1981 QP III 5 Speed and 1986 QP III Auto | Page 12 | FerrariChat
Discussion in 'Maserati' started by William Abraham, Nov 27, 2010.
  1. William Abraham
    William Abraham Formula Junior
    Nov 21, 2010
    830
    London, UK
    William Abraham
    See the repair invoice. Carpathian Burl Elm
    View attachment ESale.pdf
  2. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Well I took the car out for a quick detail before Christmas. Anyway, overheating in the shop and a floor full of rad fluid. Then when I picked it up limited power steering (fluid on the belt?) and overheating.
    So not sure what has gone on but I had the free flow rad installed and since then the rad light comes on for fluid level but never this issue. Hmmmm what does it mean but I dont want to cook the engine. The engine light did not come on either but there was steam from the front end. Not sure what is up but clearly either the fans are not kicking in right or there is some issue with the free flow rad conversion.
    Does put a crimp in the holiday driving plans. Anyone else out there have an issue with a free flow rad?
  3. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    William,
    Check your fans first. You may have a wire, fuse or sensor issue. If need be, you could operate the fans manually with a switch.
    Also make sure that when you fill the system, it gets bled properly. Best done with the front of the car a little higher, heater on full and let run with the cap off untill you have open thermostat. Then fill to the mark and cap. If you don't do this properly, you may have pockets of air in the system, and an airlock may occur, preventing flow in certain areas.
  4. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    Hi William!
    Fantastic thread which shows your ability to overcome the various challenges related to a project like this.
    I just bought a LHD 1981 QP3 and I have a few questions for you:
    1) Where do I get the MASERATI and QUATTROPORTE chromed badges for the bootlid?
    2) Do you know of someone who have a cylinder sleeve with a matching piston and rings that I can put into my "stuck" 4,9 engine?
    3) At what speed does the "lock-up" of the converter kick in (auto tranny)?
    4) What is your typical milage when driving at a steady 110 kph.?
    5) You wrote that you bought a new mirror from MIE just to get the rubber seal.... Was this right or left side mirror? My left side mirror is broken. I could be interested in this mirror if you want to sell it (my gasket is perfect)
    6) The exhaust tips on the PQ3s seem to differ a bit, but I am nut sure if some just are aftermarket systems. I would like to buy he original "big tube" tips and have the small pipes inside like on an original car. Mine have just some sort of small wedge-cut tips and I am uncertain if these are original on the first years cars or aftermarket. I noticed MIE has a system availible, but these have the tips like on your '86. I want the ORIGINAL ones...
    7) Was it hard to screw off the exhaust manifold/header nuts?
    I am in the process of getting a fine "Maroon Colorado met" (Light brown) car on the road for 2013!!
    Cheers from Oslo :)
    Erik
  5. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Hi I will try to answer a few questions or at least point you in the right direction. See above in Caps
    QUOTE=F456M;141989921]Hi William!
    1) Where do I get the MASERATI and QUATTROPORTE chromed badges for the bootlid? THERE ARE A FEW PEOPLE ON THE INTERNET THAT HAVE THEM. MIE HAD ONE OR TWO BUT MAY BE SOLD. ALSO AT BILL MCGRATH IN LONDON. CHECK OUT EBAY BY SEARCHING QUATTROPORTE III OR 3 AND YOU WILL GET SOME SELLERS
    2) Do you know of someone who have a cylinder sleeve with a matching piston and rings that I can put into my "stuck" 4,9 engine? HMMM TOO TECHNICAL FOR THE LIKES OF ME! I SUGGEST MIE/BILL MCGRATHS AND MAYBE THE SHOP THAT IS WORKING ON MY CAR NOW AS HE IS DOING THE MOTOR ON MY 1981 AND SEEMS TO HAVE ALL THE SOURCES.
