308/328 GTB/GTS / DINO GT4 PARTS CROSS REF. THREAD | Page 10 | FerrariChat
Discussion in '308/328' started by thecarreaper, Jun 25, 2005.
  1. Jonny Law
    Jonny Law F1 Rookie
    3,210
    Over yonder.
    IT Guy
    Anyone know of a cross over for brake rotors on a '81 308?
  2. viper_driver
    viper_driver Formula Junior
    Jan 1, 2009
    978
    Vegas
    Jason
    I think they're Ferrari specific. You're stuck paying a ton for these.
  3. Dave Bendl
    Dave Bendl Formula Junior
    Dec 7, 2003
    808
    Chicagoland
    Dave Bendl
    #228 Dave Bendl, Oct 13, 2010
    This is the lockable map pocket on the back of the passenger seat. Check this thread prior to bidding for a key on e-bay.
    Complete Thread Details:
    http://www.ferrarichat.com/forum/showthread.php?p=139975237#post139975237
    As with many items on e-bay, buyers should take caution when bidding being careful to do their homework and pay fair market value. Allways do a search on F-Chat to see if other owners have reported sources prior to bidding.
    A good example of this is an e-bay auction where several people recently bid on a simple map pocket latch key for a 308. The auction ended with a bid war between 4 people and the key went for $51 + $9.95 shipping. The key can be readily had from a company in Ohio for $1.00 ea.
    I have known that I was missing the key for the map pocket (located on the back of the passenger seat) on my 308 GTS QV. I had some time to do some homework and asked a local 84' 308 GTS QV owner that has one of the most original 308's I've ever seen inspect his key. The key has a triangular (not oval) shaped cutout in the finger grasp. Doing a simple search on F-Chat, I found a thread started years ago http://www.ferrarichat.com/forum/sho...ompartment+key with a link to company in Solon, Ohio called Ohio Travel Bag http://www.ohiotravelbag.com/Products.html
    Check their catalog at http://www.ohiotravelbag.com/P210_Hardware_Catalog/index.htm Page 109, Item 1769K imported luggage key. I gave them a call at 1-800-800-1941 and the keys are $1.00 ea. + $7.00 shipping. I ordered 5, will keep 2 for myself, and give the other 3 to a few local friends with 308's.
    As for the $50 I saved, I'll fill up the tank this weekend and have a nice extended fall drive.
    Hopefully, no F-Chat members over bid on this readily available key.
    Dave
  4. cavallo_nero
    cavallo_nero Formula 3
    Nov 3, 2003
    1,707
    colorado
    Giovanni Pasquale
    Has anyone come up with a cross reference to the 308 GTS heater control valve??
  5. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    #230 Badman, Jan 8, 2011
    Anybody have a source for the plastic vapor line check valve (#124193)? The usual suspects want $140-$190 for it. I've heard suggestions it's possibly a cross on early Nissans.
  6. unwound64
    unwound64 Rookie
    Jan 19, 2011
    26
    Chicago's North Shore
    Trying to get a definative cross reference for rear brake calipers on a 308 gt4. From what I've read in various places I've heard early Porsche 911 or 914 and read front Kia Sephia? Does anyone know for sure which rear calipers would bolt in and operate in a 308 gt4? Thanks
  7. jfrazar
    jfrazar Karting
    BANNED Rossa Subscribed
    Jun 26, 2004
    223
    Savannah, GA
    Joe Frazar
    Same as a 914 Porsche with a spacer between the two halfs. That is the only diff. Understand that the 328 and Mondial 3.2 use a kia sephia front caliper in the rear. Diff brake set up on the 308 series cars. Yes you can buy pads for a 914 for the rear of a 308 series car. You can also use pads for a 911 for the front. Can't remember which one exactly. All of the above I have done on my own cars.
    jfrazar
  8. SilverLeaf
    SilverLeaf Formula Junior
    Feb 1, 2011
    309
    This thread should really be a sticky.
  9. 328gts1987
    328gts1987 F1 World Champ
    Mar 11, 2007
    13,009
    Rotterdam Holland
    Fred
    I have read some posts of engine lid struts but not one of Front lid strut of 328/308
    I have 328 europe model 1987 and think it has the same strut as US 328 model, don't know 308.
    Strut is not filled with gas, has a small ball to secure position. Anyone Idea of partno?/adres to order?
