355 O2 sensors | FerrariChat
355 O2 sensors
Discussion in '348/355' started by mpodgor, Aug 8, 2011.
  1. mpodgor
    mpodgor Formula Junior
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    I'm replacing my cats and think I will put in new 02 sensors to be safe. Can someone tell me the Bosch Part numbers. I found a 13819 & 13820 doing some research. I'm wondering which is the pre-cat and which is downstream? Are these good P/N's?
    Thanks in advance.
    1999 F355 Motronic 5.2
  2. Chris Honeywell
    Chris Honeywell Karting
    Nov 11, 2007
    98
    Trowbridge UK
    Chris Honeywell
    Here you go m8
    def the right part numbers as i fitted 2 new ones on my 355 (5.2)
    I only changed the front ones though bought them via ebay (gen bosch)
    just under £70 each inc postage although i see your not in the UK
    Front O2 sensors : 0 258 003 819
    rear O2 sensor : 0 258 003 820
  3. Chris Honeywell
    Nov 11, 2007
    98
    Trowbridge UK
    Chris Honeywell
    Oh genuine Bosch plug straight in so the new ones i fitted are exactly the same as the ones i took out.
    If you go NGK route then you have to cut the plugs off and splice the wires.
  4. Future ferrari collector
    Oct 12, 2006
    1,795
    Chris, would these part numbers be the same for the 2.7 cars?
    Thanks in advance.
  5. WATSON
    23,926
    WI
    Just did mine a week or so ago.....
    Pre Cat: Bosch 13819
    Post Cat: Bosch 13820
  6. roadracer311
    roadracer311 Formula 3
    May 6, 2009
    2,398
    San Francisco
    Paul
    Good to know! I've always assumed that there would be splicing involved if I changed mine.
  7. mpodgor
    Aug 15, 2005
    661
    San Mateo, Ca.
    Michael J Podgorski
    I was 98% sure that was the deal. Thanks for confirming it.
