488 - 2018 FERRARI F488 WORKSHOP MANUAL | FerrariChat
488 2018 FERRARI F488 WORKSHOP MANUAL
Discussion in '458 Italia/488/F8' started by AvechuchoAxel, May 6, 2021.
  1. AvechuchoAxel
    AvechuchoAxel Rookie
    Dec 28, 2008
    20
    Hello guys, I'm looking for a 2018 F488 workshop manual.
    I'm working on a NFR node problem (ABS) that cause to driving selector ( MANETTINO) stays in WET mode all the time.
    Scanner doesn't detect NFR as installed module as well. It might be a ABS module failure or WIRING issue.
    So I need wiring diagram to pinpoint POWER + POWER - and CAN lines..
    I have code DTC
    U1706 NFR NODE ERROR
    U199D unknown error
    Thanks for any help...
  3. AvechuchoAxel
    Dec 28, 2008
    20
    Brake system node HARNESS W003. I need pin allocations for this connector.. Thanks!
  4. AvechuchoAxel
    Dec 28, 2008
    20
    I'm still looking for this info...... anyone?
  5. ChadR
    ChadR Karting
    Jun 19, 2019
    249
    Central Florida
    Taj B
    The only ones I've been able to source on here from my knowledge is the Ferrari california and the 458.
    Everything else is money
  6. AvechuchoAxel
    Dec 28, 2008
    20
    458 it's fine... I got the 458 but doesn't have wiring schematics.. Not trying to be cheap, just can't find what I need..
  8. Ruperto
    Ruperto Rookie
    Mar 28, 2012
    21
    Manila
    Ruperto
    Hi,
    did you get to resolve this already? what did you end up doing or replacing?
    thanks in advance
  9. AvechuchoAxel
    Dec 28, 2008
    20
    Not solved yet, ABS replaced, all fuses boxes checked 3 times. CAN checked 60 ohms / 120 ohms disconnected. Ground OK 2 12v power OK
    ABS still not showing on module list after scanning.
    There are 3 can lines that goes to the ABS. Can't do much without schematics.
  10. jonazizbey
    jonazizbey Rookie
    Jul 16, 2021
    9
    Aziz JON
    Hi Friend
    I have also exact your problem, have you managed to repair it?
    in my case I have even placed another used ABS control module just to check if it will connect scanner, but result is same,
    there is voltage from battrey and ign, grounds all fine. managed to find 2 pair of CAN lines, and check voltages on both, voltages are also OK.
    Scanner can not connnect ABS module, and when i disconnect abs plug and start car ABS light is coming on dash, connected and started car, ABS light is going off, It seems like ABS is communicating with some modules etc Engine, Instrument, but can not connect to scanner
  11. JuniorGT2
    JuniorGT2 Rookie
    Aug 29, 2018
    4
    Junior Strous
    Try replacing NBC body computer module,
    worked for me
  13. Mechanicrene
    Mechanicrene Rookie
    Aug 8, 2022
    4
    Dallas, TX
    Rene Lucero
    We’re you able to repair your problem??
