of the ones I'm looking at.....
    Details I've gotten are"
    7 J 16 for front and 8 J 16 for the rears
    Tires are 205/55/15 adn 225/50/16 respectively
    Bolt pattern: 5 X 4.25
    Tire is the picture has quite a few weights attached....does this indicate somethings wrong with it?
    The rest are fine.
    Again, thanks for all the help with this...........Lou
  10. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,320
    That's an 88.5/89 ABS wheel
    Re wheel weights, they need taking off & putting on the inside of the wheel for a start. It might be that if you rotate the tyre on the rim a bit it will need far less weight. If not its not the end of the world. More important is to check the age of the tyre(s) if you plan to use them
  11. LouB747
    LouB747 Formula 3
    Apr 8, 2009
    2,123
    Lou Boyer
    Any idea what a good price would be for a set with tires? Can't tell if I'm getting a deal or getting robbed!!!
  12. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    Yep some experiments work and others.............................:)
  13. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    these are the same as the ones I got off of ebay about four years ago. straight fit and only tyre choice is down to you.
  14. birddog
    Jun 24, 2006
    415
    Illinois
    Ed
    Honestly, I'd say the going price for a set that needs no paint or repair seems to be about $2,000. Others will chime in, but that seemed like the going rate to me while I was actively looking over the past three years. I was lucky enough to get mine recently for less - which you may also be able to as well. If you can do better than 2k I'd say you got a decent deal.
    As far as the wheel weights - mine have a ton of weights on them too, and they were installed by a very reputable Ferrari dealer. (My 390 wheels with TRX's on them that is.) Some tires and wheels just need a little more help to balance - and wheel weights may be required on either or both the inside and outside of the wheel.
  15. 350HPMondial
    Feb 1, 2002
    5,325
    Edwardo
  16. 350HPMondial
    Feb 1, 2002
    5,325
    Edwardo
    Half price,
    $ 815.00 usa
