2010 California fuel door release
Discussion in 'California/Portofino' started by Randbrit, Jun 7, 2017.
  1. Randbrit
    Randbrit Rookie
    Jun 3, 2017
    4
    Rancho Mirage
    Darrell Auxier
    I'm a new ferrari owner and recently the fuel door button on the floorboard is not releasing the door. Talked to a Recambi parts guy and he said it is very unlikely that it is the fuel door actuator, but before I spend 300-400 on the trunk/fuel door switch, does anybody have any experience with this problem. Thanks
  2. vjd3
    vjd3 Formula 3
    Rossa Subscribed Owner
    Jun 3, 2005
    1,030
    Rhode Island
    Vic
    Can you swap the connections and see if the trunk switch will then open the fuel door?
  3. Ricambi America
    Sponsor Owner
    Dec 7, 2003
    14,841
    Winston Salem, NC
    Daniel
    #3 Ricambi America, Jun 7, 2017
    That's a pretty clever idea! I don't remember holding this one in my hands (I think Cameron took the photo), but it doesn't seem like there are two discrete connections that could be swapped, unless you open the switch itself.
  4. vjd3
    vjd3 Formula 3
    Jun 3, 2005
    1,030
    Rhode Island
    Vic
    Not a bad idea to open it ... that may reveal the issue -- broken contact, bad solder joint, etc. Or, if you can apply voltage to the actuator and see if it operates. These are all good ideas in older cars, but not so sure on the newer ones : )
  5. SciFrog
    SciFrog Formula Junior
    Apr 9, 2008
    566
    Had the same issue, just spent the money and the dealer fixed it...
  6. miketarrant
    miketarrant Rookie
    Jan 9, 2004
    36
    Happened to mine as well. I took the switch out and shorted the pins (cant remember which two but they are the pair either on the left or right) . This proved that the Motor actuator was working fine.
    Then dismantled the switch and sprayed with electronic contact cleaner. Also sprayed the pins in the cable and the switch connector.
    Reassembled and now all works again.
  7. Tired of seeing this ad? Upgrade now
