1967 275 GTB 2-cam Nylock nuts | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by HealeyWerks, Mar 1, 2010.
  1. HealeyWerks
    HealeyWerks Rookie
    Dec 4, 2009
    31
    Lawton, IA
    The Healey Werks
    we need a couple yellow nylock nuts that measure M8x1 with 14mm across the flats and a height of 10.5mm. everything I can find is only 13mm across the flats with a height of 9mm. I have contacted all the usual suspects and no ones has these. Does anyone have a good source for these?
    Thanks in advance
  2. prance
    prance Formula Junior
    May 4, 2005
    513
    Agoura Hills
    morris
    Where do they fit on the car?
    Morris
  3. HealeyWerks
    HealeyWerks Rookie
    Dec 4, 2009
    31
    Lawton, IA
    The Healey Werks
    These are for the fuel tank straps. We will need 4 total. Even if they were used but in good condition would be great!!
  4. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,529
    Tuscaloosa, AL
    Drew Altemara
    Have you tried NewCo Products in CA. www.newcoproducts.com
    Might have to call them. They seem to specialize in this type of stuff. Pricy but if you really need them and only 4 at that might be worth a call.
    Drew
  5. HealeyWerks
    HealeyWerks Rookie
    Dec 4, 2009
    31
    Lawton, IA
    The Healey Werks
    Drew-
    Thanks for the response- I have talked to Neil @ Newco about these with no luck. I have tried all the usual suspects here in the states with out any luck either. I've even tried a few other resto shop hoping and they too do not have any. I have tried a few placing overseas but again.......zero. I will not post anything without doing my homework per say.
    Thanks again-
  6. prance
    May 4, 2005
    513
    Agoura Hills
    morris
    You are probably going to have to have them made. Let me know if you do.
    Morris
  7. 275GTB-2
    275GTB-2 Rookie
    24
    Speaking of straps. How are you going to restore them? I was told they came from the factory blued.
  8. paulvv
    paulvv Rookie
    Feb 20, 2006
    40
    Hello Craig,
    Found three yellow nylocks in my hardware stash....
    I will see if I can find another before sending tomorrow....(HealeyWerks address?)
    Don't have any need for these (at the moment!!!)..... your welcome to them.
    Best Regards
    Paul Vasquez
  9. HealeyWerks
    HealeyWerks Rookie
    Dec 4, 2009
    31
    Lawton, IA
    The Healey Werks
    Sounds good Paul- PM sent
  10. notrag
    notrag Rookie
    Jul 19, 2009
    7
    cheshire, UK
    Try http//:www.thomassmithfasteners.com; they have large stocks of fasteners in UK,
