2004 360 check engine light with slow down | FerrariChat
Discussion in '360/430' started by cpoferrari, Jul 3, 2017.
  1. cpoferrari
    cpoferrari Karting
    Jun 30, 2013
    61
    just took delivery of the car drove it down the shore for two hours on Friday. Used it yesterday to go down the street. The check engine light went on and message to slow down and see dealer. I was told by dealer to try shutting down and restart a few times. Thoughts? It was heavy traffic on the way down. Safe to drive home?
    thx
  2. mkzhang
    mkzhang Formula Junior
    544
    Philadelphia
    If the color of the lights are both amber it's probably just your cats overheating. Bad sensor, or a whole bunch of more serious issues that cause the cats to overheat
  3. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,832
    The Low Country
    Dave Steven
    My SlowDown light came on only at startup or restart and then disappeared after a minute. I have Cat Bypass pipes with O2 extenders so initially we thought it might be related to that. Then we tried swapping ECU's, then replacing each ECU one at a time with a new one. Finally the problem went away by replacing both ECU's. No CEL's anymore as well.
  4. vrsurgeon
    vrsurgeon F1 World Champ
    16,520
    Charleston, SC
    Curt
    So your car could potentially have a cat overheat situation and your dealer tells you to "try shutting down and restart a few times"? Why not get an OBD2 code reader and plug it into the car under the steering wheel and see what it says? Then post it here. You can also borrow them at the store as well.
    It's probably a vesicovini box (cat temp ecu) that has gone bad, but it's always nice to know what the car thinks is wrong.
  5. photi
    photi Rookie
    Dec 10, 2013
    44
    Nassau County LI
    Steve
    Is the car on a battery tender?
  6. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    As Curt said, could be a slow down ecu. Could also be a few other things. I'm afraid the vendor is looking to give you a diagnosis that isn't a cure. Take it back and get them to fix it. Let us know the outcome!
  7. cpoferrari
    cpoferrari Karting
    Jun 30, 2013
    61
    where do I get an OBD2 code reader?
  8. cpoferrari
    cpoferrari Karting
    Jun 30, 2013
    61
    no just got it
  9. cpoferrari
    cpoferrari Karting
    Jun 30, 2013
    61
    spoke to a Ferrari mechanic who said 99 % of the time it's the light not the CAT. Unfortunately I'm two hours from home. He said its safe to drive it home.
  10. photi
    photi Rookie
    Dec 10, 2013
    44
    Nassau County LI
    Steve
    I got a check engine and slow down warning as you describe as well as a few other gremlins when I first got my car 2 years ago. I disconnected the battery, reset(see the posts about that), and then started using a tender. No more issues. It may not fix your problem but it is a cheap and easy way to start.
