For Sale - 1995 Berlinetta with mods | FerrariChat
For Sale 1995 Berlinetta with mods
Discussion in 'Ferraris' started by F355Bob, Dec 1, 2019.
  1. F355Bob
    F355Bob Formula 3
    Selling my early, 1005, 1995 F355 Corsa Red with tan interior. Build date 1994. Car has 59,500 miles and I have owned it for 20 years. I have extensive records. Car has many performance modifications to suspension, engine and interior and I think it is the F355 version of a 360 Stadale. The car has a complete blueprinted engine rebuild by Scott Tuckers's Challenge Series engine builder. Car is never driven in the rain and very clean. This has been by good weather daily driver and occasional track car. Paint in very good condition with a scrape below the front bumper. Interior is very good with some shrinkage of dash around window and wear on the drivers bolster as expected. Car has over 40rwhp over stock car and much better midrange power, massive brakes and Challenge suspension with stock springs, and real carbon fiber interior. Car has over $60,000
    in factory Challenge and performance parts. Engine rebuild in 2018 cost over $45,000. Asking $82,000
    Here is a list of parts.
    SUSPENSION
    Challenge wheels
    Challenge front sway bar
    Challenge rear sway bar
    Challenge front and rear sway bar pads
    Challenge front adjustable sway bar links
    Challenge rear adjustable sway bar links
    Challenge steering rack
    Challenge steering pump
    Moton triple adjustable shocks front and rear.( $1200 rebuild of all seals done 10/19)
    Rear 11mm spacers
    Front 15mm spacers
    Michelin Super Sport 4S tires
    Car lowered and corner balanced
    Rear Challenge bar, Challenge rack and pump are no longer available from Ricambi
    Suspension parts cost $20,000
    BRAKES
    Stoptech 355mm front cross drilled rotors with lightweight Trophy calipers
    Stoptech 332mm rear cross drilled rotors with lightweight Trophy calipers
    Front and rear stainless steel brake lines
    Brakes cost $6500
    BODY
    Challenge grill
    Challenge engine mounts
    Challenge rear engine support
    Challenge door grills
    Challenge factory clutch cover
    HID headlights
    Front clear turn signal lenses
    Scud Ing front LED front turn signal bulb with Scud Ing relay
    Scud Ing LED tail lights. All four light up when lights on or braking 3xs brighter than stock
    Scud Ing LED programmable 3rd brake light. Can be programed to flash when braking in 20 configurations
    Scud Ing LED back up light
    Valence USA carbon fiber diffusers
    Yoshi fender shields
    Rolled fenders
    Black powder coated exterior emblems
    Cost of body parts $5500
    INTERIOR
    Valence USA full carbon fiber center console
    Valence USA full carbon console center console instrument panel
    Valence USA full carbon dash instrument and radio surrounds
    Valence USA carbon fiber mirror surrounds
    Valence USA carbon fiber emergency handle
    Valence USA carbon fiber door handles
    Valence USA carbon fiber door sills
    Momo steering wheel adapter
    Momo steering wheel
    Factory rear glove box
    VDO volt gauge replacing clock to monitor alternator charge
    Yellow faced tach with adjustable lights for rev limiter
    Custom aluminum accelerator pedal for easy heal and toe
    Alluminum passenger foot plate
    Shortened shifter
    Hill shifter plate
    Tinted windows with 80% LLuminar tint
    Sticky parts have been cleaned down to bare plastic
    New air deflector motor
    New air circulation motor and brass pin
    All Valence USA carbon parts are full carbon and not overlays. They are the highest quality and are pretty much unavailable.
    Cost of interior parts $12,500
    GEARBOX
    Complete disassembly on 2018
    New 3rd gear synchro
    New filter and all new gaskets
    New gearbox cover bearing
    Hill throughout bearing
    New CV boots
    Cost of labor and parts $4000
    ENGINE
    Complete engine disassembly with rebuild in 2018
    1000mi on rebuild
    Engine dynode 324rwhp at 8000rpm on Mustang dyno. Stock dyno around 280rwhp on Mustang dyno
    On Dynojet would dyno around 355rwhp
    New belts
    Guides replaced
    Heads and intake have been ported
    New slightly larger pistons with new rings
    Refinished cylinders
    3 angle valve job
    New valve stem seals
    New oil squirters
    New belt tensioners
    Hill bearings
    New cam, main and rod bearings
    New vacuum lines
    New water pump
    New thermostat
    All new water hoses form engine to front trunk heater core
    Challenge belt covers
    Cams timed and slightly advanced
    Powder coated valve covers
    Cost of rebuild over $45,000
    Custom engine parts
    Gothspeed one off Scuderia exhaust
    Bruce Wright custom 4-2-1 headers
    Hyperflow cats
    Inconel header shields
    Saldana aluminum radiators
    GruppeM airbox
    Dual UnichipQ computers to adjust fuel timing when dyno tuning
    Complete Helms gold kit including computers
    New factory alternator
    New battery and cables
    Cost of parts $17,000
    Not a car for the purist but for those who want a one of a kind F355 that has outstanding handling, brakes , and power that far surpasses a stock F355 and can be daily driven of tracked. Suspension and engine computers fully adjustable Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
    ShineKen, Tifosi Dude, Nikil and 7 others like this.
