News
2010 Ferrari California window/top switch replacement
Discussion in 'California/Portofino/Roma' started by Steve1979, Mar 27, 2020.
  1. Steve1979
    Steve1979 Rookie
    Feb 12, 2020
    24
    Austin
    Steve Bowling
    I replaced the window switch on my 2010 Ferrari California today. The part number is Ferrari 82661100 and described as COMPL. RHT AND POWER WINDOW CONTROL
    This was quick and easy:
    1. In the center console you’ll see four hex head bolts. Two toward the rear and two in the front in holes by the cup holder.
    2. After taking the four bolts out the center console interior slides out.
    3. You’ll see two hex bolts below where the center console was. Remove them.
    4. Disconnect the three cables (two were under the console insert and one is the cigarette lighter that you’ll see when you lift up on the bar). Note: The clips slide off (and back on when reassembling) the plastic tab that holds them in place.
    5. Pull out the bar.
    6. Take out the four hex bolts holding the top and bottom together.
    7. Unscrew the 5 Phillips screws holding the switch on.
    8. Insert the new switch and reverse the process to put back together.
    I’ll attach a picture. Hope this helps. The dealer quoted 1.5 hours. I finished in 25 minutes.
  3. Steve1979
    Steve1979 Rookie
    Feb 12, 2020
    24
    Austin
    Steve Bowling
  4. Mike2010california
    Jul 12, 2019
    1
    Mike jones
    Steve. How do I get to the hex screws I am sitting I’min my California now I don’t see any screws. What do I need to remove and with what tool to get to the hex screws.
    I have the switch I just don’t know how th remove the center glove box “if I even need to”. And in the front of the center bar up by the air conditioner control. How or where are screws. I am assuming I need to remove something to get to the front bolts but not sure. Thanks mike.
    QUOTE="Steve1979, post: 147119754, member: 236096"]I replaced the window switch on my 2010 Ferrari California today. The part number is Ferrari 82661100 and described as COMPL. RHT AND POWER WINDOW CONTROL
    I’ll attach a picture. Hope this helps. The dealer quoted 1.5 hours. I finished in 25 minutes.[/QUOTE]
    Steve.
  5. Steve1979
    Steve1979 Rookie
    Feb 12, 2020
    24
    Austin
    Steve Bowling
    Hi Mike,
    The only screws to remove are in the center arm console. From there it slides out. In the front by the air conditioner it doesn’t have any screws. I’ll take some pics and post.
  6. Steve1979
    Steve1979 Rookie
    Feb 12, 2020
    24
    Austin
    Steve Bowling