    Thanks Fred
  10. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    Hi All,
    Two more for the list, I think they are both new additions, and both fit my 78 GTS #26451:
    1) Front Wheel bearing seal: SKF 17257
    This is the seal that goes against the inner bearing and drives in place. On my car, 26451, there was also a dust cover that slips over this and I reused my original dustcover.
    This new seal also has the spring, a kind of collar around the sealing surface, that the original did not. This should be an improvement making a more durable seal.
    2) Air conditioner belt idler (tensioner) pulley: SKF 6002-2RS JEM (two required)
    The idler pulley for the air conditioner belt takes two of these little bearings. Be careful. There is a snap ring and spacer in between them, so you can't just press them out together. You have to push them out each side.
    Hope this helps somebody out there!
    Jeff
  11. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Jeff Ward
    #236 Fairview, Feb 25, 2011
    This took some footwork to get done. There are a couple cross references already posted that don't work for the 308, but probably do for the 328.
    New dryer from Advance Auto Parts (and many other suppliers)- $32 or less. This is a Four Seasons part number 33444. Fits a 1985 BMW 318i. As you probably know, but I didn't, the dryer should be changed periodically, it is not a once in a lifetime part.
    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Filter-Drier-Factory-Air_3892999-P_2948_R%7CGRP60000_888748811___
    Here are comparison photos. The new part has two metal tabs that you can easily cut off (already done in the photos). The extra piece you see in the photos is a pressure valve (a good thing), which doesn't get in the way at all. In the photos you can't see the threads for the shipping caps. The new one works- I've checked the threads, it fits the bracket, and even has the sight glass.
    Best to all, Jeff
  12. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Jeff Ward
    #237 Fairview, Feb 25, 2011
    And here is another, maybe the final one I have for the 308 air conditioning system:
    Part number 106644 expansion valve-
    Try NAPA TEM 207307, see picture for comparison. Of course, threads match up no problem. This particular valve is marked for R134, I'm sure you can get similar for R12.
    The particular NAPA valve is for 1985 Ford E150 Econoline van with 6 cylinder engine. That is the kind in the Scooby Doo cartoons....
    Jeff
  13. not2shabbe
    not2shabbe Rookie
    Sep 29, 2010
    4
    TEXAS where else...
    Thanks Fred
    1985-1989 Ferrari 328 Gtb Hood Strut Stabilus Ferrari Hood Strut Sg437002
    around 42.00 plus ship
  14. tempest411
    tempest411 Formula Junior
    Dec 3, 2010
    564
    Just a thought...Those are gonna be some pretty cheap brake pads! It's good to have the base number, so why not get a better quality pad with the application information?
  15. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    629
    Massachusetts
    Joe
    #241 jmaienza, Mar 11, 2011
  16. thecarreaper
    thecarreaper F1 World Champ
    18,097
    Savannah
    so why is this not a " sticky thread " anymore? I put alot of work into making this info public.
    :mad:
  17. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Jeff Ward
    I second that motion- a tremendously valuable thread. Please stickify it again.
  18. veet
    veet Karting
    Nov 4, 2010
    96
    Sudbury ON
    Vito L
    looks like the same light in my 1983 bmw e30.
  19. WIND
    WIND Karting
    132
    LIGHTHOUSE POINT,FL
    MARK KAHN
    NO STRONGARM # 4760 STRUTS , ENGINE LID=$25:00 A PAIR
    NOT LISTED @ ADVANCED AUTO
    who else carry them for $25:00 a pair
  20. thecarreaper
    18,097
    Savannah
    They used to, part numbers get changed as time marches on.
    Please update part numbers as they change guys. :)
  21. WIND
    WIND Karting
    132
    LIGHTHOUSE POINT,FL
    MARK KAHN
    can the small holes in the EXPANSION TANK be fiberglass over, instead of welding
    just a taught
    who has a tank for sale cheaper than JEGS ALUMINUM replacement for $80:00
    anyone has a complete GEAR BOX for sale (locally)
    still looking for $25: struts
    MARK (954)338-5211
  22. thecarreaper
    18,097
    Savannah
    for future use.
  23. SeattleM5
    SeattleM5 Formula 3
    1,264
    Kirkland, Washington
    Ettore Palazzo
    Thanks carreaper, I should have done that.
  24. thecarreaper
    18,097
    Savannah
    #250 thecarreaper, Mar 18, 2011
    my pleasure :) . I sent a message to a Mod as to why this thread is not "sticky" anymore.
    I have had several recent "thank you" pm's about creating this thread, for all of us. :)
    I will be adding more 328 info, as soon as my 328 is delivered and we take it all apart! :cool:
