2020 812 Superfast ODBII code Reader | FerrariChat
Discussion in 'F12/812' started by Andy Hoepfner, Oct 6, 2023.
  1. Andy Hoepfner
    Andy Hoepfner Rookie
    Oct 10, 2020
    8
    Carefree, Aizona
    Andy Hoepfner
    Hi, I own a 2020 Ferrari 812 Superfast and bought a Foxwell 809BT ODBII scanner to monitor faults and other data (it has no problems at all!). The scanner works on 1000's of car models including Ferrari, Lamborghini and so on.
    It is a brand-new model and worked fine on my 911, Lambo and stuff. There is a long list of Ferraris that are supported, including V12's like Lusso, 599 etc. However, the 812 is missing in the list.
    I already contacted the Vendor, Foxwell. Is there another model that I can use that has the same/close electronics or is there a different Scanner model that I should have bought?
    Thanks!
  2. Andy Hoepfner
    Oct 10, 2020
    8
    Carefree, Aizona
    Andy Hoepfner
    Here is an update: I confirmed with Support that the 812 is not covered by the Foxwell, as a matter of fact by none of their model. I returned the unit.
    I then did some research and found the Autel Maxi Check MX900 series covers most old and new Ferrari models. Their website actually let you search the exact I Model of car you have. I ordered the MX900TS.
  3. DZ-96
    DZ-96 Formula 3
    1,904
    South Germany
    Daniel
    I fear 812 is not included.
    All testers i know ends with F12.
    Daniel
  4. Andy Hoepfner
    Oct 10, 2020
    8
    Carefree, Aizona
    Andy Hoepfner
    I checked on the website, it is included specifically. And that is the only brand I found that includes that model.
  5. DZ-96
    DZ-96 Formula 3
    1,904
    South Germany
    Daniel
    Andy, that would be great.
    Can you post an update here, if the SF is included ?
    Daniel
  6. Andy Hoepfner
    Oct 10, 2020
    8
    Carefree, Aizona
    Andy Hoepfner
    I tested the Autel MX900TS just to find out that every possible car BUT Ferrari is supported, although on the website the device is specifically listed. After chatting with Support I received the below answer.
    I now ordered the MK906PRO and will update my findings next week.
    [SUPPORT]
    After confirming with Autel engineer team, we are sorry to say that MX900TS itself is not compatible with any FERRARI vehicles in diagnostic functions.
    Because MX900TS has the same-level diagnostic function as MX808, which is the entry-level tablet in Autel diagnostic tablet scanners.
    Only the MP-series scanner such as MP808BT PRO/MP808S PRO/MP900 or higher-level tablet has the ability to be compatible with FERRARI vehicle.
    Dear friend, you have purchased the MX900TS wrongly. Please don't worry, you can contact amazon customer service center to return MX900TS back for a full refund.
    PS: Please kindly note that there is no one perfect scanner in the market that can be universally compatible with all the cars for all the functions. The functions are not universally compatible with every car. So, on our product page, we always suggest to our customers that they should check the function compatibility with us before purchase. The non-universally compatibility is the feature of all the scanners, not just for Autel brand scanners. Besides, some functions also depend on the actual condition of the car. Sincerely hope for your kind understanding.
    On your FERRARI car, MP808BT PRO or MK906 PRO or MK906 PRO-TS support the basic diagnostic functions such as read/erase full system codes, read live data and Active Test(bi-directional control) functions. But service functions/special functions are not universally compatible. If you need specific service functions for your car, please let us know and we will help you check the function compatibility before purchase.
    If you mainly need diagnostic functions(Not need the TPMS function), you may consider the MP808BT PRO or MK906 PRO.
    If you both need TPMS and diagnostic functions, you may consider the MK906 PRO-TS:
    MP808BT PRO:
    https://www.amazon.com/dp/B09F3MZZ3F
    MK906 PRO:
    https://www.amazon.com/dp/B09YMB3CWN
    MK906 PRO-TS:
    https://www.amazon.com/dp/B08PB6DHBS
  7. DZ-96
    DZ-96 Formula 3
    1,904
    South Germany
    Daniel
    Hi Andy
    Bad news.
    The good thing that they have to give back you the money.
    Daniel
  8. jaapio
    jaapio Karting
    Feb 19, 2016
    155
    Bruinisse, the Netherlands
    Jaap
    Have you purchased the correct Autel scanner ? either the MP808 or the MK906, I am curious to see if you got any feedback on it.
  9. Andy Hoepfner
    Oct 10, 2020
    8
    Carefree, Aizona
    Andy Hoepfner
    Yes, I finally found the correct Autel scanner after sending the others back, the Autel MaxiCOM MK906 PRO. Basically according to support it comes down the Pro Series and I was surprised to not only see the 812 Ferrari, but also the Lamborghini Revuelto.
    Of course you get what you pay for, $1369.00. Its still better than north of $3K like other professional scanners. After all we drive Ferraries. :p
    jaapio likes this.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,864
    Central NJ
    Dominick
    Did you actually try reading data ..alot of tools say they can handle a car but cannot connect or read data
    ..e.g. launch with a 512tr
  11. Andy Hoepfner
    Oct 10, 2020
    8
    Carefree, Aizona
    Andy Hoepfner
    Yes, I just tested the Unit on my 812 Superfast by reading all the codes and resetting for testing purposes. It all worked fine. Unfortunately, that is the only Ferrari I have so I cannot speak for a 512TR.
    McLarenHitchhiker and flash32 like this.
  12. McLarenHitchhiker
    178
    Greater NYC
    Keith
    Thanks for sharing this