    3) At what speed does the "lock-up" of the converter kick in (auto tranny)? NO IDEA ON THAT ONE BUT IT WAS DISCUSSED ON THE SITE EARLIER. IF YOU CANT SEARCH FOR IT I WILL FIND IT. AS THIS IS A 727 CHRYSLER UNIT THERE ARE A FEW PLACED THAT CAN SORT THEM OUT
    4) What is your typical milage when driving at a steady 110 kph.? I HAVE NEVER CALCULATED IT BUT CANT BE MORE THAN 8 TO 12. ONCE I GET IT TUNED PROPERLY I WILL DO SOME CHECKS BUT THERE WERE SOME VALUES POSTED ON THE SITE IF YOU SEARCH YOU WILL SEE
    5) You wrote that you bought a new mirror from MIE just to get the rubber seal.... Was this right or left side mirror? My left side mirror is broken. I could be interested in this mirror if you want to sell it (my gasket is perfect) - MIRROR WAS A BIT OF A WRECK. I BOUGHT A "PERFECT" EXTRA SET FROM JOEDRO ON LINE WHICH WERE QUITE RUSTED AND ROUGH. THE ONES ON MY 86 WERE ALSO A BIT ROUGH SO BETWEEN THE 4 WE MADE ONE DECENT BUT NOT PERFECT SET. THE SPARE FROM MIE WAS REALLY JUST A SHELL BUT HAD THE GASKET. MIE DOES SELL A REPLACEMENT UNIT BUT NOT SURE HOW IT FITS ON WHAT CARS
    6) The exhaust tips on the PQ3s seem to differ a bit, but I am nut sure if some just are aftermarket systems. I would like to buy he original "big tube" tips and have the small pipes inside like on an original car. Mine have just some sort of small wedge-cut tips and I am uncertain if these are original on the first years cars or aftermarket. I noticed MIE has a system availible, but these have the tips like on your '86. I want the ORIGINAL ones...I THINK MIE HAVE SOME ORIGINAL TIPS (MAYBE) OTHER THAN THAT THERE ARE SOME ITALIAN SITES THAT YOU CAN FAX YOUR REQUEST TOO AND THEY SEEM TO HAVE PARTS AT A VERY HIGH PRICE.
    7) Was it hard to screw off the exhaust manifold/header nuts? I DID NOT DO THIS BUT HAVE NOT HEARD IT WAS AN ISSUE FROM THE MECHANIC. USUALLY IT IS A BIG ISSUE AND THERE ARE SOME POSTS ON THIS IN THE VARIOUS THREADS THAT MAY GIVE SOME HINTS. EVEN ON THE OTHER THREADS THERE IS GOOD USEFUL INFORMATION AS THE MOTORS SHARE THE SAME GENESIS (A BIT). THE QP III IS TREATED A BIT LIKE THE BASTARD COUSIN BUT STILL FAMILY.
    ANYWAY, ENJOY YOUR CAR AND POST SOME PICTURES.
    Cheers from Oslo :)
    Erik[/QUOTE]
  6. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    I had the issue with the car overheating the other day after I had put in the free flow rad and got it on the road again. It dropped a few litres of rad fluid on the floor of the detailers shop (he left it running probably as he was worried about it starting!)
    I would top off the expansion tank but still the Rad fluid light would come on. It was losing fluid out of the expansion tank overflow when hot but the other side (by the rad) showed fluid? Could it be a vapour lock as someone suggested or could it be the water pump packed in during the recommissioning.
    I am not familiar with the expansion tank system - can someone give me a quick primer?
    If so, someone mentioned running it with the caps off and the heater on full. Is that the recommended approach. I would like to do a few self help steps before having it towed away!
  7. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Hi William,
    That was me.
    The best results you'll get with the caps off: as soon as the engine starts to circulate coolant, bubbles get transposted by the flow and end up below the thermostat. The thermostat should have a jiggle-pin, which facilitates air to bleed through, but that is just a very small hole. Let the car run to operating temp, you'll see on the level when the thermostat opens, and the hose from the pump will then also get warm. squeeze the hoses to get bubbles out, fill rad to capacity (if it has a cap), and expansion tank to high mark. Cap and be done.
    The reason for the heater to be on full heat is to get the air out of the heater matrix. When you vacant the system, the matrix doesn't get filled when the heater is set on cold, and it is just full of air.
    Modern thermostats normally open when they fail, but it's a good thing to check. Also check the polarity of the fans, if the wires get switched, the fans blow against the incoming air-stream.
    I don't know how prone to failre the pump is, but of course there could be a problem there, albeit the last thing to check imo.
    Also check for bubbles appearing in the coolant (persistantly) with a warm engine: In that case, check the coolant for exhaust contaminants, as it would indicate a head-gasket problem.
    Hope this helps,
    Jack.