  2. Jon Von Bon
    Jon Von Bon Formula 3
    1,697
    Toronto / Florida
    Jeff
    THE 355 TO HAVE..... ( besides mine LOL!)
    I have admired this car for years.
    Why would you sell such a beautiful example of perfection?
    Good luck with your sale and I feel your pain.
    355dreamer likes this.
  3. jeffdavison
    jeffdavison F1 Rookie
    Jul 29, 2002
    2,544
    Suwanee Georgia
    Jeffrey Davison
    why, why, why, why???
    jimmym likes this.
  4. ///criss
    ///criss Rookie
    Jan 1, 2017
    44
    San Diego
    Cristopher
    Looks sweet! The question is will this pass California regulations for smog etc?
  5. BrianNYC14
    BrianNYC14 Formula Junior
    Dec 6, 2014
    761
    North Carolina
    Brian E
  6. Rnye
    Rnye Karting
    Mar 17, 2014
    177
    Las Vegas, NV
    I went on YouTube to find exhaust clips of your setup and ended up being the 355th view!
    It’s an awesome setup! GLWS
    ThatFlyGuy likes this.
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,519
    San Carlos, CA
    Mitchell Le
    From the visual inspection alone, it would have serious problem passing. You would have to somehow convert it back to stock look to even have a chance. Then the Hyperflows have a low probability (1 in 3) of passing the tail pipes test. That can be cured by swapping back the stock cats.
  8. F355Bob
    F355Bob Formula 3
    custom exhaust
    crinoid likes this.
  9. F355Bob
    F355Bob Formula 3
    Mustang dyno 324rwhp. The smoke at the end is coming from the dyno tubing getting hot.
    C50 and crinoid like this.
  10. eyeman1234
    eyeman1234 Formula 3
    Dec 25, 2006
    1,881
    Boca Raton, FL
    All I can say is...WOW!
  11. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Damn you!
    Now I want another 355. I’m seriously tempted. How’s the paint?
    SGM and Robb like this.
  12. F355Bob
    F355Bob Formula 3
    Paint very good
  13. 355dreamer
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    Can you remind me again how the exhaust / rear bumper conversion was done?
  14. F355Bob
    F355Bob Formula 3
    How it was done? I contracted Goth and asked if he could make a 430 Scud looking exhaust.Gothspeed made the exhaust and template to drill the rear bumper holes. It is like the Scud exhaust. The pipe you see in the bumper is not the real exhaust but another pipe inside thst one is the real muffler pipe. It gained 20rwhp on the dyno.
    crinoid likes this.
  15. F355Bob
    F355Bob Formula 3
    crinoid likes this.
  16. Jon Von Bon
    1,697
    Toronto / Florida
    Jeff
  17. tres55
    tres55 F1 Rookie
    3,568
    Canada
    Pretty much perfect driver 355. Personally not a fan of the exhaust exit location compared to the factory solution but car is a beauty on all other points.
  18. Mmckee
    Mmckee Formula 3
    BANNED Silver Subscribed
    Sep 30, 2016
    2,339
    Alta Loma, Ca
    So it’s bone stock & for concours only?
    Me likely. Mods good, massive mods are most excellent!
    In CA they use my car at concours judge training: Find the 99 things for which you should deduct points.
    You have me beat- nice work.
  19. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,658
    NOLA
    Chris
    Love the car.
  20. F129b
    F129b Formula Junior
    Feb 6, 2004
    523
    oc, calif.
    Robert
    Helluva lot of F355 for $82k
    I hope you get it & don’t regret it!
  21. Joseph Safina
    Joseph Safina Rookie
    Dec 3, 2019
    1
    Fort Lauderdale
    Joseph Safina
