10-15 minute warm up is a must! | Page 4 | FerrariChat
Discussion in '348/355' started by Dave rocks, Sep 19, 2013.
  1. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Steve, try a 15 minute idle and let me know your thoughts - one time will certainly not hurt your car - as for your marriage, well I can't speak for that ;-)
  2. tazandjan
    39,318
    Dave- I have an F1 and no way is she going to waste time and gas with a 15 minute warm-up. As soon as the high idle comes down (time varies with temperature), she is ready to go and is driven gently with revs below 4000 (like the OM says) until oil temperature reaches 70C/158F. Then cleared hot because all the parts are warmed up, not just the lumps attached to the engine.
    If your F1 system is not working well when cold, suggest you have your techs flush and bleed the system and put in new synthetic automatic transmission fluid meeting Dexron III standards, which is what the recommended Shell Donax TX is.
    Early F1 systems, through the early 612, have no recommendation for F1 system fluid change. Ferrari learned over the years, however, and on the 599 began recommending every 3 years for a complete F1 fluid change. Just like there is no recommendation in your maintenance schedule for a coolant change, but most (hopefully all) of us change it every 2-3 years, some (like Brian Crall) annually.
  3. plugzit
    plugzit F1 Veteran
    7,794
    Redondo Beach, CA
    Bruce Bogart
    Is the f1 pump operating the whole time of warm-up?
    If not, how does the fluid "warm"?
    Alternatively, what is warming in the f1 system where warmth is important?
  4. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Terry, I plan to change my fluid annually w/ Redline. My fluids where changed a year ago (252 miles before I bought the car) w/ the last major.
    You have a 355 F1?
  5. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Bruce, my assumption (yes, assumption) is that it's the oil in the gearbox getting warm, the hydraulic oil in the F1 system should not matter unless it is really cold.
  6. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    In case some of you missed Monte's reply...
  7. Steve355F1
    Steve355F1 F1 World Champ
    Aug 26, 2011
    17,184
    Adelaide, South Aust
    Steve
    Fair enough Dave. I'll try that next time my wife isn't home to complain about the pong!
    I do sympathise with you about the title of this thread. I suspect you'd change it if you could...
    I think it's important to do whatever works for you, and ignore some of the "experts" on here. Otherwise, no one would ever buy a 355.
    I honestly think the endless whining about every ****ing little issue has a fair bit to do with the ridiculously low prices of these amazing cars in your country.
    A good 355 is well over $130k here. As they should be.
  8. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Steve, just for the record, I love my car - it's awesome and really without issues...
  9. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    BOOOOOOM!!!!!!!!!!!!!!!!
  10. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    64,298
    Southlake, TX
    Rob Lay
    yes, an electrohydraulic manual transmission.
  11. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    OT, but can you post a pic of the center console Rob, would be curious to see what it looks like in the GrandSport. If we did not have snow here, I'd love to have one for a DD
  12. rob lay
    Dec 1, 2000
    64,298
    Southlake, TX
    Rob Lay
    Google "maserati gransport center console images"
  13. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #88 Dave rocks, Sep 30, 2013
  14. rob lay
    Dec 1, 2000
    64,298
    Southlake, TX
    Rob Lay
    I don't see a Maserati or center console.
  15. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,919
    Richmond
    Pete
    #90 bobzdar, Sep 30, 2013
    Here is the detailed explanation:
    There are three important facts at play:
    1. The byproducts at cold operation are harmful.
    2. Combustion is usually more efficient and complete at peak VE (torque peak) and worse at the ends of the rpm range.
    3. If you let the car warm up at idle, it takes longer to warm up than if you drive it.
    Here is where the logic part comes in.
    If the car takes longer to warm up (3), the oil will be exposed to more (2) harmful contaminants (1) for a longer period of time, therefore the oil will become more contaminated.
    Is that detailed enough?
  16. GerryD
    GerryD Formula 3
    May 5, 2010
    2,446
    North of TO
    Guido
    I find just starting the car no matter what the temps outside is very hard on the engine period. That is why I lift my car on the hoist before starting it and take a blow torch to the oil pan for about 10 to 20 minutes to warm the oil up. This will cause less damage upon initial start up as the oil is thinner when warmed. But if you find this a bit too much, just go with what Rob said as that is the best way especially if you don't have a hoist.:)
  17. rob lay
    Dec 1, 2000
    64,298
    Southlake, TX
    Rob Lay
    my plane has a preheater, why don't these expensive Ferraris! :)
  18. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,693
    Sarasota
    David
    Ettore Bugatti is said to have replyed to a customer who complained that his car was hard to start on cold mornings, that if you could afford his cars you could afford a heated garage.
  19. rob lay
    Dec 1, 2000
    64,298
    Southlake, TX
    Rob Lay
    ahh. :D
  20. TrojanFan
    TrojanFan F1 Veteran
    Nov 17, 2008
    5,186
    So. CA & NV
    Peter
    Steve:
    I'll ship mine over there for $100K. Any takers?
    Peter
  21. Steve355F1
    Aug 26, 2011
    17,184
    Steve
    Not if it's LHD! :)
    There are currently 14 F355s for sale on the most popular Australian car sales website.
    Prices range from $92,000 to $218,000, with the average probably around $140k.
    I've said it before (and I'll probably say it again) but you guys are REALLY fortunate to be able to buy one of these amazing cars for so little money. Although it does seem you get badly ripped off when it comes to servicing etc.
  22. Gated
    Gated Formula 3
    Dec 21, 2009
    1,117
    No kidding. I was just reading a UK article on servicing costs for F355 and they were half what most US posters are talking about!
  23. AceMaster
    Feb 6, 2009
    34,789
    Ontario, Canada
    Lol, this is good :)
  24. wrk2ownCT
    wrk2ownCT Karting
    Nov 30, 2012
    134
    Madison CT
    Chris
    I always warm my car up for +/- 10 mins.. It CLEARLY drives better and i dont constantly think i shredding metal on metal in an oil-less engine lol
  25. jjmcd
    jjmcd Formula Junior
    Dec 3, 2004
    490
    Same is true for the owner's manual for my Porsche 911
