News
2005 612 Secondary pump not resetting for smog
Discussion in '612/599' started by matt dodwin, May 13, 2020.
  1. matt dodwin
    matt dodwin Karting
    May 14, 2018
    82
    matt godwin
    california residence :
    any one having issue with 612 not passing smog ,, what drive cycle you using
    i tried the one from FNA 360/575 2005. didn't work
    Reset .. overnight .. warmup 4min>>drive 3.5 mile at 2000 - 2500 rpm 3D 4th gear
    Etc...
    All reset properly except the secondary air pump..
  3. matt dodwin
    matt dodwin Karting
    May 14, 2018
    82
    matt godwin
    I did some search . I found one by member start TAZ..
    was absolutely amazing following the instructions, all worked and pass smog easily ..
    Saved me a lot of money .. thanks TAZ
    I remember those days when I had 456 was nightmare ...
    Any one with 612 or similar software and if you replaced/ disconnected the battery .. DO THIS
    ( you will need radio code )
    key in 30 sec
    Turn on ( don’t start) 30 sec
    Turn off 30 sec
    Start the car and Idle for 10 min ( all accessories off/ light/ ac etc..)
    drive normal no hard acceleration of shifting
    for 15 min..
    And you will pass
    brogenville likes this.
