2.7 v. 5.2 engine cradle differences | FerrariChat
Discussion in '348/355' started by Carmellini, Nov 11, 2019.
  1. Carmellini
    Carmellini Formula 3
    Jul 16, 2019
    1,008
    wondering what the differences are between the 2.7 cradle and the 5.2 cradle? thinking it might be as innocuous as an E brake mounting tab....??? or, is there some major difference that would render it inadvisable to swap one with the other?
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    No major differences. The 2.7 version is more prone to cracking at the upright of the shock mounting points and that is where the 5.2 version is beefed up.
  3. Carmellini
    Jul 16, 2019
    1,008
    ^^^^^^^ is that "beef up" visually obvious?
  4. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    No. They use thicker stock material.
  5. krazykarguy
    krazykarguy Formula Junior
    Apr 17, 2014
    732
    Fort Mill, SC
    Matt
    The mounting tab for the upper wishbones is slightly different on the 5.2s. It’s buttressed.
    There is a thread about it from recently with pics.
    Qavion likes this.
  6. Carmellini
    Jul 16, 2019
    1,008
    ^^^ do you happen to remember when that was posted or the title?
  7. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,329
    Palos Verdes
    Vince V
    We found that there are additional gussets on later 5.2's as well.
  8. 308 GTB
    308 GTB F1 World Champ
    11,750
    New Jersey
    Barry Wolinsky
  9. Carmellini
    Jul 16, 2019
    1,008
    ^^^^^^ thanks for that link, and the info
    I have "heard" that the cradle is inherently a weak component and susceptible to a variety of issues.
    anyone want to comment on that "rumor?"
  10. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    The only weakness is the tendency to crack at the driver side upper support. I have not seen any other weakness. It is held to the main frame with 20 bolts. I don't know if I would call that weak. What are the rumors saying?
  11. Carmellini
    Jul 16, 2019
    1,008
    what I have heard, I don't understand: that the metal used is dirty (?)……. is of poor quality and does not take well to welding
  12. yelcab
    Nov 29, 2001
    13,621
    San Carlos, CA
    Mitchell Le
    Ah, you need to be a good welder. The thin metal is prone to blowing through but a good welder with gas will solve that.
  13. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Correct absolute **** carbon steel
    My winter project doing a 3D drawing off my measuring jig and building a correct rear section thats adjustable in all the right places
