Buy
1982 308 intermittent fuel gauge operation
Discussion in 'Technical Q&A' started by wamclain, Apr 15, 2004.
  1. wamclain
    wamclain Rookie
    Apr 1, 2004
    6
    Denver, Colorado
    William McLain
    When my 308 is cold, the fuel guage seems to work fine, but after the car has run for a while, the gauge pops back and forth between a reading and zero. Then as the engine heats up, the fuel gauge stays pegged at zero.
    I have cleaned the contacts at the sending unit, but would appreciate knowing if anyone else has had this problem, or would have any suggestions as to what I need to eliminate as possible causes of this abnormality. For example, can I test the sending unit without removing it from the fuel tank?
  3. joeyy
    joeyy Karting
    Nov 11, 2003
    190
    long island
    joe
    i had a similar problem and it was the guage. i had it rebuilt and all is fine.
  4. wamclain
    wamclain Rookie
    Apr 1, 2004
    6
    Denver, Colorado
    William McLain
    Thanks for the reply. I'll have it checked.
