News
1999 456 GTA Overheating and steering rough
Discussion in '456/550/575' started by harryb, Apr 9, 2006.
  1. harryb
    harryb Rookie
    Nov 22, 2005
    5
    Harry
    I just had my 15k mile service done 3 months ago
    So today I am driving and the car starts to overheat and the steering becomes rough so I pull over and notice that the car is leaking fluid.
    I had the car towed to my local dealer but any Ideas what is wrong?
  2. Simon^2
    Simon^2 F1 World Champ
    Oct 17, 2005
    11,494
    At Sea Level
    what color was the fluid? was it radiator fluid? overheating and steering probs together should be pretty simple to identify the root cause of. not much commonality there. might be as simple as a loose fan belt.
    my guess is your dealer will know within 1 hour of looking at the car.
  3. Simon^2
    Oct 17, 2005
    11,494
    At Sea Level
    Any news???
  4. harryb
    harryb Rookie
    Nov 22, 2005
    5
    Harry
    It was a loose belt which caused the problem only an $800.000 fix not bad at all.
    Can not pick up untill Friday though
  5. paulchua
    paulchua Moderator
    Moderator Rossa Subscribed Owner
    Jul 1, 2013
    5,669
    Menlo Park, CA
    Paul Chua
    Was driving in, I see some water drops and bunch of water vapor smoke, steering is rough, and temp goes off the scale...thinking similar issue. Having it checked out.
  6. killer58
    killer58 Formula Junior
    908
    CA & DC
    Bet it's the belt- the water pump and power steering are driven off the same one.
    Hopefully, it won't cost $800 to replace a $25 belt and fluids !!
    paulchua likes this.
  7. paulchua
    paulchua Moderator
    Jul 1, 2013
    5,669
    Menlo Park, CA
    Paul Chua
    Just had the water pump.and belt replaced, might have come loose, thanks for your reply!
  8. paulchua
    paulchua Moderator
    Jul 1, 2013
    5,669
    Menlo Park, CA
    Paul Chua
    Yup, popped it open, belt was shredded. Getting it replaced. my past guy must have botched the install.
    Cheers
  9. paulchua
    paulchua Moderator
    Jul 1, 2013
    5,669
    Menlo Park, CA
    Paul Chua
    Did a compression test just in case a gasket blew - came in flying colors all around 200. Nice.
    Ordered the belt, having it installed, and a check to make sure the belts don't 'jump'
    rubenpadron likes this.
  10. paulchua
    paulchua Moderator
    Jul 1, 2013
    5,669
    Menlo Park, CA
    Paul Chua
    @yelcab I'll drop it off one of these days to ya to have you take a look as well. It's at Ted's at the moment.
