308 belts & bearings | FerrariChat
Discussion in 'Technical Q&A' started by ria, Nov 29, 2003.
  1. ria
    ria Formula Junior
    Nov 2, 2003
    728
    ohio
    phill
    if anybody is thinking of changing the timing belts and bearings for 308 2 or 4 valve this is the time to get them 2 bearings 2 belts at $ 112 intristed let me know.
  3. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    I am interested. Are they new?
  4. ria
    ria Formula Junior
    Nov 2, 2003
    728
    ohio
    phill
    yes this are all new parts
  5. 348paul
    348paul Formula 3
    Dec 27, 2002
    1,098
    Kent - UK
    Paul Hill
    Are they the aftermarket bearings or OEM?
    Paul
  6. ria
    ria Formula Junior
    Nov 2, 2003
    728
    ohio
    phill
    paul i think they are aftermarket.
  8. Dave
    Dave F1 Rookie
    Apr 15, 2001
    2,722
    Little Rock
    David Jones
    Thanks, but I always keep a spare set in my Ferrari parts rollaway.
    On a side note, if you are doing belts and tensioners at this time,
    then you are only completing half of the service if you don't adjust your valves.
    Which would mean you will also need cam seals, valve cover gaskets, and valve bucket shims to complete the service.
    It would sure suck to change the belts only to have an old sodium filled exhaust valve pop its face because it hadn't been adjusted in the last 20 years.
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,017
    Groton, MA
    Verell Boaen
    What part # is on the box?
    " on the actual bearings?
  10. ria
    ria Formula Junior
    Nov 2, 2003
    728
    ohio
    phill
    verell i will let you know as soon as i get them.
  11. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    Please let all of us know the part #'s.
    I have found that that Superformance seems to have reasonable prices and quality stuff. I just received my order for all the suspension bushings and seals for my QV. I haven't fit anything yet but they sure look pretty!
