308 A/C Thermostat Question | FerrariChat
Discussion in '308/328' started by MFlanagan, Apr 2, 2020.
  1. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    155
    #1 MFlanagan, Apr 2, 2020
    On my carb NA 308, 22963, inside the console, I find the Thermostat Control for the A/C with what looks like a loose wire (circled in red in the picture). It looks like it might have broken away from the spot on the Lighter that the White Arrow is pointing towards. It just doesn't look "Right." And the A/C isn't working, either. Anybody know what's right/wrong with this picture?
    The picture didn't come through. Trying again: Image Unavailable, Please Login
    Hydroxide1 likes this.
  2. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    From memory, I think it goes to the expansion valve or temp bulb under the bonnet.
    Martin308GTB likes this.
  3. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    I think you will find that is less of a wire and more of a tube.
    Saabguy likes this.
  4. Martin308GTB
    Martin308GTB F1 Rookie
    4,231
    Black Forest Germany
    Martin N.
    It has nothing to do with the cigarette lighter. That's the temperature sensor tube, which goes all the way to the evaporator/expansion valve. On my picture below you see the opposite end. Normally hidden under thick layers of tar tape.
    When I work on anything, what requires removal of the center console I am always anxious to break this tube as well. Has someone ever repaired a broken temp sensor tube? Or does this mean replacement of the whole thermostat switch, which is probably NLA?
    Best from Germany
    Martin
  5. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    155
    Yes, I can now see that it is a tube, and I have found the other part of the break -- going forward from the console -- What on earth am I going to do now??!!
  6. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    No, the temperature bulb for the thermostat goes into the fins on the evaporator, through a small hole in the housing (at least it does on my '85 QV). The coiled tube clipped to the suction line goes to the TX valve and regulates how much refrigerant is released into the evaporator. Thermostat switches are freely available - you just need to find one that fits the factory knob.
  7. Martin308GTB
    4,231
    Martin N.
    I would be interested as well in repair options. If there aren't any, you can purchase an incredibly expensive replacement (notice the surcharge) after FerrariUK/Maranello Concessionaires has opened their shop again. But noone know, when this will happen.
    Sorry for having no better information.
    Best from Germany
    Martin
  8. Martin308GTB
    4,231
    Martin N.
    Hi Patrick,
    maybe my picture is not completely clear or there were some alterations between the carb and QV cars. The tube I showed is definitely the opposite end of the thermostat switch inside the center console. It is not the coiled tube clipped to the suction line I was referring to. It is the -admittedely hard to see- tube end in the center of my red circle.
    I had my evaporator out. There's no temperature sensor going into the housing. I remember how much I was confused after reading this prior to my work and then not finding such a thing.
    Best
    Martin
  9. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Oh, OK. Maybe mine's not stock, but most car a/c's run the tube into the fins. I seem to recall a Service Bulletin about moving the TX valve sensor bulb, maybe they also changed it then.
  10. Martin308GTB
    4,231
    Martin N.
    I heard/read that the sensor tube on the late cars runs into the evaporator's fins. So it was probably stock on the later injected cars. But definitely not on the earlier cars like my late carb car.
    Best
    Martin
  11. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    On my GT4 it definitely slides in between the fins of the evaporator core through a small grommeted hole in the housing. I assumed it was a thermocouple that provides voltage to the controller based on temperature at the evaporator.
  12. Martin308GTB
    4,231
    Martin N.
    That's interesting on such an early car. Maybe it's not an early/late car thing, rather than a Euro/US-car thing?
    Best from Germany
    Martn
  13. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    FWIW my ‘82 308GTSI the t-stat tube is wrapped around the same evap exit tube as in the red circle of post 4. I have wondered why it would not be inserted into the evap fins, but also makes sense that the exit tube is the highest temp.
