On 2 occasions, after a cold start my 612 OTO was way down on power but ran smoothly. A restart fixed the issue. I'm guessing only one bank was running. Any explanation?
I’ve had that once. I put it down to not waiting for the Check OK dash message before firing up. Sent from my iPhone using Tapatalk
I'll bet you are right. In both cases I was in a hurry to get going. Patience is a virtue!! Thank you... Any other thoughts?
Have the injectors cleaned and resealed with Viton o-rings. You could have leaking/dripping injectors. Three of mine were dripping (7.1.1 575M).
Hi Does anyone know how to remove the LED window and/or dismantle the steering wheel on a 599. The first LED is not working so want to explore options as to how to fix it without replacing the entire steering wheel. I know it is only cosmetic but these sort of thing annoy me.