  8. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Hi
    Radiator Issue
    Hi I put some water in and warmed up the car as advised with the caps off and heater on full. The fans did not come on.
    I was wondering if this had something to do with having the TEDEL 102 out of the car but there was nothing showing that this linked to the fans at all. The fuse looked fine so I think I will need to get it checked.
    TEDEL 102
    I got this reply from the TEDEL repair expert.
    "William
    We have some defined results for you! We have tested both units (but only charged you one test fee of £44.50)
    1. Old unit is damaged badly, but is repairable. Damage to switching circuits
    2. New unit is the wrong one for function.
    The only logical conclusion is you have a host wiring fault which is eating the units
    I think we can repair the old one for about £125.00, but we will only know the outcome when we try to do it (it is a mess).
    You need to find the host loom fault before we go ahead with the repair here!
    You thoughts please?"
    The issue is with Pin 5 Blue/Red - Interior Lights
    Pin 2 Black - Ground
    Pin 7 White/Violet - Ignition Switch
    Hmmmm I need someone who knows about QP III electrics to track this down and at the same time to fix my fans and install a back up toggle manual switch for the fans in case this happens again (every car has had this issue so I do think this is a MUST for the QP III)
  9. F456M
    F456M F1 Rookie
    Jan 8, 2010
    3,696
    Oslo
    Erik
    F308Jack: You write in the text below that the fans for the radiator is blowing air from the engine compartment and out??? IS this correct? That yould be the opposite way of the natural airstram....
    Please confirm this.
    I have ordered a new fan thermo switch to be sure the fans kick in!
    Thanks,
    Erik
  10. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Well a short update. The Tedel 102 repair was unsuccessful! The only solution was to buy a unit from Germany. Thankfully they have a source there that is making or remaking these so it should be here in a day or so - expensive.
    I did find a "mobile mechanic" service that came out and actually knew what they were doing. He didn't want the manuals just jumped in to sort out every electrical issue. Said he was very familiar with the car. Fixed the lights, ground short, got motor in seat working, fixed connections for fan which were the problem, a light issue caused by ground fault in the rear light, cigarette lighter working, etc. The dimmer was not sorted as we are waiting for the 102. He even got the courtesy light in the engine compartment working.
    Also, we wired in a switch for the fans. He did this properly by taking out the front fuse box and baring two brown wires for the fans and soldering in the new wire and running it to the cubby below the steering wheel. At least if nothing kicks in on the fans for some reason I can turn it on and get home!
    I will try to post a picture or two particularly when the 102 is going in.
    Car was in great shape as was wiring. Really almost like new.
  11. Jalpa_Mike
    Jalpa_Mike F1 Rookie
    Apr 2, 2004
    3,019
    Sequim
    Michael Wilson
    Correct William. The Tedel 102 has nothing to do with the radiator fans. From what I found years ago, the Tedal 102 was mostly controlling the lighting inside the car, dimmers, etc... Here is a diagram I made years ago. Not sure if it will help you now or not......
  12. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Yes your diagram was a great help as we had the box checked by P Remmington here in the Uk and he identified the issues which were caused by loom faults of some kind. This enabled us to have the electrical guy track down the underlying faults which were causing the box to blow.. So hopefully when we put in the new 500 pound box it does not go "boom". I had bought a spare box before from Joedro but it was all blown up inside too - Anyway, quite the saga. The box from MIE was not the right one either - not sure what it is for but it went back to them.
    Anyway, all good fun but now the car is running like a tank so needs to go back to the mechanic. Obviously the overheating was not good for the running trim.
    Ciao for now
  13. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Jack Verschuur
    Hi Erik,
    Sorry, I only saw your post now.
    No, that's not what I wrote: I suggested to check the polarity of the wires to be correct after the rad replacement, because if switched around the fan could blow the wrong way (I.e. against the natural flow, thus diminishing the cooling capacity of the system. It wouldn't be the first time I see this happen, and such a thing is easily overlooked.
    Best,
    Jack.
  14. qp400i
    qp400i Karting
    Jun 17, 2011
    91
    Netherlands
    Igino
    This is a great thread which I enjoyed reading. I am new to this forum, owning an F400i which was restored, then suffered an engine burn and is now being repaired again, as well as a 1986 qpIII which I have saved from the scrap yard and which has undergone many repair works and improvements. I might open a separate thread to show the work done so far. This picture shows that the car is fairly low at the front, due to mounting F Daytona coils in stead of original ones. Handling is great but the chassis tends to touch the ground on certain steep speed bumps.
