430 - 2009 F430, 14,200 miles @25% clutch remaining. | FerrariChat
430 2009 F430, 14,200 miles @25% clutch remaining.
Discussion in '360/430' started by Extreme1, Apr 6, 2021.
  1. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    I just hooked up my Launch 431 and got the 75% worn reading. The car drives and shifts great. At what percentage will I start having issues and have to replace the clutch?
    It’s never popped into neutral, yet.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    You sure not 25 precent worn ?
  3. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    Using your launch device, try this rather than using their percent wear reading:
    Calculation of clutch wear percentage for Ferrari 360/430:
    closed clutch position - NEW closed clutch position / Clutch thickness (8.5 mm for 360, 5.6 mm for 430) * 100 = % wear on clutch
    Kevin
  4. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    Kevin,
    Can you clarify that please? I don’t understand. I’ve only used the Launch a couple times and am still learning it.
    My email is [email protected]
    if that would be easier.
    Thx
  5. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
  6. armedferret
    armedferret Formula 3
    Mar 24, 2018
    1,141
    Maryland
    Mark
    Edit for better info below.
  7. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    kes7u and armedferret like this.
  8. armedferret
    Mar 24, 2018
    1,141
    Maryland
    Mark
    Oh that's significantly better lol. I didn't notice the 231 at first. I believe the 301 is the correct choice but someone who knows more will chime in shortly with a more reputable answer. ;)
  9. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    When I bought the car a year ago with 12,900 miles, I was told there was 83% remaining when they “snapped” the clutch.
    Any ideas?
  10. armedferret
    Mar 24, 2018
    1,141
    Maryland
    Mark
    I'd be willing to bet that the second image you posted is the correct one then. That would be a much more realistic figure, ultimately. 75% life left after 14k is significantly more along the lines of what others report for mileage from a clutch than the inverse. Going through 75% of the clutch in 14k miles tells me someone was either reversing it uphill for almost all of those miles, or doing a *LOT* of 0730 laps of the 495 beltway around DC. :D
  11. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
  12. kes7u
    kes7u Formula 3
    1,148
    Shorewood, MN
    Kevin
    This is the correct one.
    Also, I did not know if Launch calculated the clutch wear correctly. Apparently it does:
    (18.42-16.92) / 5.6 *100 = 26.78% clutch wear
    Kevin
  13. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    5,692
    Central NJ
    Dominick
    Sorry late to the thread here ..second one is correct .. nice
    10.95 version is really good ..not like the earlier version
  14. CoreyNJ
    CoreyNJ Formula 3
    2,032
    New Jersey Shore
    Sounds about right at about 27% clutch used for 14,000 miles. Mine is about the same and I am at around 13,500 miles on my 2009.
    armedferret likes this.
  15. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,231
    Santa Clarita, CA
    Thanks for the replies. That’s great news. I don’t have to spend $6000 on a new clutch yet, and be without the car for a week.
  16. armedferret
    Mar 24, 2018
    1,141
    Maryland
    Mark
    Sounds like you should celebrate with a drive. :D
