For Sale - 1980 Euro 308GTB | FerrariChat
For Sale 1980 Euro 308GTB
Discussion in 'Ferraris' started by shenbec, Aug 13, 2019.
  1. shenbec
    shenbec Rookie
    Nov 21, 2003
    14
    After 20+ years of ownership I am selling my Red/Black interior Euro (German spec) 1980 308GTB serial number 30693, with 55xxx km (35000 miles). Has DOT/EPA waiver. This is a rare dry sump, carbureted (one of the last), factory electronic ignition (single distributor), 16" factory Chromadora wheels (has original window decal stating this), deep larger fiberglass front spoiler, and correct single outlet exhaust. Car has never had body damage. Have two tool kits (one original one reproduction, plus some spare tools) and two original Jack kits. Also have a 1980 Euro owner’s manual and a 1976 US manual. Asking $95,000. The car is located in Spring City PA 19475. I have title in hand.
    Modifications: The springs have been cut and the car corner weighted (it is about 1”+ lower, but a set of adjustable height springs are also included). Has thicker Michelotto front and rear sway bars (originals included). The front bonnet grills have been stripped to bare aluminum and clear coated. The carburetors also have different larger jetting installed. The car corners very flat and the engine pulls very strong from 2000 RPM to beyond red line.
    History: The car started life in Germany. In 1985 the car was imported into the US. In 1989 Tim Holt of Holt Motorsports in West Chester PA bought it as his personal car. I then purchased the car from Tim in November of 1998 with 41071km (25520 miles), it currently has 55xxx km (just under 35000 miles).
    Major Maintenance Performed, with receipts and records
    2019 Replaced trunk zippered cover
    2018 Replaced Transmission fluid and engine oil (55k km)
    2017 Replaced all four tires
    2015 Replaced all electrical relays
    2013 Rebuilt brake master cylinder and booster (changed brake fluid)
    2013 Timing belts replaced at about 54500 km
    2012 Rebuilt water pump (changed antifreeze)
    2012 Installed Retro Air Rotary AC compressor (never charged)
    2009 Timing belts replaced at about 53500 km
    2006 Rebuilt starter
    2003 Installed New Jet Hot Coated front exhaust header
    2002 Timing Belts, Ignition (Coils/Wires/Distributor Cap/Rotter/Magnetic pickups), Replaced all hoses (Fuel/Coolant/AC), Suspension Bushings, POR15 (rust prevention black paint) inside of front fenders and A-arms
    2001 Replaced Steering Rack
    2000 Radiator clean/repair/paint, painted hood and replaced foam pieces
    1999 Redyed door panels
    Have many new parts and kept all the old parts removed from the car.
    New Spare Parts Included
    2x Motor mounts
    Shock bushings
    Water Pump Belt
    AC Belt
    Fuel filter
    Dash Instrument Light Bulbs
    Euro side-marker light
    Window channel felt
    Wheel valve stem
    4x wheel centers
    Brake caliper seals
    Interior AC plate
    Interior Fan/Hazard/Wiper/Antenna plate
    Body plate
    Paint label
    Carburetor rebuild kit
    F40 style key blank
    Usable Parts that were working when removed from the car
    2x Ignition coils
    2x Ignition magnetic pickups
    Distributor cap
    Distributor rotor
    Alternator
    Plus have old hoses/nuts/bolts/screws/misc parts that were replaced during the listed maintenance.
    Contact Chris at 610-659-1329 or [email protected] Many more pictures available upon request.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    George Vosburgh likes this.
  2. 19633500GT
    19633500GT F1 World Champ
    12,025
    Blueberry
    Muffin-Tops
    Wow. Outstanding. Love the mid year change steering wheel, but carb seats. Super cool I bet this sounds amazing.
    ralfabco and BOKE like this.
  3. Bucci
    Bucci Karting
    Jan 5, 2020
    77
    Mark Bucci
    You sell it?
  4. George Vosburgh
    George Vosburgh F1 Rookie
    Very nice, you made a lot of the same changes I made to my '77 GTB.