  14. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    No, it's a gas that simply operates an on/off switch
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Refrigeration expansion valves have a coiled tube connected to the top of the valve and the other end of the coil has a bulb about the diameter of your little finger, say 2 inch long. The expansion valve has a designed throughput of freon tuned to the system output and the expansion valve opening is controlled by the expansion of the fluid in the bulb. It is not an on/ off switch as such. The bulb is generally strapped to the gas outlet line from the evaporator and covered in insulation. If the gas coming from the evaporator is too cold then the fluid in the bulb sensors this and contracts, this reduces the pressure on the expansion valve diaphragm and reduces the liquid freon flow into the evaporator. If the gas coming out is too warm then it increases the liquid into the evap.
    You need the correct gas flow into the evap to get the best results but as the returning gas cools the compressor you cannot have it coming back too warm, if it comes back too cold then you get liquid freon in the compressor which turns the compressor oil into a gas/ oil bubble mix.
    Looking at the previous pic pt no 109809 ferrari temp switch- this is exactly like the thermostat in your domestic fridge and at £10 each it might be worth going to your local fridge repair co to see what they have as the ferrari part is silly money
    MFlanagan likes this.
  16. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    I realize the AC compressor is either running or not running but the use of a variable control knob for temperature suggests this controls how long the AC cycles on and off to maintain a given temperature and I assumed the metal rod is part of this control. If not there would have simply been a switch to turn the AC compressor on and off right?
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    The thermostat would control the compressor clutch to start and stop the refrigerant flow. Once the cool temp has been achieved the thermostat tells the clutch to disengage and the compressor stops pumping. The gas in the system would equalize the pressures so the suction and discharge pressures would be the same. The thermostat will have a variable air gap internally to give you a temperature range. Once the thermostat travels the range of the air gap it operates to start or stop the compressor. The switch to start stop the AC is the main system switch.
  18. Ferraridoc
    Jun 20, 2012
    16,192
    Gold Coast, Aust.
    Patrick
    Yes. I was referring to the temp control knob in the centre console.
  19. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
  20. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,464
    Tulsa, OK
    John McDermott
    I am still not clear on the purpose of the metal rod that connects the rotary control to the fins of the evaporator core? Can someone educate me on this?
  21. rjlloyd
    rjlloyd Formula Junior
    438
    Brisbane, Australia
    Richard Lloyd
    The metal “rod” is a capillary tube. It is effectively used to sense the temperature of the evaporator. The colder you set the temperature with the rotary control, the longer the compressor will stay engaged bringing the evap temperature down , once the sensor detects that temperature, it disengages the compressor clutch, until the temp exceeds the set value and re engages it again
    kiwiokie and waymar like this.
  22. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,835
    Isle of man- uk
    Well said sir
  23. MFlanagan
    MFlanagan Karting
    Dec 21, 2016
    155
    Researching -- Googling -- for appropriate replacements, it appears the big question is, "How long does the Capillary Tube need to be?" The previously mentioned example from Summit Racing (manufactured by Omega?), is 48 inches. I found longer ones from other manufacturers (MEI and Red Dot), 66 inches and 72 or 73 inches. Well, here they are:
    First, is 48 inches long enough? Second, are there other traits that I should be looking for besides the length that would make a difference? Is there one of these -- or the Summit Racing example -- that stands out as the most appropriate for a '77 308 GTB Ferrari?
    I can't tell you how much I appreciate all of your comments and your help.
    Thank you,
    Mike Flanagan
    Saabguy likes this.
  24. Martin308GTB
    4,231
    Martin N.
    Regarding length; I admit I don't know. But if all else fails. Since you have to pull the t-stat tube anyway for replacement, you could pull it now and simply measure the length and add the piece to your measurement which is still on the t-stat switch?
    This is, how I would proceed.
    Best from Germany
    Martin
  25. ferrariowner
    Feb 21, 2014
    1,109
    Mansfield, TX
    Ron
    I think the 48" is plenty long enough.
    One other observation about adjusting the rotary switch. If you don't set it so that the compressor cycles off occasionally, your evaporator can ice over. Especially during a highway drive.
    Crowndog and waymar like this.
