01336 USA Prototype | Page 4 | FerrariChat
01336 USA Prototype
Discussion in '206/246' started by omgjon, Jul 19, 2021.
  1. V12addict
    V12addict Formula Junior
    Jan 2, 2004
    293
    Thank you for the tip, but i just wonder why is it almost impossible to find a shop that has a " hot seem weld" the way the factory used to do it. Plus sometimes finding the material itself is hard and not easy to match.
  2. racerboy9
    racerboy9 F1 Rookie
    2,524
    I think Henk and others have the materials. The heat stitching is the tough part. The trouble is getting someone to do one or two at a time. If you were doing a bunch at one time someone might be interested.
  3. V12addict
    Jan 2, 2004
    293
    Thank you, i will look into Henk. And yes, none of the upholstery shops in my area wanted to or could do the heat stitching probably because of cost or time involved.
  4. JL350
    JL350 Karting
    Jan 20, 2013
    205
    If the material is vinyl, I believe the welding method is ultrasonic and uses dies for the process which is going to be expensive for small numbers of parts if the tooling has to be fabricated. Is leather wrapping an alternative solution?
    V12addict likes this.
  5. V12addict
    Jan 2, 2004
    293
    Thank you for the info, and yes that could be an option. I have also looked at Alcantara which looks great but not original in older cars. Newer Ferraris are using then extensively for headliner, sun visors and seats.
  6. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
    Thanks Jon. Sorry for the delayed reply. Glad to see that you are still at it.
    Assuming that I wish to keep the same material, it's tricky cutting the edge with a razor blade and re-sewing. Once open (with the razor cut) it's easy to remove and replace the foam. The sewing such that it doesn't buckle and look tacky, that's the challenge. What alternative material? And how to cut to proper shape?
    Jim
  7. jselevan
    jselevan Formula 3
    Nov 2, 2003
    1,873
  8. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
  9. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
  10. racerboy9
    racerboy9 F1 Rookie
    2,524
    John, where are you having your cad plating done in Texas?
  11. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    I had some done at Texas Precision Plating near Dallas and I took 35 pounds of parts to my plater in LA b&c plating. I was flying to San Diego to visit the grandkids so I decided to fill my suitcase and while in LA making a stop at Philippis French dip sandwich shop!!
    Face76 likes this.
  12. racerboy9
    racerboy9 F1 Rookie
    2,524
    I was going to send a large batch to Burbank Plating. Do you still recommend them?
  13. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    I like B&C plating in LA, highly recommended! I've used them for 15 years!
  14. swift53
    swift53 F1 Veteran
    6,744
    E.S.
    Alberto
    Hello Jim, good to know you are still active! It has been a long time...
    Kind regards, Alberto
    TonyL likes this.
  15. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,839
    Norfolk - UK
    Tony
    Yes, i was getting concerned too.
  16. dhalter
    dhalter Karting
    Aug 2, 2009
    128
    New York
    Darryl
    Amazing work as always! I am at disassembly stage of full suspension rebuild on 308GT4 15406. What coatings are you applying to the a-arms and the rear aluminum uprights / bearing carriers? Thanks!!!
  17. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    I powdercoat the A-arms and use cerakote on the hubs.
  18. russh
    russh Karting
    139
    Northern California
    Russell Hazarian
    Hi John, Your work is just fantastic. I looked at the B&C Plating cadmium information and it indicates class(thickness) and type. I was wondering what cadmium thickness and type you recommend.
  19. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    Class 1 is clear cad and type 2 is yellow cad. Thickness is .002 to.004
  20. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    It's been 4 months since I received the Dino at the shop. Yesterday I loaded it on the trailer for a 45 minute drive to Color House of Texas for paint and body. I knew TJ the owner of Color House of Texas when I had my shop in Escondido, California. TJ worked up the street at Best of Show and recently relocated to Texas and opened his own paint shop. His work is top quality and the Dino will be painted with Glasurit in its original Rosso Dino color. I expect to get it back in about 3 months when I'll be ready for reassembly. Most of the parts and interior are done. I'm setting up an area for my upholstery guy who will come out when I'm ready to sew and install the carpeting, headliner etc. The carpet, headliner and dask material came from Henk at HVL in the Netherlands. The motor is dissembled and in progress.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login View attachment 3241720 View attachment 3241721 Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    of2worlds, -K1-, JCR and 2 others like this.
  21. Mwbowman
    Mwbowman Rookie
    Jul 2, 2021
    4
    Michael bowman
    I got to go down to Austin to visit my car last week. Jon is a most gracious host and his new shop is really top notch, complete with F1 simulator! The parts that are restored look brand new and the bodywork is amazing. The Dino body is so beautiful!!! That's what hooked me in the 1st place.
    Can't wait to see it after paint!
  22. Skippr1999
    Skippr1999 F1 Rookie
    4,216
    John,
    Beautiful work. Out of curiosity, what is the approximate cost to do a restoration of this caliber? If you don’t want to put it out there publicly, just send a DM.
    thanks,
    Skipp
  23. omgjon
    omgjon F1 Rookie
    3,542
    Spicewood, Texas
    Jon Gunderson
    I believe Henk now does heat stitching.
