1985 400i 5 spd / Long overdue / 12k Service | Page 6 | FerrariChat
Discussion in '365 GT4 2+2/400/412' started by Paul C Cain, Nov 1, 2022.
  1. Paul C Cain
    Paul C Cain Karting
    112
    Newport Beach Calif.
    Paul C Cain
  2. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    It's been a busy few weeks. The car is back together. The 'sport' exhaust took a number of fixes to cap all of the exhaust leaks but once capped, we went for a full shakedown run, about 800 miles roundtrip from So. Cal to Central California.
    We spent about one hour going back and forth on Hwy 229, It is here where the 400i chassis and torque curve completely blew me away, tight twisties, gobbs of torque and a chassis that was planted, flat and predictable in the tightest of the decreasing radius turns. What a chassis, and what a pleasure, complete with good feedback in the ZF power steering. I really pushed it hard and it kept responding. Unbelievable for its size and girth. It’s on new Michelin TRX’s.
    Here is a quick clip of the new exhaust note getting back on the 101 Freeway near Santa Barbara.
    It drank a little oil, the self leveling pump fill hose is still dripping (odd, its new) and the rest of the engine service performed flawlessly, both at speed and back in traffic.
    Jim575, GT Jones, 06ZHP and 3 others like this.
  3. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    12k Service -Phase II - Valve Adjustment
    I am deep into the pass. side valve clearance checking and shim adjustment. A pleasant surprise while lifting the cam covers was the pristine condition of the internal cavities. Clearly this motor at 12k got a lot oil changes. The peaks on each lobe look pristine with no visible wear. 5 of the 6 exhaust valve clearances were way too loose. Here are the details. New shims are on the way.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    71Vette, Jim575, Il Tifoso and 2 others like this.
  4. Theruse
    Theruse Karting
    Jan 17, 2014
    176
    Maryland
    Prescott Russo
    That is a great chart. Do you have that in a file format we can all use when we adjust our valves? thanks
    Ashman and raemin like this.
  5. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    Il Tifoso, Schumi, raemin and 2 others like this.
  6. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    I just realized FChat does no allow Microsoft .ppt format. I have that for you, just email me and I'll send it. To anyone.
    to: [email protected]
  7. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    Before I go any further. A brief but important acknowledgement to Phil Auldridge from the GTC / C4 forum for the spectacular write up on doing this valve adjustment. See attached. Really well done and a great baseline before you grab your 10mm socket to remove the cam covers.
    samsaprunoff and 06ZHP like this.
  8. Theruse
    Theruse Karting
    Jan 17, 2014
    176
    Maryland
    Prescott Russo
    Many thanks. Now I feel compelled to adjust my valves!!! Very useful.
  9. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
  10. raemin
    raemin Formula 3
    Jan 16, 2007
    2,296
    Lyon (FR)
    R. Emin
    Why don't you follow the clearance factory guidelines? Additional clearance makes the drivetrain more noisy and reduces the lift. Also It will take very little wear (0.01mm) to be again out of spec.
    Apart from saving a few shims, there are no obvious benefits.
  11. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    @raemin Good question. There is one benefit: my piece of mind.
    The 'before' clearances were very loose and the valve train remained very quiet. I take any valve clearance adjustments, particularly further tightening, on the 'hot side' (exhaust) very seriously and always set them at the right end of the distribution. It gives me more confidence that in the extremes of thermal expansion, I will never burn an exhaust valve. Its theoretical, but I sleep better at night knowing I am not overlifting my valves by 13/1000's of a millimeter. ;)
  12. Al Campbell
    Al Campbell Formula Junior
    Nov 22, 2013
    581
    Australia
    I have just installed the camshafts and set my valve clearances and I'm wondering how you managed to get measurements to the 1000th's of a mm with feeler gauges?
    On a side note I found that my angle grinder spanner was great for holding the camshaft in the correct position while fitting it and then a piece of cardboard under one cap to hold it in place to fit the chain.
    Cheers,
    Al
    Jim575, Paul C Cain, wrxmike and 2 others like this.
  13. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    @Al Campbell my comment was in jest -in that we are splicing hairs with these small increments.
