1979 308 key blocks going to start position | FerrariChat
Discussion in 'Technical Q&A' started by DonatoEng, Apr 19, 2025.
  1. DonatoEng
    DonatoEng Rookie
    Jul 11, 2016
    6
    Michigan
    John Donato
    Went to get my 308 out for the first time this year and the ignition key will not go past the on position, 2, to start.
    Key turns easy and column lock works. Key feels like its against a hard stop.
    Any ideas ?
  2. malcolmb
    malcolmb Formula 3
    1,208
    San diego
    Malcolm Barksdale
    If the 308 has a steering wheel lock try wiggling the wheel.Sorry if you already tried that-it is so obvious it is easy to forget.
  3. lm2504me
    lm2504me Formula 3
    1,121
    Nipomo, CA
    Richard
    You may have a cracked pot metal barrel in you ignition switch or in the contact block.
    Post a close photo of the front of the ignition switch.
    Hopefully, it is the steering wheel lock.
  4. Motob
    Motob Formula 3
    Nov 11, 2003
    2,360
    Frederick, Maryland
    Brian Brown
    #4 Motob, Apr 23, 2025
    It sounds like the electrical portion of the ignition switch has gone bad. It is held to the back of the ignition lock with two screws. Unscrew it and remove it from the lock. You should be able to insert a screwdriver in the front of the switch and turn the ignition on. If the switch will turn to the crank position and start the car, then it is bad.
    The switch is the same as a vintage BMW 2002. BMW 61312682120
    This is the cheapest one I could find in a short search:
    https://parts.bmwnorthwest.com/p/Bmw__1602/Switch/43695250/61312682120.html?srsltid=AfmBOor-uBts0zDofkmaI8qb0orTkbOCN7yIoQzrSUTfObLPTbJUggDK
    f355spider likes this.
  5. emcauto
    emcauto Karting
    Jul 1, 2009
    248
  6. Motob
    Motob Formula 3
    Nov 11, 2003
    2,360
    Frederick, Maryland
    Brian Brown
    I used to get new OEM Bosch switches for $20-30 each back in the early 2000's.
