Sold - 1995 F355 GTB Rosso Barchetta Stick | FerrariChat
Sold 1995 F355 GTB Rosso Barchetta Stick
Discussion in 'Ferraris' started by brendon0, Sep 21, 2020.
  1. brendon0
    brendon0 Formula Junior
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    1995 GTB stick shift Rossa Barchetta 29,xxx miles. Fabspeed headers, Tubi Exhaust.
    Purchased in 2006 from a fellow fchatter, so Owned it 14 years.
    3 Engine outs since I have owned it. I never ever intended to sell this car so the car has been maintained like
    I was planning to keep it forever, including major/minor stuff the mechanic pointed out at the last engine out. NOTHING has been skipped on maintaining this car. If you want a 355 where everything possible that can be fixed on it has been done, then this is the one for you. No stickies.
    Have been using this as a daily driver for the last year, just had the windows tinted and A/C completely replaced in the last year so this is actually comfortable to drive on a daily basis even in the Florida heat.
    Maintenance history:
    2020:
    All windows ceramic tinted including clear windshield tint.
    2019:
    Replaced complete A/C system - The Blower box, A/C Compressor and Drier all replaced.
    Oil pressure sensor replaced.
    2018:
    MAF's rebuilt, O2 sensors replaced.
    Engine out - transmission cover replaced, rear main seal replaced. Replaced crank sensors
    CV Boot replaced, All spark plugs replaced
    Wheel caps replaced with darker yellow caps
    Several under body panels replaced and refinished.
    Rear tires replaced with Michellin Super Sports 295/35/18 approx 3000 miles on them.
    Front Tires replaced Michellin Super Sports 225/40/18
    Clutch replacement - Hill Flange, triple seals replaced, new clutch and throw out. Pressure plate replaced. Flywheel checked and cleaned.
    4 Wheel alignment, set to factory specifications on hunter machines. Balanced, ride height set to factory
    2016:
    HVAC ECU rebuild with new chips
    2015:
    Leak down test with cams out - All showing less than 2% leakage so zero valve guide issues.
    Leaking Shocks replaced.
    Bushings (Hyper Blocks) Replaced
    Major Engine out service - everything done as well as:
    Tensioners, Motor Mounts replaced, Tension bushings, throttle cable, injectors pulled cleaned and blueprinted, shaft seals
    headers wrapped.
    Saldana racing single piece aluminum radiators installed both sides. New radiator fan.
    HVAC actuator motor and boss replaced.
    Triple seals replaced, throw out bearing replaced
    Water pump replaced
    2011:
    Speedo Sensor replaced
    2008/2009:
    Engine out service.
    Fabspeed headers. Cats have been modified for "performance".
    Alternator rebuild. Starter Rebuild.
    Crank Seal, Water pump replaced.
    2 Motor mounts replaced
    Hundreds of other little things.
    2008:
    Brake system repair - replaced pump and accumulator. Flush system.
    I have full records of everything above including pictures of the majors when they were done.
    Asking $95,000
    My cell is 770-401-3608 text me if I don't pickup, or leave a voicemail.
    4re308, Mikestradale, VAF84 and 11 others like this.
  2. ScudMarks
    ScudMarks Formula Junior
    Jan 22, 2018
    330
    Bay Area, CA
    Matthew Mauer
    Drooling....
    19633500GT likes this.
  3. Sean O'Neill
    Sean O'Neill Karting
    Apr 4, 2020
    51
    Sean O'Neill
    Gorgeous car! GLWS! Looks like a very fair price too.
  4. tres55
    tres55 F1 Rookie
    3,554
    Canada
    Has this been repainted?
  5. chris1866
    chris1866 Formula Junior
    Mar 14, 2005
    557
    Atlanta
    Chris
    Beautiful color! GLWS
  6. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Just some additional info from what people have been asking:
    Replaced the battery 2-3 months ago.
    Rossa Barchetta - They only painted 64 this color out of the entire F355 build, so this is a super rare color.
    Interior is TAN, the darker brown color.
    WJC likes this.
  7. The Outcast
    The Outcast Formula 3
    Apr 19, 2011
    1,562
    Royal Oak Michigan
    Wow!! Nice!
  8. 355dreamer
    355dreamer F1 World Champ
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
  9. ShineKen
    ShineKen F1 World Champ
    19,446
    Southern California
    Nostradamus
    Looks great! In pics, hard to tell it's not Rosso Corsa if not mentioned.
  10. Robb
    Robb Moderator
    Moderator Lifetime Rossa Owner
    Feb 28, 2004
    14,214
    Robb
    I'd pick this over Rosso Corsa any day of the week.....
    Nice looking car.
    Robb
    tres55 likes this.
  11. tres55
    tres55 F1 Rookie
    3,554
    Canada
    Agreed. Rossa Barchetta and Maranello are my two favourite reds. Corsa is a bit too bright for my liking.
    technom3 and Robb like this.
  12. WJC
    WJC Formula Junior
    Apr 28, 2004
    855
    Austin, TX
    Joe C.
    I didn’t know the number was so low. Is that for all F355 or just the same year as your car?
    RB is my favorite red and I want it on a 355 - just can’t purchase right now.
  13. 355dreamer
    Apr 3, 2006
    10,476
    DC Metro
    L.C.
    crinoid and ShineKen like this.
  14. Ed Russell
    Ed Russell Rookie
    Nov 24, 2018
    36
    Arizona
    Ed Russell
    Nice Car! 1995 is the year to have in my opinion. Pretty sure I own its twin. Hate to see you sell it but I am sure if will make someone very happy.
    ShineKen likes this.
  15. margarita
    margarita Formula 3
    Mar 20, 2011
    1,618
    usa
    Love that color hope you sell the car is Beautifull
  16. xpensivewino
    xpensivewino Formula Junior
    Jan 26, 2008
    952
    Simi Valley CA
    Need to know basis
    I owned the identical car. It’s possibly the best 355 color ever.
    Robb likes this.
  17. PorscheGuy
    PorscheGuy Formula Junior
    Dec 13, 2010
    520
    Irving TX
    Jeff
    I'm surprised it's still for sale.
  18. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    Its been under escrow for a week. 99% sure this will go thru just fine, just fixing something up before it goes on a truck. I'll update everyone once it ships.
    Thanks everyone for the kind works on the sale and comments on the car. Should be all wrapped up in a week or so.
    Natkingcolebasket69 and ShineKen like this.
  19. santana
    santana Rookie
    Nov 15, 2009
    3
    If it doesn't go through please let me know.
    Thx
  20. Matt Andrews
    Matt Andrews Formula Junior
    Dec 31, 2006
    515
    Newport Beach, CA
    I think there are a good number of us who are sad and relieved this is sold. (if it is) Great looking car.
    Natkingcolebasket69 likes this.
  21. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    She goes on the truck tomorrow at 10am. Sad to see her go.
  22. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
  23. Robb
    Robb Moderator
    Feb 28, 2004
    14,214
    Robb
    Congrats to buyer and seller. 355 are definitely great cars getting their due.
    Robb
  24. brendon0
    Dec 13, 2003
    611
    Tampa FL
    Brendon
    ShineKen and WJC like this.