    Impressive photo of your rebuild. I gotta ask, what is the 'trick' with cutting the O rings on the mating surface to the front of the cylinder head?
  14. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    Ok, it does not take a concours judge to see what's wrong with the below photo. Cylinder head on the pass. side all buttoned up, new acorn bolts, etc. It's those headers. And the surface rust.
    At the moment I have the entire center section mufflers and resonators out of the car. It open collectors x 4 downstairs, I think you see where I am going with this.
    I am considering removing the headers, media blasting and ceramic coating them. I've cracked about half of the exhaust flange bolts to the head and no issues so far with stripping, studs extracting, etc. It *appears* that these two header sections would simply slide out. This is obviously the easy side, duping you to dive in deeper. Only to discover major issues on the LHD steering box side.
    Before I do: A question for the FChat forum: How hard is it to remove and replace the drivers side headers on this model? Is the steering shaft a major issue?
    Any input from those with the scabs on their knuckles would be greatly appreciated.......
  15. raemin
    raemin Formula 3
    Jan 16, 2007
    2,296
    Lyon (FR)
    R. Emin
    That's the WSM guidelines when removing the camshafts. You can make it do without cutting them, but it's a pain.
  16. raemin
    raemin Formula 3
    Jan 16, 2007
    2,296
    Lyon (FR)
    R. Emin
    The most painfull part is to remove the k-jet, but you already did it once for the right side.
    While you are there, just service the starter, and install some good lightweight heatshields.
  17. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    @raemin Thanks for the reply. Removing the Fuel distributor/air box is easy. So, do I lift the headers out from the top side (around the steering shaft) or do they drop out the bottom?
    Thank you.
  18. raemin
    raemin Formula 3
    Jan 16, 2007
    2,296
    Lyon (FR)
    R. Emin
    Top side.
    By the way, I never had to remove the steering servo even when we took the engine out. The steering link, but not the servo or the matching pivot on the right side.
  19. Al Campbell
    Nov 22, 2013
    581
    Australia
    Cutting the O'rings as per the manual allows you to remove/refit the front covers later on to check/adjust the camshaft alignment without removing the rest of the camshaft covers etc which saves a lot of extra work.
  20. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    @raemin / Others,
    Well, that was easy. All the exhaust studs stayed in place and the header set is now out and ready for blasting. It'll be a few weeks, but I'll be back with some Cerikoted headers.
    I've done a lot of searching on this Forum for the correct header color for the 365 / 400i. I may have missed it, but what was the original color?
    Ak Jim likes this.
  21. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    Back on the project today. Got the Driver's side cam covers off and the valve clearances checked. Only one of the exhaust valves had an issue at 0.38 mm clearance. One shim swap was all it took to get it back in tolerance. All off the intake valves were within tolerance.
    Cam lobe peaks are in great condition and there is no wear on the back side of the lobes.
    Jim575 likes this.
  22. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    I can't recall who suggest that I 'service' the starter motor while the headers are out. Holy tamole that was a brilliant. With the heat shield in place, I can't image how anyone could remove the starter. Bendix and armature shaft have been lubed. Time for some new asbestos in the heat shield.
  23. Theruse
    Theruse Karting
    Jan 17, 2014
    176
    Maryland
    Prescott Russo
    I am going ahead and Cerakoting the exhaust system in Black Velvet. I saw finished examples of Black Velvet and it is exceptional. I have decided to now do the headers. Richard at Competizione says it's not too difficult to remove the headers. He has FI while I have six sidedraft Webers, so a tad more difficult. Were you able to determine the original color for the headers? If not, did you go ahead with black velvet as well.
  24. Paul C Cain
    Paul C Cain Karting
    112
    Paul C Cain
    Hello Theruse,
    I did not get any replies as to the question about: "what is the original color of the 400i headers?".
    That (not) said, I decided to go with Cerikote "Cobalt'' which is sort of a matte titanium color, as shown below:
    Spider2400 likes this.
  25. Theruse
    Theruse Karting
    Jan 17, 2014
    176
    Maryland
    Prescott Russo
    Good choice. We were looking at something similar as we wanted a contrast from the engine and exhaust. Look forward to seeing pix when done and will do the same.
