2004 360 Alarm module failure | FerrariChat
Discussion in '360/430' started by Scotter, Dec 8, 2013.
  1. Scotter
    Scotter Rookie
    Apr 2, 2013
    8
    #1 Scotter, Dec 8, 2013
    So the other day we had a 360 towed in with a no start condition. I tried everything like punching in the secret code with the key, tried all fobs etc. I tried a few other tests and finally set about removing the alarm module/siren under the front boot area on the drivers fender well. It looked sound and the wires were secure, no corrosion etc. I finally decided to punt and got a razor and cut along the seam to take a peek inside for the infamous dead batteries. This is what I found. The batteries had leaked their guts out and eaten up the circuit board. I have never seen this before but I thought Id share this with the board as it is a common problem with batteries failing, just not like this.
  2. Starfish
    Starfish Rookie
    Feb 28, 2012
    40
    So Cal
    Very common problem.
  3. tazandjan
    38,087
    Not only common, but should have no affect on starting.
  4. Fatty
    Fatty Karting
    Jun 5, 2010
    235
    Australia
    #4 Fatty, Dec 9, 2013
  5. vrsurgeon
    vrsurgeon F1 World Champ
    15,919
    Charleston, SC
    Curt
    Yup that's about right...
  6. Scotter
    Scotter Rookie
    Apr 2, 2013
    8
    I forgot to mention the part about the blown fuse.
    Sent from my DROID RAZR using Tapatalk
  7. vrsurgeon
    15,919
    Charleston, SC
    Curt
    It is interesting that the car wouldn't start at all... unless the blown fuse quit power to the alarm system, in which case yeah the car won't start. Almost was thinking that the later models might have had version 3 of the wiring schematic and that is what led to no start versus the red light on all the time..
  8. Scotter
    Scotter Rookie
    Apr 2, 2013
    8
    Yeah I had no red light either...it was just dead.
  9. English Rebel
    English Rebel Formula 3
    Aug 13, 2013
    2,158
    Piedmont Area of NC
    Alan
    Is it best to be proactive on these batteries and install a remote rechargeable to avoid this mess? Mine was replaced over a year ago.
    Alan
  10. tazandjan
    38,087
    Alan- Only works if the interior of the siren and its recharge circuitry is not trashed by a leaking battery like Scot's was. Brian Crall said he replaced a few of the batteries on sirens but they always came back, so he gave up and only installs new sirens. With a GM replacement available for less than $100, not much sense in fiddling with it, even if the sound is different.
    Scotter- A blown fuse will shut her down, obviously.
  11. 993turbo
    993turbo Formula Junior
    Oct 4, 2006
    317
    Puerto Banus
    Remi E
    Any part number / pointers for the GM part?
    :D
  12. cpoferrari
    cpoferrari Karting
    Jun 30, 2013
    60
    So the same issue came up with my 360. The car starts now but I was told it can fail anytime and that I should replace the module. problem is locating a new one without going for Ferrari dealer. Can anyone offer advise?
  13. hwyman
    hwyman Formula Junior
    Jun 25, 2015
    329
    Canada / Los Angeles
    Lol I went through the service records on my 550 and it looks like the cars had the siren replaced 4 times, I just ordered the 5th. What a great design
    EastMemphis likes this.
  14. one4torque
    one4torque F1 Veteran
    5,123
    Houston
    One4torque
    In 2 yrs of ownership I'm on my 3rd siren. Kisses and hugs to the engineer of this system.
  15. hwyman
    Jun 25, 2015
    329
    Wink wink someone should come up with a retrofit kit
  16. fotostars
    fotostars Formula Junior
    Feb 6, 2015
    341
    Bay Area
    Wow!! You probably have another issue somewhere. What replacement part are you using?
  17. one4torque
    5,123
    Houston
    One4torque
    I did get the trev bypass finally.
    remfrs likes this.
  18. JaguarDriver
    JaguarDriver Karting
    174
    Atlanta, GA
    Dick Maury
    I converted to a remote rechargeable battery pack which is now easy to get to if replacement is needed. Here is a pictorial article I did: http://www.georgiajag.com/Ferrari/Alarm/alarm.html
  19. brogenville
    brogenville Formula 3
    2,020
    Robin
    Ah, glad to hear it. You use AV, or someone else?
  20. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    Great! Yes, who did you contact for this in the USA?
    Thanks.
    Kevin
  21. one4torque
    5,123
    Houston
    One4torque
    I used a local shop that used to work w trev.
    I did notice after the trev immob mod now my alm dash light stays on all the time when engine on.
    I tried a new siren and this did not change.
    So I presume it is an artifact of the bypass mod.
  22. Apollo 11
    Apollo 11 Karting
    Feb 11, 2019
    114
    San Francisco, CA
    Randy
    The LED on my car stays on all the time with the car running. Is that not normal? It seems to work ok.
  23. one4torque
    5,123
    Houston
    One4torque
    Apollo— ok maybe this is normal?? That would be nice.
  24. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,742
    Memphis, TN
    The LED on mine (360) stays on when the engine is running.
    This is an excerpt from the alarm manual.
    If I read this right, a solid LED indicates an anomaly present.
  25. one4torque
    5,123
    Houston
    One4torque
    Thx East when i queried trev I gather it is just a side effect of the immob bypass mod.