    I am having issues with the TEDEL as well. I was happy to read the recommendation to repair the wiring first, before putting back a repaired or new TEDEL.
    Cheers!
  15. Sunracer
    Sunracer Formula Junior
    May 18, 2005
    661
    Makati City
    Pierre Beniston
    great looking car it would be great to see a thread on the build up!
  16. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Great to hear your car is going and rescued. Also, thanks for your comments re the thread. I got the TEDEL 102 back yesterday and got it into the car. The electrician checked it all out and it is working (somewhere in heaven a choir was singing). He did say that the copper connectors etc in the boot for the lights really were a poor design (they have a bar across the lights for ground) and he was proposing to come back and solder a proper ground connection for each light. I asked him to consider this a bit more and perhaps could be go to a brighter cooler light like LED without destroying the look. He thought it may be possible and would consider it.
    So a bit more work for the future.
    Anyway, the TEDEL did not help the running of the car so we will have to limp it to the mechanic for a mani/pedi.
    Ciao for now
  17. Quattroporte3
    Quattroporte3 Formula 3
    Nov 13, 2010
    1,060
    Hi William,
    glad to hear your saga, it sounds like progress is being made!
    I'd also be interested in a LED or similar rear light replacement. I notice that mine have a mind of their own, and work fine for a while until they don't, and before I get a chance to look at them they work ok again :-/.
    Related to that, I drove back from a longish trip (2h) last night and was reminded how dim the original headlights are, they barely illuminate anything at all! I'll have to see if there are after market solutions to increase the output while retaining the look and originality.
    Igino - great looking car, it would be nice to see more of your restoration and what you've done so far! The front end looks dangerously close to the tires, though. Just a thought.
  18. qp400i
    qp400i Karting
    Jun 17, 2011
    91
    Netherlands
    Igino
    I'd like to post pictures directly on the page, not as a link, but I see that for me 'img code' is off. How can I change that? I just silver subscribed but that made no difference. I have an avatar now though (wheel of the 400i).
  19. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Well - the system here is not user friendly but if you get an error message then picture size is too big. Some seem to get a lot of pictures up but I can only ever get 2 per reply (maybe 3).
    Open a reply
    Manage attachments
    Upload 2 and then wait - there is no timing bar or hourglass so you have to look at the static uploading and wait.
    That is all I can help you with.
  20. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    Cheers![/QUOTE]
    On the Tedel the only solution I found was Herr Scheimenz from Bonn - sent it got it back and it worked.
    Front end. The MIE solution shocks are too high on the front. Now that mine is running I have a special Ohlins system made for the QPIII. It will be a bit expensive but should be amazing. Off there maybe end of next week.
    If you want I can connect you up once you have seen what was posted.
  21. qp400i
    qp400i Karting
    Jun 17, 2011
    91
    Netherlands
    Igino
    I am watching this space! Look forward to see your solution for the front end. Do you have contact details of our German TEDEL repair man?
  22. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
    This is the website. No one there replies or communicates probably because all is in German. However, Mr Lange (black QP III fame) listed on this site liaises with him for me. The cost was 500 pounds including postage.
    fast turnaround. It looked the same (only the plastic melted to seal the box) and even the board end looked the same. Not sure if they repaired it or if it was new but it did work.
    Picture of it going back in
    www.schiemenz.com
    translation from their website ----
    Maserati engines
    According to original specifications with current materials or alloys and production methods.
    According to an old Italian craftsmanship.
    Unit overhaul and repairs.
    Maserati bodies
    After original accuracy with today's surface quality, sealing and corrosion prevention.
    Manufacture, repair, renovation and painting to original recipes.
    Society is changing, not the lifestyle of Maseratisti. Without your Maserati, the world can be very lonely, we are against loneliness.
    Do not take our word for it!
    Mr. Schiemenz is:
    Founding member of the Maserati Club
    Founding member of the Registro Maserati Modena (since 2004 Maserati Fabric)
    Member of the Scuderia del Tridente
    Vehicle offers, please visit our used car page, or on request.
  23. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
  24. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
  25. William Abraham
    Nov 21, 2010
    830
    London, UK
    William Abraham
