07 599 TPMS not calibrated | Page 2 | FerrariChat
Discussion in '612/599' started by nakrulz, Jul 17, 2010.
  1. cmparrenzo
    cmparrenzo F1 Rookie
    Mar 3, 2002
    2,686
    Kansas
    Chris Parr
    Recently, I have had to calibrate my 599 EVERY time I get in it. What a pain! Next time it goes to the dealer to figure it out.
    Sometimes I may have to re-calibrate it 2 or three times before it takes. If I wait a few minutes before I calibrate it, I usually only have to do it once.
  2. tazandjan
    38,083
    Chris- Those sensor batteries only last 5-8 years, so you could have one on the edge of going out. Dealer can check individual battery life with an SD3 or MODIS.
    Note they also work better at higher pressures, so if winter has lowered your tire pressures, that could be a potential cause.
  3. Condor Man
    Condor Man F1 Rookie
    4,857
    Los Angeles
    Thanks Guys,
    I will give this a go and hopefully it works.
  4. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    #29 ar4me, Nov 23, 2013
    Had the new HUF sensors from TPMS Direct mounted in my new 20" "challenge" wheels at the local tire store, mounted wheels on car, paired/re-calibrated sensors, worked like a charm - life is good with some F-time in the sun after a few days of showers :)
  5. Condor Man
    4,857
    Los Angeles
    So I get in the car today and drive it for the first time after a collected the car from the dealer and surprise, surprise! The TPMS are working and for the first time in the ownership that stupide light doesn't come on when I start the car!
    Hooray!!
  6. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,377
    Weston, MA
    Paul
    Oh you poor baby, you had a few days of showers. TRY 4 MONTHS OF WINTER! :D
    Hey Christmas came early. No more gifts for you!
  7. ModificatoUK
    ModificatoUK Rookie
    May 9, 2016
    47
    My 2008 car just had exactly this happen.
    Batteries are not able to be replaced so four new units required and then need - linking to the TPMS ECU
  8. tazandjan
    38,083
    There are two ways to calibrate, but the owner as laid out above, or with an SD3 or similar tool by the dealer. The latter does it all with no drive required.
  9. ModificatoUK
    ModificatoUK Rookie
    May 9, 2016
    47
    My TPMS system lost its new sensors after a while. We have had them reset on SD3 but I await another loss of contact.
    There is also an ECU and antenna in the system so could also be that
  10. ModificatoUK
    ModificatoUK Rookie
    May 9, 2016
    47
  11. ModificatoUK
    ModificatoUK Rookie
    May 9, 2016
    47
    My new sensors lost their link with the system yet again. Next step will be to investigate the ECU.
    The error message is TPMS system failure
  12. Licht
    Licht Karting
    Aug 2, 2009
    81
    LA
    OP just saved me a trip to Ferrari service... love Fchat!
  13. 360Marnix
    360Marnix Formula Junior
    Jan 4, 2017
    490
    Holland
    I mounted a new set of wheels last week on my 612. I bought 4 Autel MX tpms sensors. €32 each. Programming them took less then 30 seconds. Works great.
  14. rmfurzeland
    rmfurzeland Formula Junior
    Jan 7, 2005
    554
    Houston, TX
    Ron Furzeland
    anyone know where the 599 TPMS antenna box is mounted somewhere by the front wheel (left side), I think mine is faulty, maybe picture from workshop manual (oh, if only I had one)
    Thanks,
    Ron
  15. TrojanFan
    TrojanFan F1 Rookie
    Nov 17, 2008
    4,902
    So. CA & NV
    Peter
    Ron, im having problems with mine on my 612 (different thread). If you just wsnt to see approxinately where the ecu is located you can look at the parts diagram on the Ricambi website. Unfortunately they list the ecuvas unavailable. I see some shops in Europe have it ranging frombaround $350-$1000. Im hoping that the same part is used on some non-exotic for less $$$. I dont know if my ecu is bad but I replaced all of the wheel sensors about 18 months ago.
