2002 360 Challenge Restoration Project | Page 7 | FerrariChat
Discussion in 'Challenge/GT Cars/Track' started by Prototype_, Apr 19, 2023.
  1. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    Peter, the finer pieces were outsourced and CNC milled, based off the the original parts.
    I was told laser cutting doesn't work on polycarbonate as the heat discolors it - unlike Plexiglas which laser cuts really nicely.
    The larger shapes I cut with a jigsaw, and then fine tuned the edges with a mouse sander at 220 grit, going up to 800.
    I made a couple of mistakes, and I scratched one of the sheets, which I then tried to polish, but it hasn't fixed the issue - I believe with enough effort, you can buff out scratches. First time for me, so was trial and error. I guess with more patience it would have been an A, but Im going to give myself a B+ for this attempt. I'll see how noticable it is, once on the car, and then make the call on whether to redo it or not.
    NürScud, Mel Spillman, JAM1 and 3 others like this.
  2. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
  3. wthensler
    wthensler F1 Rookie
    3,538
    Gator Country, FL
    William
    Can’t wait to see the finished project! It has been a joy to follow this thread!
    P.S. are you actually going to track this car?
    Prototype_ likes this.
  4. PETER@TEAM AI
    PETER@TEAM AI Formula Junior
    Sponsor
    Nov 4, 2014
    372
    Charlotte
    Peter
    Dale
    Great to see you are still rocking along! Mine is apart for an engine sleeve replacement due to an oil/coolant pump failure! But best time of year here for having it apart!
  5. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    What a superb effort.
  6. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    You bet! Probably not nearly as hard as you track your car, but its going to be tracked for sure.
    Thanks Peter. Good luck with the sleeve ... this on the 430?
    Thanks John!
    Most of car now has the color and clear on.
    A few more bits and pieces to go.
    Going to let this gas out for the next 4 weeks or so, flattening the clear, assembly, and then will be working on getting the livery on.
  7. PETER@TEAM AI
    Sponsor
    Nov 4, 2014
    372
    Charlotte
    Peter
    Dale
    Yes on the 430. Good news is everything else looks great, mostly :). I will send a pic. Good color choice, but i am biased!
  8. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    HEADLIGHTS WORK IN PROGRESS
    PART 1
    Started looking into the headlights. Pretty bad shape - one of them had been opened up in the past and had some "race car repairs" done to it.
    It was still super difficult to open up, despite the fact that it wasn't the factory seal - but looks like they used the same grey stuff - which is seriously tough to get through.
    A bunch of YouTube vids showing a home made oven using a heat gun and cardboard box out there. Idea is to heat up the light and soften the seal.
    Wasn't so successful for me - I did a test without the light in it- heating up the box, and it caught fire.
    I think I was probably just too impatient - and wanted to heat it up quicker and overcooked things :p
    Anyway, decided not to go this route! :-D
    A friend helped me out - we heated up the seal all the way round, by blowing the heat gun directly onto it, going around the light a few times, and then he held the heat gun in place, and I pried it open with two plastic scrapers.
    Definitely a two man job using this method. It took a lot of effort to get the lenses off ...
    The lights were broken and cracked in a bunch of places on the one that had been repaired previously, and the actual light clusters in rough shape too with the mirror chrome plating chipping off, overspray and dust etc. ...
    Expensive part to replace over $2000.00 per headlight ... so this is a nice challenge to see if I can get something acceptable out of this ... if not - its an easy replacement for the future ...
    The lenses were stone chipped, as is to be expected, so I started sanding them down, and eventually polish.
    I figured a way to help hide some of the issues with the lenses would be to go with Le Mans style yellow film....
    So a bit of an experiment, trying to see if I can salvage these lights ...
    7Robwilson likes this.
  9. veldhuisjr
    veldhuisjr Rookie
    25
    Netherlands
    Jeroen Veldhuis
  10. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    Nice ! I’m happy to send you the digital files then you can have it printed. Any sticker shop / bureau can do it. What are the roll cage numbers and roll cage colors ?
  11. kaj750
    kaj750 Formula Junior
    May 9, 2022
    313
    Fresno, CA
    Late to the show.. did someone already ask what kind of silicone you soaked the rubber and plastic pieces in? Very interested!
    Ryan S. likes this.
  12. veldhuisjr
    veldhuisjr Rookie
    25
    Netherlands
    Jeroen Veldhuis
    please mail to
    [email protected]
    really appreciate it!!
    If you are looking for spares, i have alot, also wheels
  13. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    Any off the shelf spray silicone from a hardware store etc. Clean the part thoroughly, put some newspaper down and spray the part until it’s saturated. You may even see air bubbles coming out of the plastic, depending on how dehydrated it is … place parts into a plastic bag and tie the bag up. Place the bag onto a surface you don’t mind getting covered in silicone. (The silicone will seep through the plastic bag over time). Leave for a few days. Buff off with soft cloth. Works for rubber too.
    kaj750 likes this.
  14. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    No prob - I’m assuming your roll cages are black ? I changed the decal for mine to work on a white surface - so lmk - so I can change it to black for you, if that’s the case?
    Secondly - do you have your roll cage serial number ? It’s the red omp decal with a number - so I can change my number to your number/s before sending.
  15. veldhuisjr
    veldhuisjr Rookie
    25
    Netherlands
    Jeroen Veldhuis
    Indeed black.
    Will check on cage nrs, will get back to you. Or is the file open to make changes to data?
  16. kaj750
    May 9, 2022
    313
    Fresno, CA
    You are a life saver, dude. Thanks! Is there any silicone seepage at first? Should I let the parts air dry for a while before reinstalling? Thanks, again.
  17. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    No - the plastic will absorb what it can, then the soft cloth will remove the excess - it won’t have any residue etc … just wipe it off.
    kaj750 likes this.
  18. veldhuisjr
    veldhuisjr Rookie
    25
    Netherlands
    Jeroen Veldhuis
    have the following roll cage nrs: 26983+27349+29347+29810. Yes indeed 4 CH cars
  19. veldhuisjr
    veldhuisjr Rookie
    25
    Netherlands
    Jeroen Veldhuis
  20. Prototype_
    Prototype_ Karting
    Mar 31, 2023
    111
    Dale
    Sent!
  21. Happychris
    Happychris Rookie
    Feb 1, 2015
    6
    Germany
    Christian
    NürScud and of2worlds like this.
  22. PETER@TEAM AI
    Sponsor
    Nov 4, 2014
    372
    Charlotte
    Peter
    Dale
    All looking amazing. Headlights in the oven to slowly warm, takes a bit of time but a one man job! Great work!
  23. tres55
    tres55 F1 Rookie
    3,572
    Canada
    Just stumbled across this thread as I'm currently looking at a 360 CH myself and this is turning out so damn nice I'm feeling a little disheartened looking at all the shortcomings of the cars I'm looking at now! :D
    This is almost too nice to track!
